Old 06-09-2005, 04:01 PM
ks gto (Cap) ks gto (Cap) is offline
I would like to have opinions on whether or not to grease the bolts that hold the lower control arms. I thought if they were coated with a light film of lithium that they would be less apt to "freeze up" -- or would that be bad because of attracting dirt etc? thanks, Cap
1964 Gulfstream Aqua GTO - 389 Tripower 4 speed - Torq Thrust II's - Cowl hood
1965 Starlight Black GTO - "Wilhite" stroked 421 Tripower - 4 speed - Custom sound system - Frame off
2009 Mysterious (Black) Solstice GXP Coupe-5 speed
Cap & Robin Proffitt-GTOAA PR & Member Recruitment Team
Old 06-09-2005, 04:40 PM
GTOFARM GTOFARM is offline
lube the bolts, you will have no problems, look at it like this i have control arms with grease fittings
Old 06-09-2005, 04:45 PM
grease fittings ---good idea! Thanks, Cap
Old 06-09-2005, 05:02 PM
Shadowjack Shadowjack is offline
If you have stock rubber bushings, there is no way to use grease fittings. When you tighten them down, the inner sleeve is essentially locked to the bracket. If you want to keep the bolts from rusting in there, coat them with grease, antiseize, or whatever.
