total crap, even after replacing the harness i still have grounding issues with the awful design,, also who the hell can see those faint things.
so i want to mod the tail light sockets with a real ground "wire" socket and get these things SUPER BRIGHT!!!!!!! but not melt the plastic lens. any ideas on what type of socket/bulb i should look into,,,, i thinking some type of halogen bulb... |
joe, just get a set of 72 torino sockets. they're all metal and ground thru the body. i put them in mine and solved the grounding issues that plagued my car. they fit in the gm lamps tight.
i got them thru carquest, in fact if i remember correctly they were in stock. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
sounds like a winner! are they any brighter then the GM type?
im going to add a 3rd brake light (license plate style) so i should be alright. btw i got the whole interior done in the 65,, complete with kickass sound system, electric cutouts and that nitrous purge lol im going to take some pictures today if the weather clears up. |
As a fellow 65 Convertible owner, I would be interested in seeing what you are doing for a sound system..
With all of the modern advances in technology and medicine, there is still no cure for the common birthday - John Glenn |
its louder then the cutouts lol... ill take some pictures in a few,,, i got those custom molded 65 kicker panels with speakers,(opg) they sound great!
You could also try the $18/pair LED bulbs available at Autozone. I put them in my '65 and they are super-bright, even through the grilles. I still have grounding/wiring issues, but brightness is no longer a problem.
Matt 1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor 1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD 1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring| 1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners 2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD 2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles |
I'll be building a custom LED tail light circuit board for my 65 when I get to that stage. Molded to wrap around the inside of lens. Won't help you now, but maybe down the road. I have a 66 lens too I thought about making some for, hard to see the stock lights through the louvers.
Sandman:
This should fix the issue you have. I went to Advance Auto parts and picked up 4 of the METAL connectors. Part number attached. They have the grounding tab on them. Picture attached. I sanded the lip of the hole that they go into about an inch all around with 120 grit. Made sure my screws holding the tail lens in was tight. Put the bulb in WHOA. Didnt need the ground after I did this. I put in NEW XEON bulbs that I got off of EBAY and these are so BRIGHT. You almost cant look at them because of how bright they are. Standard 20 amp fuse is NOT blowing so draw isn't much more than stock. I am going to do the same with the reverse lights. Got the XEON bulbs for those too. http://cgi.ebay.com/ebaymotors/LOT-o...QQcmdZViewItem Hope this helps!! Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
i think ill give those bulbs a try
good post...
I am fighting the same issue with my 65....I'll check out those ideas... |
yup all done,, i did the all metal housing with ground wire tab,, complete ground over kill lol
also got a pair of those extra bright xenon 1157 bulbs! ill never have to fuss with taillights again!! |
How did those blue tinted bulbs look through the red lense? Do they generate a lot of heat? Thanks
Did you guys encounter the grounding problem with a new (re-manned) harness? I recently purchased an MandH factory replacement harness, the sockets are plastic. Thanks.
the plastic housings are no good.
