Old 05-12-2007, 11:33 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
1971 LeMans 3660 # without me. Fully dressed. Drive it as far as 100 miles at a time. No overheating.
455, stock crank & rods, TRW piston 80# pump. This lower end has been running since 1986. Starting to use a little oil though.
Comp P296AH-8 cam, 246/253 @ 050 566/572 lift with scorpion 1.65 rockers. Comp. Hi-Tech 5/16 9.250 pushrods.
6X#4 heads ported by SD Perf. to mid 260`s at 550.
T-2 intake with a Pro System 1000HP.
Mallory unilite re-curved to 36 @ 2300, no vacumn advance. MSD 6AL box set to 5600, MSD super conductor wires and NGK UR5 plugs.
Hooker super comp headers with 3 inch exhaust all the way to the back with 3 chamber flowmaster muffler.
All stock components are still there except a/c.
T-400 trans with modded governor, Trans Go stage 2 kit, Continental 10 inch converter.
12 bolt with stock posi running 3.55 gear. MT ET street 275/60/15 tire.
This car ran 12.21 @ 110.8 just the way it sits. 1.70`s 60`s Closed exhaust. Ran 12.24 @ 110 with a 1.80 60` also.
Needs a decent fuel system though and i`ll be putting one shortly.
Changes will be a new engine with e-heads and roller cam to make more power and higher vacumn than this engine.
As the pics show, this is no race car.
ID:	91177   Click image for larger version
ID:	91178   Click image for larger version
Old 05-12-2007, 08:49 PM
Thumbs up Cheap 400 build for 87 octane.....
Here's a low-compression 400 that I put together on the cheap.
I started with a 1969 400 engine that came standard in the Grand Prix that year, this one had around 90K miles on it. This one suffered the same fate as many others with the factory nylon upper timing chain sprocket. The teeth came off the sprocket and the next thing that happened was the valves started hitting the pistons, bending nearly all the pushrods. Beside maybe a couple of slightly bent valves, the rest of the engine was in great shape.
1969 400 block, still std. bore as the cylinders had almost no wear ridge, this engine must have had some decent care during its life. I reused the original pistons and put some new std. iron rings on them. Pistons sit about .020" down in the hole like most factory 400 engines of that era. The original rods were reused with new std. bearings, they checked out good. Same thing with the original 400 crank, new std. bearings installed and factory balance job retained.
1976 factory baffled oil pan with HO Racing trap door mod to retain oil pressure on hard right turns. Melling M54DS oil pump, pickup retained with a 10-32 screw through the pump housing and tube and loctited in place, HO Racing hardened oil pump driveshaft. Stock filter adapter with bypass blocked off using a 3/8 pipe plug.
1976 6X-4 350 92-94cc heads, no milling or porting/port matching. Rocker studs were replaced with 7/16" big-block Chevy studs and stock Chevy self-locking crimp nuts were used to set the valves. Stock valve springs were reused as well as the retainers and keepers. 1976 valve covers with the drippers were used to help keep the rockers lubed.
Compression works out to 8.2:1, I put the original #62 high-compression heads off to the side.
Edelbrock Performer cam (204/214 @ .050, .420"/.442", same as Summit 2800 cam) was used with stock 1.5 stamped rockers and stock pushrods. Cloyes Tru-Roller timing chain, cam installed straight-up.
1972 factory iron Q-jet intake and a 1972 455 750 Q-jet were used, the exhaust crossover was not blocked off. Topped off with a stock 1970 GTO twin-snorkel aircleaner.
Stock log exhaust manifolds with the outlet ID opened up from 1.900" to 2.100" to match up to the ID of the 2-1/4" headpipes. Full 2-1/2" mandrel-bent exhaust with H-crossover, Walker Dynomax 17749 20" long Super Turbo mufflers.
TH400 trans with Trans-Go shift kit and stock converter, stock 3.23 open rear and 235/75-15 (28" tall) whitewall radials. Engine resides in a 1969 Grand Prix, weighing 4100# w/o driver.
