Old 01-22-2010, 12:06 AM
Blue '66's Avatar
Blue '66 Blue '66 is offline
Default Taurus electric fan on a '66 GTO?
I am not there yet but I am looking at OEM fans and it looks like the Taurus fan looks like is one that seems to fit well.I was hoping some of you would have some info and some pics of of the setup?Is there a another fan(s) that fits the '64-'67 top/bottom tank radiator?
Thanks!
Eric
Old 01-22-2010, 04:41 PM
70GS455 70GS455 is offline
It's a good fan, moves alot of air. Make sure you have enough current to run it. It is kinda thick at the motor, however, don't know if the 64-67 has enough space between the water pump and rad. But the platsic shroud can be easily trimmed.
Old 01-22-2010, 05:09 PM
Blue '66's Avatar
I was planning to use a higher rated oem alt like a '84 camaro.I didn't know the fan was that thick,thats why I was hoping for pictures.
Old 01-25-2010, 10:45 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Thumbs up Fan
No crap about the zip ties!!! I haven't installed the bracket that I made.
Fan Controller is from Hollister. Will work for Ford Taurus fans and the Mark VIII. They are great!! They have them in stock and ship the next day. Another guy makes something similar but does take awhile. I had a bad temp sender after a week. Called them, they sent another one out for free. Got it in 2 days.
http://www.thehollisterroadcompany.com/default.html
http://cgi.ebay.com/ebaymotors/Tauru...item1c0fb3366d
This fan the the Mark VIII. The fan can also be removed from Ford Thunderbirds. I have 2 spares. The last one I got out of the Junk yard for 20$. It is a 2 speed. In the winter it runs the car too cold on low. In the Summer she runs at 170* on low. On high the thermostat closes. The fan MOVES air. As you can see it is so close to the radiator, that it is very efficient.
I have a 1000CCA battery and a Summit 100 Amp alt.
HTH,
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 02-01-2010, 11:32 PM
stobin's Avatar
stobin stobin is offline
Default TAURUS FAN
Blue 66: I am running a 2-speed Taurus fan on my Grand Am. It was a junkyard find as well for $20. I have had great results with the set up. Just make sure that you run at least a 10 or 8 gauge wire from the motor. I am using the low speed circuit as the primary, and have the high speed set up to a switch if needed. These fans pull a large amount of current on start-up. I am running each speed with it's own 75 amp relay. Overkill, but safe. A lot of people report melted wires and blown fuses with these fans mainly due to the fact that they are trying to cheap out on the parts. Solder all the connections as well. I was even able to fit the fan inside my factory shroud without trimming the Taurus shroud. I am running a basic $40 Hypertech temp sensor 200/185, nothing exotic is needed. Works great.
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme.
Old 02-02-2010, 12:06 AM
dracowizard's Avatar
dracowizard dracowizard is offline
Default How Coooooooool
Are there any particuliar years for the Taurus Fan that is good to hunt for? Meanwhile i'll check the links to ebay and also for the hollister and hypertech pieces. This looks as though this could be a good choice for my 65project.
Gotta Luv some old Muscle..
64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror
3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna
Silvermist w/BlackVinyl Top
http://s161.photobucket.com/albums/t201/dracowizard/65/
Old 02-02-2010, 04:52 AM
drailed drailed is offline
Not sure on the Taurus but have read a few places that the 98 Mark VIII fans put out the most cfm. I would imagine the earlier ones would be plenty sufficient also. Somewhere in the range of 4500 cfm.
Old 02-02-2010, 09:57 AM
I know that it isn't original and all, but when you trim the Mark VIII fan, it pulls soo much air on low. If you have a good tune on the motor, you will almost never turn it to high.
I was at a car show last year parked next to a judge with a clutch fan. His car was rock solid 190*. It was hot and humid and his car never budged. I asked him what he did to the motor and he said that it was all original.
Mine was at 170* with the fan cycling on and off on low. The sensor I have now turns it on at 195*. A little high, but is ok for cleaning out the carbon etc...
If I turn it on high it runs too cold in the winter. The 160* t-stat closes and the heat goes away.
HTH,
Dave
The Burb Files
Old 02-24-2010, 02:56 AM
lust4speed's Avatar
I used the Taurus fan and have the thermostat wired through the low speed circuit - which is all it needs.
