Old 02-22-2007, 02:52 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
Any chance it will be at VMP?
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, [email protected] (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 02-22-2007, 02:54 PM
ponchospidel's Avatar
ponchospidel ponchospidel is offline
Default new picts
picts.
ID:	83408   Click image for larger version
ID:	83409   Click image for larger version
ID:	83410   Click image for larger version
ID:	83411   Click image for larger version
Old 02-22-2007, 02:57 PM
Default 1 more
pic.
Old 02-22-2007, 03:03 PM
ducksgaot, maybee, it depends on if we have my dad's new engine done for his 62 cat. we are bringing 3 cars one way or the other. my Bird will be their for the friday night streetcar deal, my stepmom's car"THE PONTIAC LADY" and either "LIL'CHIEF" or my dad's car. VMP looks to be a lot of fun no matter!!!
Old 04-11-2007, 12:22 PM
jusjay's Avatar
jusjay jusjay is offline
Any updates???
Old 04-11-2007, 06:04 PM
car is ready, weather around here hasn't been good yet. hope to have it at the track in a week or two. did get it weighed, 2510 pounds race weight, i am 200# so the car is 2310#.
Old 04-11-2007, 06:05 PM
Old 04-13-2007, 12:45 PM
BigB's Avatar
BigB BigB is offline
any pics of the engine bay?
Old 04-13-2007, 01:36 PM
Default engine picts,
bigb, look at the first page of the thread, there are a couple there.
Old 04-13-2007, 05:41 PM
White Warrior White Warrior is offline
The weather should be getting better real soon here. Are you ready to take it to the track yet? Make sure you start out on the rich side or you could have a rod thru the block like I did. Mine leaned out because the manifold loosened up so make sure that doesn't happen.
I am putting on a Gutsram with 4 plugged ports,2 800cfm AFB,s mounted sideways with the secondary's disconnected and a new set of tires. Hope to have it ready in a week or two.
Old 04-13-2007, 06:27 PM
dave the car is ready, even had it down the road once. it seems to want to run.will double check the intake, didn't think of that, thanks for the info. boost should be around 20 pounds. hope to make about 600hp after tuning it. how much power did your make with yours last year?
Old 04-13-2007, 08:35 PM
I am guessing about 325 hp. The biggest problem has been a high speed miss in 4th gear above 7000 rpm which is from the lousy fuel distribution. The Gustram should fix that and hopefully ad some power.
