Old 02-10-2007, 06:14 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Originally Posted by Apache Warrior
Tom, I am using Hooker Super Comp 2" headers for 68-72 A Body cars.
A little massaging but they fit pretty nicely.......they are a pain to work around however.
Installing the engine the first go around was painful....I learned I should NOT have used header studs, the oil filter housing MUST to go on after the engine is installed and the headers are on, and it's MUCH easier to put the bellhousing on last after everthing else is installed. And then the fun part - I get to install the clutch linkage - VERY tight set up but was nicely fabbed by Kal Schultz.
I don't have any pictures of the headers on with the engine installed. I will get a few of those between the holidays and post them here for everyone to see.
Let me know if you have any more questions.
You Know what #, I may have to go to 2" with my 535. Is it #4201#
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 04-28-2010, 09:53 PM
R 70 Judge's Avatar
So has anyone else had any luck with these 4201 SC headers?
James
1970 Trans Am
Old 04-29-2010, 07:21 AM
spartazoo's Avatar
spartazoo spartazoo is offline
I am pretty sure that is what is on my car. You have to "massage" the passenger side frame rail and grind one little spot on the back of the engine crossmember, other than that they actually fit pretty well.
I will check and see if those are the ones I used.
Kip
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 04-29-2010, 05:02 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Did Apache Warrior ever get the car to the track?
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 04-29-2010, 06:52 PM
afx421's Avatar
afx421 afx421 is offline
is the car tubbed? i dont want to tub mine, if not tubbed, what size is the rear? drum to drum, what size tires wheel back spacing.
1971 ventura 455 12.04 @ 110 w/ crummy 1.69 60 ft - so far!
NHRA super gas licence holder 9.31@145 @ frank hawleys in a 2000 firebird
Old 04-29-2010, 09:35 PM
spartazoo's Avatar
Here is what I did...
I put the car up on jack stands and dropped the rear transaxle out of the car. the first thing I bought was the rims and tires that I wanted to use. I set them under the car in position and then measured the distance between the rims. I gave that dimension to the guys building my rear-end and the rest is history.
Everything lined up great when everything came together during assembly.
Kip
Old 04-29-2010, 11:36 PM
R 70 Judge's Avatar
A '57 Pontiac big car rear is just about the perfect width. I think it's 58" - 59" IIRC. Tom S. has one under his '63 Tempest.
If you want a 9" the Ford 77-81 Granada/Versailles is 58" and from what I've heard here it's pretty close to perfect. Again, it all depends on the wheel width and offset used too.
I have a 28"x12.50" Mickey Thompson ET Street on a 15"x8" Mickey Thompson ET Drag wheel under mine and it's pretty close, but it fits.
James
1970 Trans Am
Old 04-29-2010, 11:38 PM
R 70 Judge's Avatar
Kip
This is the way to do it
James
1970 Trans Am
Old 05-04-2010, 12:17 AM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
Agreed! It is so simple and effective, it's almost like cheating!
This might be a very old thread, but a good one!
Old 05-05-2010, 09:14 PM
beemergary's Avatar
I did like spartazoo. Got 275/50/15s under the 63. Put the tires and wheels under the car with your ride height and do the measuring. Don't forget the thickness of the brake drums also. Ford 9 inch aren't on center so if getting axles made there's two different lenghts. I didn't relize when having axles made you can specify wheel hole pattern. I got tempest front ford back and one spare which only fits the front. Didn't make this mistake when doing the 61 wagon.
Old 05-05-2010, 09:58 PM
spartazoo's Avatar
I had my axles made with 4.5 x 5 bolt pattern to match the front. I also have an extra pair of 15x8 plain steel wheels that the company I ordered from made by mistake. They are just begging for installation on a 63 Catalina SD clone...Born Too Late II? Hummm
Old 05-06-2010, 01:47 PM
grparen grparen is offline
Spartazoo:
My '63 Tempest has 4.5 X 5 up front and 5 X 5 big Pontiac in the rear. However, the 9.5 inch dog dish caps I want to use won't fit on any 5 X 5 wheels. Only 10 1/8 caps fit. Where can I get my axles converted to 4.5 or buy new axles with 4.5 wheel bolt pattern?
BTW, the wheels you had made. They are 4.5 X 5 on 15 X 8? What is the backspace? I may be interested.
Old 05-06-2010, 02:12 PM
Keith Seymore's Avatar
Gary - if you ever get a flat just call me and I'll come gitcha'.
K
'63 LeMans Convertible
'63 Grand Prix
Old 12-22-2010, 07:27 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Default ???
...... so what is the latest on this car ?? ........