One warning is that either low or high speed can be chosen, but not both together so you have to wire accordingly. I used a on-off-on toggle switch with the bottom setting run to the fan thermostat switch which controlled one set of dual relays; and the top on setting went to another set of dual relays that allowed the fan to run on high. I haven't had the need to take it off the low speed automatic setting.
I didn't have to do any trimming on the Taurus shroud.
Name:	Electric fan installation.jpg
Mick Batson
Old 02-24-2010, 09:42 AM
Blue '66's Avatar
Thanks for the reply!How did you attach the fan to the radiator?Is the fan loud on low?
Old 02-24-2010, 10:15 AM
Default Loud?
Mark VIII fan on low, not that loud. With it on high I can hear it only because the hood is off right now.
You will not hear it at all compared to a mechanical fan.
The Burb Files
Old 02-24-2010, 08:33 PM
lust4speed's Avatar
My Taurus fan is louder than it should be because I managed to pick one that came off a very high mileage car. I think the best response to noise is that these Mark VIII's were on high end Lincolns, and I don't remember hearing the fan on any Taurus I was around either.
I have always stayed away from the nylon ties that go through the radiator fins. I just used allen head cap bolts securing the top of the shroud to the top of the aluminum radiator. On the bottom I just used an aluminum bracket from the bottom of the core support to the bottom of the shroud (which can be seen on my first photo). I guess I did do some trimming for the shroud to clear the radiator top bracket and also to trim it down equal to the top of the radiator. If you were using a stock radiator then you could probably secure the shroud on the sides or run an additional strap across the top to have something to bolt to.
Name:	Shroud closeup.jpg
Mick Batson
Old 02-24-2010, 08:49 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Use a 4th gen V8 F-body fan/shroud. It fits the 66-67 core area perfectly (at least for the A/C cars) and it has two fans, which gives more clearance for the water pump pulley.
Old 02-24-2010, 10:09 PM
Default Zip ties are awesome!!!
Good point about the nylon ties that go through the rad. I have a Griffen rad and on the Mark VIII fans there are no provisions for the allen head way.
One of the draw backs. I have an upper support, but it is for the rad to the frame.
Dave
The Burb Files
Old 02-24-2010, 10:12 PM
Blue '66's Avatar
Do you have a pic of your set -up?
Lust4speed:How much room do you have between the fan pulley and fan motor?
Old 02-25-2010, 12:05 AM
hgerhardt's Avatar
Here you go, the pics ain't too good, being at night... but you get the idea. Note that this is a '66 GTO and I have a mid-'70-up long-snout water pump. The original pump would have 1" more clearance. I made brackets from alum angle stock and attached to the fan shroud holes in the core support.
Old 02-25-2010, 05:41 PM
Blue '66's Avatar
Thanks!I'm not dead set on a Taurus fan,I am just looking for a fan that fits the '66 radiator and that looks good.Does the 4th Gen fan have large voltage spikes on startup?Do you use/need the 2nd fan?Are the fan(s)quiet?
Old 02-25-2010, 07:11 PM
imposter's Avatar
imposter imposter is offline
hgerhardt what kind of fan setup is that from
Old 02-26-2010, 02:42 PM
hgerhardt's Avatar
Like I said in my original post, a 4th gen F-body, or '93-2002 Camaro/Firebird V8. The V6's used a single fan setup.
No voltage spikes to speak of. Note that you do need to have a 50+Amp alternator. Also, you need to hook up any electric fan setup through a relay and then to a "fat" wire, like the back of the alternator or the starter solenoid. Don't try to source the power from the factory firewall-mounted fuseblock.
I connected the two fans together in parallel-- they both come on together. You wouldn't want to run them individually because the air would "leak" past the fan that's not running, and you wouldn't get any airflow thru the rad.
These fans are about as quiet as any electric fans-- you can't hear them inside the car, but you can hear them if you're standing in front of the car.
Also, if you have A/C, it is critical that the fans run whenever the compressor is engaged, no matter how cold the engine is. That means you have to add a jumper from the compressor clutch feed to the rad fan relay to override whatever temp switch you're using to control the fans.
Old 02-26-2010, 10:40 PM
Blue '66's Avatar
What size relays are you using and are you using more than 1?Are you using a controler and or toggle switch?Thanks for all the info!