Best ET 15.11 @ 92.7 MPH, launching fairly easy to keep traction. Not bad for low-compression 400 running nearly all stock pieces, easily a high-14s car with any decent traction tire. I was getting 13 MPG with this car running at 80 MPH on the freeway with the A/C blowing ice.
An honest 270 HP 400 built strictly for commuting, runs hard on 87 octane.
The Following 4 Users Say Thank You to b-man For This Useful Post:
Old 05-12-2007, 08:53 PM
Starlight Black with Black Vinyl Top 68GTO with Q-Jet/Tomahawk/48s/470CID/SD-Rods/103N/Sw-PiTH400/3.54:1 Dana60/15" x 7" RallyIIs.
Wood Wheel-PS/Pwr 4-Wheel Dics brakes/AC/DELCO Stereo with Seek&Scan/Pwr Antenna.
Rally Cluster/Speed-O-Alert/Tach/Column-Shift for P R N 3 2 1, soon to be accompanied with HURST Floor shift for 3-2-1, & 1-2-3...and Neutral.
See top signature:
Old 05-12-2007, 08:55 PM
tc's Avatar
tc tc is offline
1965 GTO 3900lbs. 12.13 at 112 mph 1.71 60 foot
428, .030 over 9.9 to 1 compression
performer rpm intake, 850 holley
670 heads, home ported, chamber opened up to 78cc's
240 cfm at .400 lift, 250 at .500 lift with intake radius plate
solid cam 276/279 at .020, 246/252 at .050, .571/.561 with 1.65 rockers
montgomery ward magnetic conversion in stock distributor, sears penske coil
carter mechnical fuel pump
1 5/8 headers, 3" full exhaust, four mufflers
turbo 400, continental converter, stalls at 3400 rpm
10 bolt, 8.5, 3.73 gears, 27.7 diameter american racer tires
ID:	91213   Click image for larger version
ID:	91214   Click image for larger version
ID:	91215   Click image for larger version
Old 05-13-2007, 07:28 AM
Cliff R's Avatar
Cliff R Cliff R is offline
1973 Ventura with 1974 GTO hood and Shaker assembly
1973 455 engine, std/std "N" crank, Crower rods, TRW forged pistons, zero decked
KRE 85 cc "D" port heads, unported, other than gasket matched to a stock Felpro intake gasket
Custom "RAIV" hydraulic roller cam, 230/242/112
Modified factory iron or RPM intake (run about the same)
1977 Pontiac Q-jet from a 350 engine, recalibrated
Stock HEI distributor with a Mallory rev limiting module and positive stop added to the advance mechanism
Hedman headers, 3" head pipes with "H", Flowmaster mufflers, stock 2.5" tailipipes
TH400 with 10" Continental converter
8.5 rear, 3.42 gears, Mosier axles, Eaton carrier, tubes welded
3" custom driveshaft, 1350 joints, forged yokes
Stock rims with MT Drag Radials
Race weight 3760
The engine made 514hp on KRE's dyno, and 574 torque with over 550ft lbs availabe from 3500rpms to 5000rpm's
60' times 1.61-1.64
7.20-7.40 1/8 mile times right at 95mph
11.50-11.70 1/4 mile times at 116-118mph, shifting at 5000rpms
The car is daily driven, and raced on 89 octane fuel.....Cliff
Old 05-13-2007, 09:51 PM
ta man ta man is offline
1980 Trans am 3750 lbs 13.02/104 1.89 60 ft
455 bored 30 over by previous owner,stock crank and rods
6X/4 heads,mild port,crower springs 68404
harland sharp 1.65 rockers
crower 60919 camshaft installed straight up
performer intake
holley 750 dp 72/80jets
half inch open wood spacer
msd 6al hei kit
36 degrees timing all in by 3000 rpm
vacuum advance of 14 degrees at idle
continental convertor "Jim Hand Special"
tight ten inch that flashes around 3200 rpm
turbo 350 transmission with mild shift kit
hooker super comp headers 1 3/4
pypes 2 1/2 inch x crossover
2 1/2 inch ultraflos and flowmaster tailpipes
3.08 factory disc brake rearend
comp engineering subframe connectors
Old 05-14-2007, 09:24 PM
wheelspin's Avatar
Thumbs up 1966 GTO Sedan 462 combo
9 to 1, 462 Pontiac
1975 455 2-bolt block, magged, soniced, acid cleaned, align honed, square and zero decked, short-filled, + .030 bore size, ARP main studs, and BOP Viton main seal.
