Old 08-04-2003, 07:34 PM
thecarman thecarman is offline
Goathead,
What kind of electric fans are those? Where did you get them and how much? Could I get a similar setup for my 66 GTO? That setup looks so sweet with the Rodney Red. What temp you usually run at with that setup? What thermostat you use? 180?
Thanks!
[email protected]
[email protected]
Old 08-05-2003, 06:27 AM
GR8ONE68's Avatar
GR8ONE68 GR8ONE68 is offline
I bought a '95 Ford Windstar dual electric fan set up in the local wrecking yard. With the exception on blowing one fuse and getting up to 212°F, I have not seen it above 187°F on the street in 95°F. I reached 202°F racing at the Grove at the T-N-T, but it came right back down.
I also upgraded to a 94 amp alternator. I run separate wires to each fan and each one has a separate 30 amp relay and 30 amp inline fuse. Use 10 ga. wire with a 30 amp circuit. I have a 170°F thermal fan switch that I got in a kit from Summit. The fan switch has 1/2" NPT threads and screws right into the head. I don't like the type of sensors that sense the air temperature at the radiator. I want to know what the water temperature in the motor is.
Vance, I ran the hot leads directly from the battery to the relay, is this bad?
[img]ftp://members.aol.com/gr8one68/gr8one68.jpg[/img]
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac
Old 08-05-2003, 09:00 AM
Donovan Donovan is offline
I've modified a pair of 97 TA LT1 electric fans to fit my aluminum radiator. The darn thing stays at 190 and won't move any higher. I'm also using a thermal switch and relay setup made by hayden. If you look at the pics you can see the brackets and sensor fitting I had to weld in to accomodate the fans. I've posted some pics of the install here.
http://community.webshots.com/user/kickinchicken
______________________________
1968 Firebird Coupe - 3665 lbs.
350 HO
Long Branch Manifolds
TH350
3.23 open BP axle
PS, PDB and Deluxe interior
GPE Starter ... Small body HEI ... 2.5" Pypes w/X-pipe ... Ruggles Qjet
14.1 @ 99.1
Old 08-05-2003, 10:09 AM
350 HO
TH350
3.23 open BP axle
14.1 @ 99.1
