Old 01-22-2006, 08:59 AM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
Default MSD BOX'S
Why does everyone put their MSD box's under the hood of the car??I would think the heat from the eng comp wouldn't help and getting wet also.I put mine under the dash[took out the a/c-heater box]on the pass side.
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
Old 01-22-2006, 11:47 AM
Armadillo Armadillo is offline
I can relate I put mine under the dash also. Made a sheet alum mount for it and bolted it to my heater box. At idle you can hear it working.
Tom
Old 01-22-2006, 01:07 PM
66bonne's Avatar
66bonne 66bonne is offline
Mounting mine where the glove box used to be.
Old 01-22-2006, 01:16 PM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
has anyone complained of msd failure by having it in the engine compartment?
My first lemans had the msd 5 box up there and it was fine.
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 01-22-2006, 01:18 PM
A friend of mine mounted his up front on the right side of the vehicle in the pocket where a battery would be on a Chevelle type "A-Body"
He had a nice supply of air coming off the fan there.
It was mounted to the inner fender with isolators.
Old 01-22-2006, 01:28 PM
60man's Avatar
60man 60man is offline
I know heat ='s resistance for electronics' so mounting under the hood can't be the ideal enviroment. I wanted to mount mine on front side of core support but wire leads were two feet to short. Mounted it in area where battery used to be instead. No problems so far but it is strip only car. On a street car continious underhood temps could be detrimental to MSD in the long run. JMO
On second thought I would rather have it mounted inside now that heater has been removed. That's probablly where I will mount my new 6AL-plus. Be easier to adjust micro-pots....
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 01-22-2006, 03:27 PM
Speargun's Avatar
Speargun Speargun is offline
I had an MSD 6-AL mounted on the inner fender of an old Jeep CJ-5. I ran it through the mud, deep water, dirt, dust, etc.... and never had a bit of trouble. I live in Florida and most of the time the under hood temps ran 130* +++
Of course, inside would be much better for it.
Old 01-23-2006, 12:11 AM
MAVbird76 MAVbird76 is offline
I had a 6L mounted to the firewall of my 76 TA. It only lasted about 1 1/2 to 2 years before it died. I don't know if it's demise was heat related, but underhood probably isn't the ideal environment for it. I took it all out and went back to the HEI.
Old 01-23-2006, 12:56 AM
02Hawk's Avatar
02Hawk 02Hawk is offline
I put mine under the dash on the driver side. Pain to get to but dry and I like the stealth aspect of it hidden
Old 01-23-2006, 01:02 AM
BVR421's Avatar
BVR421 BVR421 is offline
I put mine in a box on the shelf in the garage and my car starts and runs the same as it did with a 6al
Old 01-23-2006, 09:24 AM
BVR421- That's a stealth approach for sure!
I mount them inside too, with isolators, on the heater box with a plate...
Armadillo- Like this? (Ok, so it's all dirty in there, but it's under construction!)
Old 01-23-2006, 11:45 AM
wheelspin's Avatar
Thumbs up
These boxes are obviously durable, as they have survived underhood for more than 40,000 miles and five years on my a/c equipped GTO and GP. Useage includes summer cross-country trips thru Needles CA where the temps exceeded 114 degrees , extended idling on the SoCal freeways, and hot-lapping @ local strips.
Les
Les Iden
Old 01-23-2006, 01:01 PM
diddly diddly is offline
Talking
Those trips thru Needles don't count for anything though: "Cause it's a DRY HEAT!! (Just like where I live)
Old 01-23-2006, 01:19 PM
MoJo's Avatar
MoJo MoJo is offline
BVR, It's obvious you need the 7AL and Pro Coil I have on my shelf. Hey it's one number higher
""Guitar groups are on the way out", "The Beatles have no
future in show business"
Decca Records rejection of The Beatles - 1962
Old 01-23-2006, 02:19 PM
455, Very similar only closer to the squirrel cage. Am in Tampa now for work will not be able to post any pics till I get back. Not as stealthy as yours are.
Tom
Old 01-23-2006, 02:41 PM
Beebe's Avatar
Beebe Beebe is offline
My 6AL is under the dash , mounted to the back of the glove box since 98 and runnin stong .
About 9000 street miles and about 100 passes @ the strip, no hiccups, problems or worries.
Also Known As "Beebe" on other sites....... PZ , Pro-Touring , Lateral-G, TAC
Old 01-23-2006, 08:57 PM
sts sts is offline
Just like windchill, dry heat/wet heat dosen't affect ambient temperature. 130 degress is 130 degrees regardless to humidity.
Old 01-23-2006, 11:56 PM
wheelspin's Avatar
Wink
STS,
After living in the Arizona desert for many years myself, I think Diddly's comment is made in jest, as residents from this area minimize the high temps by stating "but it's dry heat" meaning low humidity. 114 dry degrees is still frickin' hot.
Les
Les Iden
Old 02-06-2010, 02:49 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
I like where you guys mounted the MSD box. I can "hear" mine and it is mounted in the engine compartment. Do you guys hear it or am I grounded somewhere??
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 02-06-2010, 05:47 PM
the-rookie's Avatar
the-rookie the-rookie is offline
Send a message via Yahoo to the-rookie
Funny, I'm trying to figure that out right now. I'm also thinking inside, but I wrenched my back and been laid up for a week.
