Old 03-21-2010, 04:17 PM
redonred81 redonred81 is offline
Default best restored snowflakes who...
I would like to buy some 15x7 snowflakes for a 78 showcar.I would like to know from you guys who does the best job in polishing, painting,coating, etc.thanks for the inputs.btw i dont want repros.
Old 03-21-2010, 05:09 PM
2manyT/A'S's Avatar
I don't believe the 15 x 7's are repop'd.
Old 03-21-2010, 10:37 PM
Old Goat Racer's Avatar
www.78ta.com
Everybody knows somthin.
Nobody knows everything !
Old 03-22-2010, 06:32 PM
Ben Ben is offline
I had my done there turned out great. Mine where the 15x8 that where done. If you want pics let me know
The Hub Cap and Wheel Store
2810 S 44th St
Kansas City, KS 66106 Map
(913) 432-0002
Old 03-24-2010, 09:02 PM
Nick623 Nick623 is offline
http://www.78ta.com/store/product.ph...cat=258&page=1
Old 03-24-2010, 10:16 PM
W72-Bandit's Avatar
W72-Bandit W72-Bandit is offline
There are several places that will restore a set for you. I've used wheelsamerica.com many times. Last set I did was $99 a wheel with lifetime warranty. Cuts out the middleman.
'79 SE T/A 400/4spd
'12 ZL1 Camaro
Old 03-25-2010, 05:28 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
This guy usually has some great-looking wheels on ebay. He does a lot of 10th Anniversary T/A and 15x8 snowflakes, but every once in a while I see some 15x7s up for auction.
Mike
Old 03-25-2010, 02:00 PM
462-6spd 462-6spd is offline
If you have an air compressor, access to the polishing compounds, some aircraft paint stripper and some time, why not do them yourself? I did my 15X8's on my '79 TA and they came out real nice.
As already mentioned, WWW.78ta.com has some great directions on how to do it. Look under the restoration tips section, the Snowflake section starts out with a factory type restoration done on a lathe, but further down he outlines the polish technique that I did to mine.
It's not that hard!!
Old 03-25-2010, 06:17 PM
do you guys order them clearcoated or not? I figured if the aluminum isnt protected it will tarnish.thanks for the inputs.
Old 03-25-2010, 06:25 PM
I polished & painted mine about 3-4 years ago, no clear-coat applied. Granted the car is stored indoors and it doesn't get driven in the rain very often, but they still look great.
Gary
Old 03-25-2010, 10:31 PM
2manyT/A'S's Avatar
Most wheel restoration shops will clearcoat those wheels (librally)which IS needed to maintain/protect the unpainted surface,but it makes them look way shinier than the original factory finish.
