Old 11-07-2010, 07:30 PM
Joust's Avatar
Joust Joust is offline
Default convertible top won't go up
I pulled the wires on my motor/compressor and applied 12v directly to it. no movement. just some clicking. Didn't do it for long for fear of burning something out.
Am I correct in thinking that this is a compressor and the cylinders that move the roof are pneumatic?
sounds like my compressor/motor is seized. can they be repaired?
Old 11-07-2010, 08:46 PM
R68GTO's Avatar
R68GTO R68GTO is offline
It's basically a hydraulic system including the lift cylinders. Disconnect the cylinders where the rod end mounts to the top frame and try your mtor/pump again. If the cylinders move up and down, you may have a binding issue with your top frame.
R68GTO
1969 Camaro COPO 427 "RAT'S NEST"
Old 11-07-2010, 09:48 PM
Joust's Avatar
I actually did that and lifted the top.
i didn't try the motor again though. I will do that though.
Old 11-08-2010, 01:27 PM
Joust's Avatar
looks like this pump is seized.
are there any instructions on opening it? its trying to move. I'm sure it just needs to be cleaned inside.
Old 11-10-2010, 06:37 PM
65WJ's Avatar
65WJ 65WJ is offline
iirc there is a small o'ring between the resevoir and the motor. It fails and allows fluid in the windings shorting out the motor. It is easy to remove, 1 connection and 3 grommets. Take the resevoir off and check the o'ring.
They sell remanufactured pumps.
Oh and you can use tranny fluid to fill it back up.
patrick
Old 11-10-2010, 06:48 PM
Joust's Avatar
awesome. I'll give it a shot.
Old 11-11-2010, 12:25 PM
Joust's Avatar
I opened the motor and it all looks good. there was a bit of dirt and flakes of rust that might have been causing my problems. Everything seemed to move freely.
I'll clean it and reassemble.
