Old 09-12-2006, 01:26 PM
Ron Landis's Avatar
Talking recently acquired...
looking to go stick with a 421. Any help with clutch set-up? Thanx...and all your cars here are an inspiration. Ron
ID:	64964   Click image for larger version
ID:	64965   Click image for larger version
ID:	64966   Click image for larger version
ID:	64967   Click image for larger version
  #62
Old 09-12-2006, 02:16 PM
tom s tom s is offline
I have found the stock cluth linkage to be weak with a heaver than stock clutch.Dave has made his work with no problem.I have done 2 cars with a hyd bearing and really like them.Tom
  #63
Old 09-13-2006, 09:06 AM
Ron Landis's Avatar
Talking Thanx, Tom...
I was thinking "hydraulic." Is there any certain set-up that might save me some head-ache? I really appreciate the help, as these are uncharted waters for us. Thanx again. Ron
  #64
Old 09-13-2006, 09:37 AM
I used the McLeod,really like it.Tom
  #65
Old 09-13-2006, 10:06 AM
White Warrior White Warrior is offline
Two racers I know have given up on the hydraulic and are making mechanical linkage. It's difficult to maintain the correct free-play in a hydraulic system.Shims in the throwout bearing have to be changed.
I have a simple and reliable mechanical system on my racecar.
ID:	65065   Click image for larger version
ID:	65066   Click image for larger version
ID:	65067   Click image for larger version
  #66
Old 09-13-2006, 10:25 PM
Pitch 400 Pitch 400 is offline
Tiacguy, Maybe you would know if this would work. I bought a 9" from Moser to fit a 68 Goat. Would this work in a 63 or 64 Tempest? Thanks. Pitch
  #67
Old 09-18-2006, 09:51 AM
Ron Landis's Avatar
Wink Hey...
I'm all about "simple and reliable" ! Would any set-up work? [V-8 or four] Or does it require a certain application. Who has a spare? Thanx again. You guys are invaluable fountains of information! Ron
  #68
Old 09-18-2006, 10:03 AM
It will work with either a 4 or V8 but you have to constuct it .Any good welder or chassis man can do it easily.
  #69
Old 09-26-2006, 11:40 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
This is the completed chassis for my '63 Tempest racecar. Next step, the body goes back on, the interior sheetmetal goes back in and I start with the wiring, brake lines, body work, etc. while I figure out how I'm going to pay for the motor. I have a billet crank and an MR-1 block for starters.
Jim
Name:	Painted chassis, 9-06 006.jpg
  #70
Old 09-27-2006, 01:05 AM
64goatman 64goatman is offline
Check out my post in the lobby about the Smurfs, the pics of our wagon are there
"Money can't buy happiness"
"But it can buy pontiac parts and that makes me happy"
  #71
Old 10-02-2006, 11:18 AM
Four of us lifted the body back on the chassis this weekend and I welded it on yesterday. It's starting to look like a car again.
Jim
Name:	body on chassis, 10-06 001.jpg
  #72
Old 10-07-2006, 06:19 PM
jackie jackie is offline
Default 61 Tempest Newbie
Hi - I'm the new girl in town, so to speak (thanks to mechanickeith for referring me!). Just bought a '61 Tempest Custom Coupe. I will attach pix shortly. It was born Tradewind Blue but someone palinted it royal blue/white twotone and redid the bucket seats. Would love to see more pix of other Tempests. Does anyone know how many '61 coupes survive? PHS is of limited help here. Thanks, Jackie
  #73
Old 11-12-2006, 12:09 AM
se428bandit's Avatar
se428bandit se428bandit is offline
here is a pic of a 63 lemans that i use to own around 1999 i was going to make it a sd clone,i seen it ebay a few years back painted black with a sd scoop and a tri power on the 326.
Name:	old pics 010.jpg
  #74
Old 11-12-2006, 05:07 PM
Peter Serio's Avatar
Thumbs up Photos from 1982
Here are some photos of my first Lemans. 326 V8 Automatic. I paid $550 for that car in 1982, it was a pretty good car for the time. I got it running, (it had been sitting for a couple years in a barn), Tune-up carb overhaul, new coil, spark plug wires etc. I drove that all summer long.
ID:	71643   Click image for larger version
Peter Serio
Owner, Precision Pontiac
  #75
Old 11-16-2006, 04:58 PM
k7king k7king is offline
Default "TEMP200"
Here is a 63 I am building. 421 sb 6 speed full chassis car. I am building the car as a pro touring and will attempt to go 200 mph at bonneville with it.
Thanks for looking
Mike
ID:	72106   Click image for larger version
  #76
Old 11-16-2006, 05:43 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Thanks for looking
Mike
620 rwhp might get you there. You going to have that?
  #77
Old 11-17-2006, 08:02 AM
Yeah I should. Dart little m Block, Brodix 18 degree spread port heads, 12.5/1 compression. This is a race engine that I am putting on the street. I will run it on E85 to keep it cool and for the compression. As you can see it will take awhile before I am done.
Thanks for looking
Mike
  #78
Old 11-17-2006, 09:48 PM
63Banshee's Avatar
Thanks for looking
Mike
Well then you'll get to 200... if the tires stay straight and on the ground. Can you make ANY body mods in the class you plan to enter?
Also, I'll through a pic of my own into this thread... More to come of my other '63s.
Name:	Tempiss waiting for first TMS run posted.jpg
  #79
Old 11-18-2006, 12:37 PM
No class. Just for fun. Good looking tempest Banshee.
  #80
Old 11-22-2006, 05:14 PM
Habanero's Avatar
Habanero Habanero is offline
Here's my 61 and 63
ALWAYS POWER!!!! ALWAYS PONTIAC!!!!
http://www.cardomain.com/id/habanero
