Old 04-05-2009, 12:14 AM
turbo69bird's Avatar
Default 67 thru 69 bird build sheet locations
Post where you have found them.
It would be interesting to figure out where the most to least common locations would have been.
960 HP @ 11 psi, 9.70 at 146.
Old 04-05-2009, 01:47 AM
68birdragtop 68birdragtop is offline
Found the build sheets for all three of my firebirds under the front buckets. Bought a seat of front buckets and found a build sheet there as well.
Old 04-05-2009, 07:53 AM
nashcar nashcar is offline
Found mine under the rear seat.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 04-05-2009, 08:25 AM
amcmike's Avatar
amcmike amcmike is offline
Under rear seat
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 04-05-2009, 10:29 AM
Cammer-6 Cammer-6 is offline
inside the lower rear seat springs
under front seat carpet
inside front seat spring
under rear carpet partly on top of the hump
remember theres a body broadcast and a build sheet.
Old 04-05-2009, 12:36 PM
What's the difference between them?
69 Z 302 M21 3.73
69 FB 400
Old 04-05-2009, 08:28 PM
elevatorman51's Avatar
elevatorman51 elevatorman51 is offline
My 67 had a nice copy under the springs of the rear seat and remnants of the same copy under the front seat between the pass front bolt of seat bracket under carpet.
69 GTO
67 Firebird 400
Old 04-05-2009, 09:51 PM
One was Fisher Coachworks the other was PMD
Old 04-05-2009, 10:27 PM
RA1John RA1John is offline
Under rear seat, in rear seat cushion, in rear seat back cushion, under RH front seat, under carpet (front- RH), under rear sound deadner (RH), RH front seat between frame & bracket.
Most of sheets found will be the BODY BROADCAST COPY.
Very rare to find the CHASSIS BROADCAST COPY (especially on 67-68).
BODY B/C: Used by Fisher Body
CHASSIS B/C: Used in Final Assy (Chassis related operations)
Even more rare than these two sheets is an inspection sheet (have only seen one).
Also have found sheets from vehicles built before/after subject vehicle.
Also have found partial sheets and blank sheets.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
The Following User Says Thank You to RA1John For This Useful Post:
Old 04-06-2009, 12:37 PM
jcruz's Avatar
jcruz jcruz is offline
I found mine on the top of the gas tank. 69 built in Lordstown.
69 Firebird/TA clone
Old 04-06-2009, 02:46 PM
Mark1968 Mark1968 is offline
Found mine under the rear seat, tucked up in the springs.
Old 04-06-2009, 05:30 PM
Keith Seymore's Avatar
John - those inspection sheets (with the punches in them) were legal documents (that is, had specific record retention requirements) and were not supposed to get out.
That's probably why you've seen only the one.
K
'63 LeMans Convertible
'63 Grand Prix
Old 04-07-2009, 08:09 PM
When you say in rear seat cushion,Do you mean in the springs or actually inside the cover and hog rings?
I have also seen them behind the seat backs in the front seat. Never under the covers though has anyone else seen them under the covers and inside the seat?
Old 04-08-2009, 02:24 PM
boater bill's Avatar
boater bill boater bill is offline
I found both of mine under the rear seat bottom between the springs and the burlap.
Old 04-08-2009, 09:20 PM
4dblnkldude's Avatar
One in rear seat springs, one under front carpet, and one behind driver set back.
Old 04-10-2009, 01:03 AM
Kurt S Kurt S is offline
John,
Fisher used the UOIT (Uniform Option Information Tag). Those are rare to find.
The body sheet followed the body, chassis sheet was used in the engine dress and chassis areas. Neither were used by Fisher. http://www.camaros.org/assemblyprocess.shtml#chev (updated with new pics).
I don't think the inspection sheets were legal documents. They documented the buy-off of the car by the various dept's and helped keep track of necessary repairs.
JohnZ will know for sure.
Kurt S
CRG - Camaro Research Group
The Following User Says Thank You to Kurt S For This Useful Post:
Old 04-10-2009, 12:28 PM
Bjorn's Avatar
Bjorn Bjorn is offline
I have been in all locations mentioned above and never found anything...but my car has been apart a few times and "restored" by a prev owner to the one before me ,so, probably gotten tossed out somewhere along the way...
FireBjorn
http://FirstGenFirebird.org/show/closeup.mv?CarID=221
breathe and enjoy it , life is temporary
69 Firebird convertible
71 Triumph TR6
Old 04-10-2009, 01:46 PM
or it simply evaporated..
have a few that not much is left,you can tell age and weather has taken its toll.
Old 04-10-2009, 01:51 PM
Found a few of those,its neat to see the options spelled out with X's
Old 04-11-2009, 10:42 PM
Really? I'd be interested to see any UOIT's. They are pretty uncommon in Camaros.
Heck, I'd like to see any broadcast sheets anyone would like to send my way. I've been working on the broadcast sheets for years and comparing to Firebird sheets would help.
Thanks!
Kurt - [email protected]
Kurt S
