Old 04-02-2006, 10:46 AM
Don Brown Don Brown is offline
Default 65 GTO Throttle Cable
Does anyone know the difference in length between a 65 GTO Tripower with a four speed and an automatic? I bought a used throttle cable to replace the one that was lost(I put it away so I wouldn't loose it) during frame off restoration and it appears to be too short.
Thanx,
Don
Old 04-02-2006, 01:35 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
I don't think there is any difference. I also think a 4bbl cable is also the same.
Old 04-02-2006, 01:47 PM
Default 1965 GTO Throttle Cable
On Page 333 of the GTO restoration guide it gives the part numbers to two different throttlle cables for the 65 - Manual 9781587 and Automatics 9779930
Thanx,
Don
Old 04-02-2006, 03:00 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
i suppose a 6 cyl car would be even different yet?
haven't got that far with my clone yet, but will be soon
Old 04-02-2006, 08:54 PM
Jerry H.'s Avatar
Don, my reply was based on memory and experience. I have bolted many tripowers on 4bbl auto cars with no problems. Also converted a couple of 4bbl auto cars to tripower 4 speed cars, and never had to change the throttle cable. Now this is from memory from well over 15 years ago, so take it so what it is worth. I can't see why their would be any difference in an auto or manual car.
Old 04-02-2006, 11:10 PM
vidguy's Avatar
vidguy vidguy is offline
I dont beleive the cable need be different, what is different is the spot where the end of the cable terminates on the throttle arm on a 2 bbl vs. a 4 bbl.
What was different from the factory is the bracket. There are different brackets for Tripower (2 barrels) and 4 barrels.
On a 2 bbl (tripower) it holds the cable farther forward toeards the front of the car (carb) then on a 4 bbl.
If you try to hook up a stock 4 bbl cable and bracket on a tripower your cable will appear too short.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
