Old 05-26-2005, 12:16 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 60man:
Oh well.....I tried mounting the alt. on pass. side head and still have problems. After much work lowering the radiator(Griffin) mount for hose clearance on alt. the belt won't line up on crank pully. It lines up with the PS slot..can't win...Back to my seach for a manual bax....... </div></BLOCKQUOTE>
Troy,
To use the alt kit on the pass side you have to shorten the spacer due to the location of the pass head relative to the face of the block. It sits further forward than the drivers side. Other than that it should get you where you need to be.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 05-26-2005, 06:26 PM
60man's Avatar
60man 60man is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Wade Congdon:
Troy,
To use the alt kit on the pass side you have to shorten the spacer due to the location of the pass head relative to the face of the block. It sits further forward than the drivers side. Other than that it should get you where you need to be. </div></BLOCKQUOTE>
Thanks Wade..I thought about that too. It appeared that alt. was all ready to close to head to do that. I'll try again when I am not pressed for time....have race tomorrow night...
I think I have a manual steering box I can use to..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 05-27-2005, 06:03 PM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
CSI gets my vote also. Four years running but not a whole lot of street. I used spacers behind alternator brackets to the block. I'm also running a underdrive pully though.
Old 05-28-2005, 04:06 AM
Bill Bolin's Avatar
Bill Bolin Bill Bolin is offline
I used the CSI for several years without a problem. Then I switched to a motor plate that mounts between the waterpump and the timing cover and the CSI wasn't going to work in my opinion due to the small hole for the impeller in the motor plate. I switched to the Meziere and have run it for two years without any problems. I believe both pumps would work fine in an application without a motor plate that mounts between the water pump and the timing cover.
Old 05-28-2005, 04:08 AM
Bill Bolin's Avatar
Troy, my alternator is about an 1/8" away from my head but I use the factory rubber boot to insulate it from touching without any problems. I have spares if you need one.
Old 05-28-2005, 05:46 AM
60man's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Pontiac462:
Troy, my alternator is about an 1/8" away from my head but I use the factory rubber boot to insulate it from touching without any problems. I have spares if you need one. </div></BLOCKQUOTE>
Thanks Bill...I have roasted my wrist several times by grounding my watch on the + terminal on the alt...insulater would help in many ways..
Still not sure if there is enough room even if I shorten spacers..Power steering got to go !!
ECM member.
MANDRA
Old 05-28-2005, 06:41 AM
Lee's Avatar
Lee Lee is offline
CSI from BOP-E, and I recently took the car on a 500+ mile cruise. Highest temp I saw was 194.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-28-2005, 07:19 AM
Hey 60Man, I know what your talking about. I really got lit up a couple years back shorting out the alternator. It melted my wristwatch band clean in half. Both pieces melted in to the skin and clung there. I had to pull both pieces out of the skin. Just another battle scare these injuns put you through...
Old 05-28-2005, 11:21 AM
60man's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by lerry:
Hey 60Man, I know what your talking about. I really got lit up a couple years back shorting out the alternator. It melted my wristwatch band clean in half. Both pieces melted in to the skin and clung there. I had to pull both pieces out of the skin. Just another battle scare these injuns put you through... </div></BLOCKQUOTE>
Yep...hurts like hell..It melted mine along with the skin. Band was welded to the stud on the alternator..Kill swicth helps a lot if I can remember to "kill" it.
ECM member.
MANDRA