Pontiac 455 "N" crank std./std., bearing surfaces micro-polished, chamfered oil feeds, and FM main/ cam bearings/Clevite rod bearings.
Probe SRS forged pistons, light wristpins, and Total Seal file-fit rings.
Crower Sportsman, forged steel rods.
Matched & balanced rotating assembly w/ TCI SFI-approved flexplate and Pioneer SFI-approved balancer.
4X-7H 99cc Pontiac heads, relieved for 1.65 rocker pushrod clearance, ported to flow 255cfm @ .550 lift on the intake side by Flowtech, "421" head cooling mod, SI ss valves: 2.11/1.77, Chevy 7/16" rocker studs, Crower 68404 springs setup @ 108# closed and 288# open/1.620 installed height, ARP head bolts, and bronze valve guides/Viton umbrella seals.
Ho Racing HC-03 cam; 244/252 @ .050, .548/.563 lift , 108 IC, installed 4 degrees advanced, 1.65 HS full roller rockers, 5/16" Pioneer pushrods, Rhoads "cool face" style lifters, and Sims Machine Torrington thrust bearing timing chain setup.
Milodon stock replacement style 6 qt. oil pan, Melling #10540 60# oil pump, loctited pickup, "Dude" crank scaper, remote oil filter: Butler engine adapter, -8 ss lines, TD oil filter adapter, Moroso racing oil filter, and oil pressure sensed @ top of the block.
Cliff's 850cfm Q-jet, RA 4 gasket matched RPM intake/milled .070 in order to align ports and bolt holes, -8 ss feed & return fuel lines, Aeromotive SS pump/return-style regulator/fuel filters, and sumped stock gas tank.
Doug's headers; 3" Pypes X pipe, 3" electric cutouts, 3" 50 series Flows, and 2.5" full length tailpipes.
MSD ready-to-run distributor w/34 total degrees timing (20 in the dist. @ 1800rpm and 14 initial)/6AL ignition box/SS coil, and Moroso 8mm ignition wires.
Beefed 700R4 trans., Hughes deep pan, B & M Quicksilver shifter, B & M Super cooler, tight non-lockup 10" Continental 2800 stall converter, 3" Chromoly d/shaft, d/shaft loop, HR Parts & Stuf rr anti-rollbar, QA 1 shocks, no-hops, adjustable upper and boxed lower rr control arms, Chevy 12 bolt: welded tubes, 3:31 oem gears, Eaton posi, ARP studded main cap, steel axles, 4 wheel disc brakes, and 8" X 15" Weld Draglite wheels/4.5" backspace w/ M/T 28/10.5/15S (stiff sidewalls).
Cooling: Rodney Red radiator, B & M Super cooler, short-filled block, "421 head cooling mod", Milodon 11-bolt water pump, vented hi-flow 180 thermostat, and Spal dual 11" electric fans.
DRAGSTRIP RESULTS @ 3860# w/o driver and 1/2 tank of gas:
Speedworld (Phoenix AZ, driven there and raced, driven home) 3000 ft. da: 1.82, 12.56 @ 109
LACR (Palmdale CA) 6,000 ft. da: 1.84, 12.78 @ 105
Les
ID:	91463   Click image for larger version
ID:	91464   Click image for larger version
Les Iden
Old 05-14-2007, 10:34 PM
slowbird's Avatar
slowbird slowbird is offline
400 bored .035
stock crank ground, polished and balanced
JE pistons file fit rings
Eagle rods 6.625
ported 62 heads with 2.125 intake valve 1.77 exhaust valves both with 45 degree seats and RPM intake
flow of head with radius plate
.100 75
.200 160
.300 217
.400 254
.500 254
.600 254
flow with the rpm intake and 850dp bolted on
.100 74
.200 159
.300 221
.400 241
.500 234
.600 231
exhaust flow
.100 52
.200 123
.300 153
.400 177
.500 191
.600 200
Exhaust is cheap 1 3/4 headers with 2.5" pipes back to the cheap muffler, there are cutouts after the collectors.
