Old 02-28-2009, 09:55 PM
goatheaven goatheaven is offline
Default Rally II 15x7 rims
Can I put wide 50's tires on Rally II 15x7 rims??
If so what tire size would you suggest?
Thanks in Advance
Old 02-28-2009, 11:03 PM
AGTO8U's Avatar
AGTO8U AGTO8U is offline
I've seen 295-50's radials on 7" rallyIIs. Probably a little wide though, 275's would fit better.
Old 02-28-2009, 11:07 PM
guccieng's Avatar
guccieng guccieng is offline
people do it all the time, but anything wider than a 235 on a 7 inch wide rim looks silly and isn't recommended by any tire company.
John J.
Old 02-28-2009, 11:24 PM
marauder's Avatar
marauder marauder is offline
I'm not sure anything wider than 235s looks silly. I've used 245s a number of times and thought they looked fine.
I have 295s on 8" wheels that look decent in my opinion but I know that they would be better on 10" wheels...
Curt
'69 GTO Ragtop, 455, RA, KRE SD Perf ported heads and "old Faithful" cam, Sean Murphy Q-Jet, Tremec 5spd, Moser Trutrac 3:73, Hotchkiss, Speedtech, Wilwood
'64 Lemans Convertible, Tremec TKO600
Old 03-01-2009, 12:03 AM
guccieng's Avatar
i admit, there's not much difference in a 245 and 235, but it starts to look like 'balloons' to me, depending on the sidewall, of course. you're not really gaining much tread and the handling is worse with the 245's on a 7 inch rim with all of the extra lateral movement.
John J.
Old 03-01-2009, 12:30 AM
thanks for all the response,
I'm buying tires in a few days.
What brand do you guys suggest? that are reasonable
if I go with 245/50/15's in the rear
what would be best for front
going on 68 goat
Old 03-01-2009, 02:55 AM
guccieng's Avatar
firestone firehawk indy 500's are great rubber. i've never heard anything but praise for them. not that expensive, either.
John J.
Old 03-01-2009, 03:16 AM
Danimal's Avatar
Danimal Danimal is offline
a 245/50/15 tire is going to MUCH shorter that the original tires. I realize that this may be what you searching for, however this might be extreme and you may have ground clearance issues or you might not be satified with the way that size fills out the wheel wells.
You might want to search for some images of the look/stance you're looking to acheive and we'll be happy to offer some additional suggestions.
At the very least, I'd check with the tire place mounting them to only "test fit" one on your car and see what you think before all 4 are on there and you're not satisfied, but stuck with them.
$.02
Dan
Austin, Texas
Antique Gold 1969 Pontiac GTO YS400/TH400 3:23 10-bolt
2009 Pontiac G8 GT Maverick silver/Black Interior
1997 Chevrolet S-10
Old 03-01-2009, 04:46 AM
mash mash is offline
235/60/15 on rear and 215/65/15 on front all 7" rimsClick image for larger version
Old 03-01-2009, 09:54 AM
ericwy's Avatar
ericwy ericwy is offline
Here's my TA with Indy's 255 60 R15 on Rally IIs, best tire for the street I have ever put
on this car. fwiw, i hv used GY-GT, GY-GTII, GY-SP, BFG, etc..
1977 TA 400 9.5:1 CR 351hp 414LbFt, #13 Heads + 1.52 Roller rockers, 1968 Pontiac 400 intake, Holley 4165 650 DP #7054
Howards Hyd .447/.467 IN:288 EX:298 214/[email protected], MSD6A + MSD timing control + H2o/Meth
1-5/8" headers, Magnaflow 200CPI Cats + 2.5" Pypes X, Dynomax STs, TH-700R4 2200 stall, 3.42 Eaton 10-bolt, PS/PB/PW/PL/AC/Cruise
[email protected] 2.18 60' on P255-60-R15 radials, pump gas, mpg : 21.5 hwy 15.2 city
Old 03-01-2009, 01:15 PM
marauder's Avatar
When I purchased my car it had 235/60x15s all around. I later wanted a little more rubber in the rear and went with the 295/50x15s. These are 15x8x4.5 Rally II repros in the pics and all with the 235s.
She's wearing 285/40x17s rear and 245/45x17s front now on 10" and 8" wheels respectively.
Name:	Driver Rear-1.jpg
ID:	159893   Click image for larger version
Name:	Drivers Front1-1.jpg
ID:	159894   Click image for larger version
Name:	Drivers Rear1.jpg
Curt
Old 03-01-2009, 03:46 PM
1971/455/HO/4-SPD's Avatar
1971/455/HO/4-SPD 1971/455/HO/4-SPD is offline
I used Firestone Firehawk 245x60x15's on my 7's and they look great!!!
Old 03-01-2009, 04:26 PM
chipster's Avatar
chipster chipster is offline
BFG's website says 255-60-15s are OK on a 7" rim. They are also 26.8 inches in diameter, which is the same as the G70-14s that your car came with.
for the front, 215-70-15s are 26.9" in diameter, probably as close as you can get to original size.
Old 03-01-2009, 09:55 PM
OLDFLM72's Avatar
OLDFLM72 OLDFLM72 is offline
Default Wider
I'm running 255/60/15s front and 275/60/15s rear on my 71 Firebird on 15x7 Rally IIs with no problems fwiw.
US Air Force Retired
"FREEDOMBIRD"
