The Crank and Cam in the block. Nodluar Iron Indexed Crank..
http://ultimategto.com/cgi-bin/showc...71/71_00075_18 |
Enlarging the wristpen end to install a bushing for to make the robs free floating. Yes I know you can buy them this way. OH SH#T No one will miss that extra ten thousands!!!!!
Thw Comp XR-288-10 cam is now in the block, I spent some time on removing the flashings on the outside of the lifterbores and "smothing" out the lifter gallery area for better oil return.
Block Now has the Pistons in it, man I starting to get excited now!
THe slugs .005 in the hole, custom made JE Pistons 0.60 over.
Side pic got that Milodon Oil pan off the parts for sale section in this forum.
Side Pic
Just a Pic of the Timing Cover with the new SFI balancer. Degreed in the Camshaft, got a adjustable true double roller chain under there.
Another Side pic. More to Come soon................
Which damper is that?
Looks nice, what kind of compression will that setup get you? I am just a week or 2 behind you on a 400 build.
67 Firebird 400 Convertible (sold) |
Romac dampner, 9.5 to 1 Compression.
Arias or JE, which are they?
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT |
Sorry the are JE, Ihad two sets of slugs and I was in a hurry when I posted the pictures.
Am I missing something here?? A .060 over 400 with 102cc chambered heads will not give you anywhere close to 9.5:1 CR.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
Keep us informed on whether it runs as good as it looks. That's the real deal...
Not missing anything, but you can't assume that I would give away me whole combo's specs!!!
#38
Blown? Turbo? Cuz, it's not 9.5:1!! Looks good, good luck with it. Just wondering why you said it would be 9.5:1 with those specs.
#39
Maybe that crank has a little extra stroke in it.
Systems under stress fail catastrophically |
#40
Could be, but it wouldn't be a 400 then! (See topic header) Just breakin stones!