cam is a solid flat tappet cam [email protected] .571-.594 with roller 1.65 rockers, 106 lobe seperation installed at 104, we dont run power brakes so vacuum is not a consern of ours. Vacuum at idle is around 5"
Car is a 73 Ventura that weighs 3600lbs stock 10 bolt with c-clip eliminators. 3500 stall convertor 3.73 gears
Was dynoed at 500hp best run to date is 11.42 at 119 in the 1/4 and 7.28 at 95 in the 1/8
ID:	91477   Click image for larger version
Old 05-15-2007, 11:33 AM
grandville455's Avatar
74 Pontiac Grandville
455 bored .040 with Stock rods ,beams polished, big ends resized,arp bolts
stck crank ground, trw slug flat tops,polished ,oil holes chamfered, entire assembly balanced,2 bolt studed bottom end
Bullet racing cam single pattern Hydraulic flat tappet with Rhoads Lifters, 108 LSA,set @104,231 231 with 556 556 lifts using my H.S 1.65's
6x-8 heads ported by Marty Warden flowing 250@400 lift and 260 @500 lift comp set at 9:3.1
Stock 69 intake opened up to 2.10x1.15,using a cliff q-jet and 1" spacer
dougs 1 3/4 headers into 3" X pipe with dumps
turbo 400 ,plate drilled for firm shifts,continental tight 10" 3200 stall
3.42 gears on 28x10.5x15 mickey slicks
best time to date in a terrible [email protected] with a 1.83 60 ft @ 4600pds
Darby
M/T 275/60 ET SS Drag Radial
Old 05-15-2007, 12:46 PM
wheelspin's Avatar
Thumbs up Mighty GP..............
9 to 1, 455
1969 2 bolt 428 block; magged, soniced, +.030 (std. 455 bore size), 11 bolt Milodon water pump.
Pontiac 455 "N" crank, std./std., chamfered oil feeds, and micro-polished. FM 3/4 groove main and cam bearings, and Clevite rod bearings.
Speed-Pro forged pistons with Total Seal file-fit rings.
Re-sized, stock cast rods, w/ARP bolts.
Owner bowl-ported #96 Pontiac heads (98cc); hardened valve seats, SI ss valves: 2.11/1:77, Chevy 7/16" rocker studs, Crower 68404 springs, and bronze valve guides.
Comp Cams #270 H sp cam: 224 @ .050, 106 IC installed straight up, .470 lift w/ 1.5 Comp roller tip rockers, 5/16" Pioneer pushrods, and Rhoads lifters.
Mellings #10540 race-prepped 60# oil pump, modded Pontiac full windage tray, angled Pontiac oil filter adapter for header clearance, and VR-1 20-50 lube.
Dual quads on Offy low rise intake: Early Buick 625cfm AFBs, progessively linked w/Mr Gasket a/c adapters and air cleaners.
Doug's headers, 2.5" X pipe, 2.5" Magneflows & 2.5" bullet type resonators, and 2.5" full length tailpipes.
MSD ready-to-run distributor w/ 34 total timing (20 degrees in dist./14 initial), Blaster SS coil, 6AL ignition box, and Moroso 8mm plug wires.
Beefed T-400 w/ 11" 2200 stall converter; stock rr w/factory 2:93 posi, ARP studded main cap, and Pontiac 8-lug wheels w/225-75R14 Cooper tires/27.3" tall.
Drag Results
Speedworld, Phoenix AZ (driven there, raced, driven home)............
4450# race wt. w/o driver and 1/2 tank of gas: 2.0, 13.54 @ 102mph.
Les
ID:	91542   Click image for larger version
Name:	2006  Pontiac Heaven Reagan Library 002.jpg
ID:	91598   Click image for larger version
Les Iden
Old 05-15-2007, 12:51 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thumbs up
Great thread!
This is the engine in my Formula, best pass in my sig below. Car is fairly loaded with A/C, P/S, PDB, P/W, etc. Everything works, BTW.
