Old 08-15-2007, 10:25 AM
RiceCooker RiceCooker is offline
Send a message via AIM to RiceCooker
Default towing ability?
Is it possible to hook a trailer up to a 79 bird? I mean, it is leaf spring and engine, tranny, and rear end should handle it, suspension should be the only worry right? Does anyone know if its possible.
Not saying I'd do it, but it does have me curious.
Old 08-15-2007, 11:22 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Yup. Back in the 70's and 80's there were direct fit trailer hitches for Camaro and Firebirds available at most auto stores. Being a unibody car GM's max towing capacity is 1000lbs but if the hitch was tied into the rear frame rails you could probably go higher without damage. I used to see to a '78 Trans Am around here with an Army surplus deuce and a half hitch mounted and he'd pull some pretty heavy trailers with that car.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 08-15-2007, 11:58 AM
wow, thats pretty cool. I wonder where you could get a hitch for the frame rails?!
Old 08-15-2007, 12:12 PM
Dens71TA's Avatar
I think it would have to be fabricated. All the hitches for F-bodies I've seen bolt to the rear bumper.
Old 08-15-2007, 12:16 PM
form74's Avatar
form74 form74 is online now
My 74 Formula at one time had a hitch on it, I just cut off the the two 5 inch braces that were welded to the rear frame rails to get the new exhuast to fit. Also as their a couple holes in the rear bumper. When I got the car the wires were still their for the plug and it had air shocks on it. Probably why the original motor was long gone as must of blown it up towing.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 08-15-2007, 02:21 PM
frans455's Avatar
frans455 frans455 is offline
Hmmm thats funny, I just sold a tow hitch that came off a 1979 Camaro. It bolted onto the rear frame rails and the bumper brackets.
Over here they tow caravans with them to camping meets, so yes ... they are great tow vehicles
Greetings Frans
Old 08-15-2007, 04:04 PM
2manyT/A'S's Avatar
Towing a trailer is a GREAT WAY to RUIN your driving experience & suck the unibody out of shape. If you like rattles,clunks & waterleaks,it's a great way to go.
T/A's & Firebirds are Sportscars/Ponycars/Musclecars but NOT TRUCKS!
Just buy a truck for towing your trailer. Your T/A will love you for it.
Old 08-16-2007, 07:34 AM
racerx23 racerx23 is offline
Default trailer hitch
If you need a Firebird/TA hitch,I just removed one from a 74 Formula.$25.00 + shipping from Dallas,GA.30157.
Later,Racerx23,Steve
Steve Thomas
Dallas, GA
1950 Chevy truck red/original drive train
1967 Camaro SS silver w/black stripes 8.91@153mph
1969 Camaro SS 350 white w/black stripes
1971 Firebird 350 matching #'s white/blue int.
1975 Trans Am Blown 509 blk.
1975 Trans Am 400 matching #'s silver,loaded
1979 Trans Am 301 matching #'s,black
1980 Trans Am 301 matching #'s,t-tops,blue
1982 Mitsubishi drag truck 383 sb runs 9.92@ 133mph
Old 08-16-2007, 08:40 AM
frans455's Avatar
Thats why I sold the tow hitch in the first place - its a sportscar to me ... not a truck
Then again - I must say that caravans in Europe are not Airstream-sized
Greetings Frans
Old 09-04-2007, 03:48 PM
Blk 76 Blk 76 is offline
Default Hitch for TA
I have a hitch on my 76 TA and have used it a few times and it worked out good. I have pulled a mid size utility trailer and also pulled a car dolley with a mid size car with no problems. The hitch on my car mounts under the car in 4 places 2 are close together right behind the safety chain eyelets and the other 2 are at the end of a long bar that goes behind the bumper and mounts on the right and left sides of the car. My hitch is a Draw-Tight Gross WT 2000 LBS and tongue WT 200 LBS
Old 09-06-2007, 02:00 PM
frans455's Avatar
I found the pics of the tow hitch I sold; here they are:
Greetings Frans
