Old 11-29-2008, 10:21 PM
Super Chicken Super Chicken is offline
Default Where to find a radiator?
I need a new radiator for my 65 Tempest with the 326 (auto w/ a/c)
I have been unable to find them anywhere for less than ~$400!!!!
Any idea how to do this for less? I do not need an exact replacement, but something that is close would be great.
Old 11-29-2008, 10:40 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
i meausred my radiator, went on summitracing.com and bought an aluminum universal with with same dimension (actually 2 inches wider) and works perfectly. look into a universal with similar dimension.
mine was made by Afco, just in case you were wondering.
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 12-14-2008, 02:15 PM
gtojc's Avatar
gtojc gtojc is offline
I have a 17.5" (measure core between tanks) 4 pass Desert Cooler with oil cooler taps. $110, very good condition
Old 12-14-2008, 10:49 PM
Dammit! I just got a universal, well not universal, for just over $200. I found a 65 Chevelle is almost the same size so I bought a cheap aluminum one off of E-gay
Not quite as tall so I will have to make some brackets to hold it up a little, also the bottom hose touches the radiator support frame so it needs to move up a touch anyway. The stock fan will interfere with the new upper hose location so I will be installing an electric fan and doing away with the mechanical one.
Old 12-23-2008, 05:59 PM
67blackcherry's Avatar
67blackcherry 67blackcherry is offline
Location: The conservative enclave in a land of liberals; South Orange County, CA
eGay!!!
Make sure the top hose isn't higher than the radiator cap...read the thread "Is your car running hot? Read this!" in this section...
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house...
Old 12-29-2008, 02:08 AM
pont406's Avatar
pont406 pont406 is offline
Thumbs up
The Griffin universal fit radiators sold by Summit or Jegs, 26x19 part# GRI -1-252222-X, $195.95 is a better unit,for your car, than what you just bought, will drop right in the factory bottom mounts, (no lower hose clearance issues), upper hose is on the drivers side, just fab a different top mount setup, and your ready to go. fits great! but if you run an auto transmission you'll have to run an external trans cooler setup. but most "universal" rads don't have the cooler option anyways.
Old 12-29-2008, 08:35 PM
The radiator I bought does have the AT cooler lines and it works great. It would have been nice to have had a better fit, but what I have now seems to work. All I lack is a decent top bracket because I didn't move the radiator up rather I modified the lower radiator support (hammer, puch, chisel..I see how you fix!) to clear the hose. I still need to buy the fan or fans depending on what size I get. For now the stock fan does the trick sans shroud, till summer comes anyway....
Old 12-31-2008, 08:36 AM
chrisp chrisp is offline
Default 64 gto w/66 tripower radiator
What would be a good fit for a 64 gto w/ a 66 tripower ? My 64 is a real tripower 4speed with the deeper radiator support , both the upper and lower hoses are on the passenger side . Thank you
Old 12-31-2008, 09:42 AM
How much $$$ do you want to spend? Aluminum universal fit radiators start at around $200, and that Alumitech piece I got ran $600...
Old 01-02-2009, 01:24 PM
gtojc's Avatar
Default Radiators
I have a 4 pass DC 17.5" for man or auto ( has oil cooler) $110 plus freight. Very good condition.
ID:	153226   Click image for larger version
ID:	153227   Click image for larger version
ID:	153228   Click image for larger version
Old 01-02-2009, 02:19 PM
That's a very good deal...where were you last year when I decided to spend way too much for my radiator???