Pump gas 467" HO engine:
1970 "XF" code 455 block, 4.200" bore, zero decked
103 "N" crank, .010/.010, stock stroke
Eagle 6.625" H-beam rods
Custom ordered JE pistons, 10cc dome, 9.98:1 calculated CR, 215 PSI cranking pressure
Sealed power rings, FM bearings
Melling 60 PSI RA IV oil pump and driveshaft
7F6 '72 HO heads, ported to 276 Int / 176 Exh @ .550" lift @ 28" by Dan Barton of Westside Machine here in Houston
Bullet Cams solid flat-tappet camshaft, 232/235 @ .050", 144/145 @ .200", 538"/.555" net lift
Crower lifters, HS 1.65 (1.73) roller rockers, Comp 9.300" moly pushrods
Stock unported '72 HO aluminum intake
17084910 455SD SR Q-Jet, tuned by myself
Mallory Comp 140 fuel pump, Mallory return-style regulator, 1/2" feed and 3/8" return lines, BG pre-pump fuel filter
NOS OEM Pontiac point distributor w/ a "Breakerless SE" electronic conversion, custom re-curved by Rocky Rotella
R.A.R.E. 2.45" outlet SD exhaust manifolds
PYPES 2.5" mandrel-bent X-pipe exhaust system
Tom Hand prototype single transverse muffler
'69 TH400, rebuilt and upgraded by Circle D transmissions, 12.5" 8625982 GM "L88" converter, 2800 RPM flash
Moser 12-bolt diff, Eaton super duty posi, 3.42 gears
15x8 repop Rally II's, P255/60 fronts and P275/60 (28" tall) MT drag radials
"Race" weight of 3950#
Engine dyno netted 430 CBHP @ 5100 and 530 CBTQ @ 3000.
Idles with just a bit of a "rump" @ 850 RPM in gear with 14-15" of vacuum, and the torque will flat tear your head off!
Regards,
"455HO" Lloyd
Old 05-15-2007, 03:35 PM
77TA406 77TA406 is offline
1977 Trans Am...4 spd...3.73 rear
400 +.030 trw froged pistons dished for 9.6 comp
align honed, bored with torque plate.... .015 deck height
350P crankshaft turned .010 .010
stock rods, polished, peened and have ARP bolts
comp cams 222/228-.465/.474 with harland sharp 1.5 rockers
comp cams 9.130 magnum series push rods
1968 # 16 heads...unported but cleaned up
stainless valves, stock springs, ARP studs
RPM manifold, Cliffs Q Jet carb (awesome) 1/2 inch phenolic spacer
My own custom made air cleaner housing so all this fits great under the shaker
MSD digital 6...blaster HVC coil
Carter electric fuel pump
Car runs 103.7 mph shifting at 5500 rpm. best time so far is 13.70...no traction. have never got better than a 2.10 60' time.
feel a low is within reach
Waiting for my CNC ported #62's to arrive from SD
Chasing a 110 mph timeslip
Old 05-17-2007, 12:41 AM
stockcar32's Avatar
stockcar32 stockcar32 is offline
Send a message via AIM to stockcar32
1968 GTO
68 YS 400 bored .030, indexed and balanced. Speed Pro forged pistons w/ 12 cc dish on stock rods w/ ARP bolts, 10/10 stock crank.
#16 68' heads w/ crossover filled, bowls blended to 72 cc's and gasket ported. Ferra valves, Crower springs and retainers.
Stock 68' intake w/ 69' RA III QJ # 7029268.
Bullitt 280/288 @ .006 w/ 223/231 @ .050 w/ .463/485 lift @ 108 lc. w/ Rhoades lifters, stock 1.5 rockers.
Ram Air II air pan, MSD Pro Billet HEI dist. Hooker Comp. 4 tube Hooker Comp. headers into 2.5 Flowmasters out 2.5 tips at rear of car.
New Switch Pitch TH 400 w/ 3000 stall converter and the original 10 bolt w/ 2.93 posi's.
Car weighs 3975 dry, have not had it to the track yet. The Switch Pitch really allows it to launch hard and still obtain driveability on the freeway.
