Old 06-23-2010, 08:15 PM
motor29's Avatar
motor29 motor29 is offline
Default Horn won't shut off
I finally connected my new horn relay , when I connect the hot lead the horns sound and won't shut off. I checked the steering wheel horn contacts and nothing is touching. Where should I check ?
"One dog is goin one way , one dog is goin the other, the guy is looking like what do you want from me"
Old 06-23-2010, 10:23 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
Check the horn relay on the firewall inside the engine compartment
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
Old 06-24-2010, 07:10 AM
2002Z4CSS's Avatar
Make sure the circuit from the horn relay to the steering column is not grounded.
1971 Pontiac GT-37
Old 06-24-2010, 12:50 PM
wiring in the column if it's tilt for sure.
May still be that if it's not.
former." --Albert Einstein
- Winston Churchill
Old 06-24-2010, 01:19 PM
motor29's Avatar
I checked the horn contacts so it's not that, all the wiring forward of the firewall is new. I guess I will be pulling the steering wheel next.
Old 06-24-2010, 03:01 PM
2002Z4CSS's Avatar
Unplug the turnsignal switch first and see if the concern goes away. If it does, the short is in the column, if not then the wiring to the relay or the relay.
1971 Pontiac GT-37
Old 06-25-2010, 06:39 PM
motor29's Avatar
Well I decided since I had the steering wheel pulled off I replaced the turn signal switch. I opened up the relay and the inside was shorted out , the wires were burnt. I guess I will be getting a new horn relay. Thanks for the responses.