Name:	NEW GTO 008.jpg
ID:	91694   Click image for larger version
Name:	70 JUDGE 071.jpg
ID:	92350   Click image for larger version
Name:	70 JUDGE 067.jpg
ID:	92351   Click image for larger version
Name:	70 JUDGE 074.jpg
Old 05-18-2007, 08:04 AM
mr68's Avatar
mr68 mr68 is offline
Default 1968 GTO
Well, I have a 1968 GTO Nightshade with Parchemnt interior. IAII block, Eagle crank, Ross pistons, Eagle Rods, 505CI. KRE D_port heads 85cc ported to 330 cfm. Ruggles Q-jet, Edelbrock RPM intake with factory RAM AIR pan. Maddog headers, 3.5" Xpipe with3" tail pipes. Turbo 400 trans, Continental converter, 3.90 gears and Mickey thompson drag radials. http://youtube.com/watch?v=JhuegdYmDgI
Old 05-18-2007, 03:00 PM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
Here's my combination:
66 GTO Convertible Reef Turquoise, Black top, Dark Turquoise Interior
447 Cu In (Original 389 +.030 with Butler Performance Stroker Kit)
Bore: 4.092" (stock 4.062")
Stroke: 4.250" (stock 3.750")
Bored and Honed with torque plate
Block decked to a height of 10.215" (was 10.225")
Zero piston to deck clearance
Lightweight Ross Flat top Forged Pistons (+.030") (426 grams)
Relocated floating pins and double spiral locks
Sealed Power Rings (hand fitted)
Eagle 6.800" forged steel H Beam Rods (stock 6.625")
Rod to stroke ratio: 1.6:1
Clevite Rod Bearings
Eagle Crankshaft polished and balanced (4.250" Stroke)
Fed Mogul Main Bearings
Rotating assembly internally balanced
9.5:1 compression ratio
66 Tri-Power setup (replaced original Carter 4BBL and manifold)
Aluminum Tri-Power intake manifold (gasket matched and not painted)
Correct Rochester Carbs (jetting 71/66/71)
Comp Cams XE274H Cam (replaced an 068 that I had put in around 1990)
Adv Dur 274/286 Dur@ .050" 230/236 Lift .488"/.491" LSA 110
Crower lifters (manufactured by Topline Hylift/Johnson for Crower)
6X-8 Heads: by KRE (Kauffman Racing) (replaced original 093 Heads)
Street ported, gasket matched, exhaust x-over filled
Comp Cams 1.52" Roller Tip Rockers with polylocks
Milled for 96 cc bowls (setup for 93 Octane)
Flow: Intake Exhaust (at 28" of water)
.100" 90 62
.200" 147 131
.300" 201 164
.400" 228 182
.500" 246 196
.600" 244 204
Stainless Steel Ferrea Valves 2.11" Intake and 1.77" exhaust
995 Springs
Three angle valve job
67 HO Manifolds Ported by Ram Air Restorations to 2.41" and gasket matched
(replaced original 66 "log" manifolds)
2 1/2" PY Pypes mandrel bent aluminized dual exhaust system (no X pipe)
2 1/2" Dynomax Super Turbo 20" mufflers
700R4 trans 1st gear: 3.06, 2nd gear: 1.63, 3rd gear: 1.00, 4th gear: 0.70
Hughes 22-25L Lockup Converter (2,200 - 2,500)
3.23 "open" rear end (WAY TOO MUCH wheelspin...3.23 posi to be installed)
Tires: BF Goodrich Radial TAs (regular street) 225/70R14 (26.5")
Overkill for a street car that will probably never see the dragstrip again? Maybe it is, but it sure will be fun for the next few decades! I really do need to get the posi installed as the biggest problem is wheelspin! I just barely (and I mean barely!) get into the outside carbs and it's all wheelspin at most surface street speeds.
Here's a link to some pictures of the build.
http://forums.maxperformanceinc.com/...d.php?t=421089
Enjoy! Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
Old 05-21-2007, 09:30 PM
KS circutguy's Avatar
Smile
• Pontiac 400 CI block 1973 2 bolt main
• Bored +.060 over to 411.6834”
• Block torque plate bored and honed
• Mains align honed w/ARP main studs installed
• Crank is 73 400 Nodular iron turned .020-.020
• Block decked to .00 deck height
• Brass freeze plugs installed
• Pistons-Ross Custom racing flat tops +.060
• Rings Sealed Power Total Seal Classics w/ductile iron moly coated top ring each ring file fit to bore
• Rods-Eagle steel 6.625” long ESP H beam w/ ARP bolts
• Federal Mogul Trimetal full groove main bearings +.020
• Clevite 77 rod bearings +.020
• Clearance at .0025 mains and .0025 at rods
• Complete assembly balanced
• Canton road race oil pan installed with crank wiper and Melling pump
• Heads 6X Pontiac w/bronze guides, new hardened seats stainless steal valves, port matched, ported in bowl area, and short side radius, w/ exhaust cross over filled
• Heads milled .070 to achieve a 8.4 to 1 compression ratio
• Competition Cams # 995-16 springs steel retainers w/10 degree locks
• Competition Cams roller rockers 1.52 ratio, Crane Cams cool nuts
• Ultra Dyne solid lifer cam duration @ .050 Intake 243 - Exhaust 251 and Lift @ Intake .518 @ Exhaust .520 w/1.53 rockers Lobe center is 112 installed 8 degrees advanced to 103.5
• Flow Tech (by Holley) ceramic coated headers 3” collectors flowing to 2-1/2” X pipe and Magna Flow mufflers
• Edelbrock Performer RPM manifold w/ Carb Shop Custom Q-jet carb
• MSD billet distributor w/ 15 degrees initial 36 total, MSD 6AL box with rev limiter and MSD Blaster SS coil
• Custom built Continental tight 10” 3200 stall converter
• Turbo 350 trans by Hughes
• B&M Quicksilver shifter
• 8.5” 10 bolt with Auburn posi and 3.90 gears, Moser axles 28 spline
• Southside lift bars
• NOS Cheater nitrous system adjustable from 125HP-250HP
• Aeromotive fuel pump, Comp Engineering fuel sump, flowing threw Aero @ Russell hoses to Aeromotive regulator
• Paint is code #29 GM Dark Blue metallic
• All work performed by owner except machine work by Archie S. at Somers machine shop, and Karl Boe for the tuning help!
Car runs 13.00 - 105.68 mph street tires, 11.50’s spraying 200hp hit.
Car weights 4100 lbs. Currently re-building motor same heads ported, better head gaskets, Cosmetic’s ARP head studs.
Easy 12’s on motor I hope. Don’t know if I’ll finish motor this season or not.
Old 05-25-2007, 01:02 AM
sixt8bird's Avatar
sixt8bird sixt8bird is offline
400 CID .030 over
#16 heads, non ported, elongated pushrod holes,stock 39year old valves.
Stock rods
TRW forged pistons.
Street Dominator Intake with Knife edged dividers
Holley 800 stock
Comp 9000 Distributer
Hooker Super Comps 1 3/4
226-234 Crane Cam
1.65 Full roller rockers
TH 350 stock
3,000 Hughes Converter
2 1/2" Flowmaster exaust with X pipe
3:73 geared, stock 1979 8.5" rear disc brakes out of TA
3810 LB weight with me in it .
Fastest ET 12.60 seconds at 105.67
Fastest MPH 107.2 @ 12.62 spinning at the line.
http://www.youtube.com/watch?v=jpEgC6G12Sk
324 Rear wheel HP
404 Rear Wheel HP with Nitrous ( Stock 39 year old valves)
12.01 @ 114 bouncing hard off the rev limiter from 1000ft on
with a poor nitrous set up. Way to rich!!
  #38
Old 05-27-2007, 01:08 PM
mikejub mikejub is offline
69 GTO, 455, 4-spd.
71 455 HO block with 4-bolt mains 0-decked and bored 40 over. 85 cc KRE heads, gasket matched to RPM intake, otherwise heads out of the box. Crower 60919 cam (231/240), with Scorpion 1.65 roller rockers. Compression ratio yields 10.4 to 1.
Doug's headers...3" exhaust with X-crossover to 3" Xlerator mufflers, then 2.5" tailpipes out the back.
Q-jet reworked by Cliff Ruggles, using 3/4" modified spacer. MSD distributer (initial 12 degrees, 30 total). MSD blaster coil and 6AL box. Adding a 2-Step box for better launch rpm control. Fuel line...1/2" tapped into the tank right to the carb (modified inlet to accept 1/2 " line). Fuel pump...McRobb mechanical...pressure set to 6 lbs.
Trans...Liberty-built Chrysler iron case A-833 Hemi 4-spd (2.65 1st gear). New steel drive shaft 1350 U-joints at both ends. Driveshaft loop.
Diff...Chev 12 bolt, Eaton posi, Yukon 33 spline axles, 3.42 gears on 275/60/15 M/T Drag Radials. 11" drum brakes
Only had the car out to track once. 12.80 @109. No tuning or tweaking. Was having some clutch/launching issues which have since been sorted out. Can't wait to try it again. Thinking if I can get out the hole at full power and power shift, she might be down into low 12s. I'm hoping.
Great to see what others are running
Mike
ID:	92812   Click image for larger version
ID:	92813   Click image for larger version
  #39
Old 05-27-2007, 04:22 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Default 66 Full-sized combos
#1 - 66 GP A/C
YK 421
Tri-power w/ Mechanical linkage
Factory Longbranch manifolds & Turbomax
96 heads (9.5:1)
744 (RA III) cam
Pertronix IgnitorII
3.42 safe-T-Trac
TH400 w/ street/strip kit
Good stoplight car. Too much RPM for long open road w/ 3k @ 68 MPH but have done 3000 Mi. straight. Nice lumpy idle w/ enough vacuum for power, auto & A/C.
#2 66 Bonneville wagon w/ A/C
389 030 over
AFB 4bbl 4034S
092 heads (10.5:1) w/ stainless valves, hardened seats etc.
Speedpro pistons
068 cam Melling SPC-7 kit, Double roller timing, HV oil pump
Pertronix Ignitor I
2 1/2" duals & Turbomax
2.73 Safe-T-Trac - ballanced Driveshaft
TH400 w/ street/strip & adj. modulator
1 1/8" front sway bar, 7/8" rear = bulldozer handling
8 lugs
Excellent road combo. Unlimited top-end, nice low-end power. Great sound. 3.08 would make it the ultimate road warrior you could still afford to gas up for a 1000 mile trip.
ID:	92834   Click image for larger version
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
  #40
Old 05-28-2007, 02:59 AM
blown 68's Avatar
blown 68 blown 68 is offline
block .060 over 455 4 bolt block, steel caps, hard blocked to bottom of coolant holes, 474 cubic inch.
crank eagle crank 4.250 stroke.
rods eagle h-beam rods.
pistons ross flat top pistons, zero decked.
heads iron d-port heads, 6H, 129cc's, ferrea stainless valves, 2.11 and 1.77's. mild port work, never flowed. cometic head gaskets.
cam solid 'lazer' cam, crower lifters, 261 intake, 272 exhaust, @.050, on a 112 lobe sep, .589 lift.
power numbers 630 plus horsepower on 92 octane, 650plus lbs/ft of torque, all done by 6200rpm. haven't made it down the track yet.
intake modified offy manifold, with 6-71 flange. 6-71 blower, 3% underdriven for street, 3% over for a bunch more with good gas. dual edelbrocks, calibrated for this engine.
cooling milodon aluminum water pump, dual flexalites on re-four cored factory radiator tanks, 160 thermostat, never gets above 180.
transmission turbo 400 tranny, done up heavy duty style, 2200 10" continental converter.
rear end 12 bolt pontiac rear with 3.42's out back.
12 mpg on the highway, a whole lot less in da city......
she drives like a champ, real normal, considering the blower and all, 'til you step on it, then it's downright scary. oh, and a whole lot of fun.
Name:	68 GTO driver engine.jpeg
1968 Lemans/GTO clone, 6-71 blown 474ci
1969 Ram air III, Hardtop
(sold it to my dad!! still care taking for it)
