Old 02-17-2011, 07:54 PM
Twenty bucks... sounds like a deal to me.
  #82
Old 02-17-2011, 10:05 PM
Originally Posted by 72TAMAN View Post
So with all of this I still don't know what wheels my Trans Am had new hoping that this resto somehow the billsheet will appear
It came with honeycombs.
GM Canada has more detailed records regarding this stuff -- believe them.
All PHS has is the invoice, and since the transmission and wheels were no cost options, they weren't on the invoice. So PHS doesn't know.
As for the recreation window sticker PHS makes...the original window sticker would have listed "Turbo Hydramatic Trans" along with the other options listed down below, but there would have been no charge for it in the far right column. But since PHS records don't tell them which trans it had... they can't get that part of it correct.
  #83
Old 02-18-2011, 02:06 AM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
That what I figure the Trans Am came with(honeycombs) because when I personally talk to George Zapora of GM of Canada he explain that to me, the no cost options and that they reinvoice the car for the canadian dollars which is why they have all the info on the cars.
I also email Jim at PHS several times and he explain to me that because of the no cost they could not tell what options ( wheels or trans) OK that is fine with me I do not have a problem with that. The problem I have with the window sticker is that it clearly mention unless specified that the rally II are standard on the Trans Am ,so that means it came with rally II w/trim rings, but really they do not know what rims came on the Trans am. If PHS does not know what the options are on a car then they have to explain why they can't tell and not say it this or that that the car came with.
Now how many people think that their 72 f-body came with those options the rims rally II or honeycombs and standard or auto trans (no cost options) but really they PHS do not really know what it came with. I was just lucky or unlucky to find out about this because I order the stuff from GM of Canada
ANDRE
1972 TRANS AM , UNDER RESTORATION
http://forums.maxperformanceinc.com/...d.php?t=656067
1972 FIREBIRD FUTUR PROJECT
http://forums.maxperformanceinc.com/...d.php?t=674551
1978 TRANS AM (PARTS CAR) MAYBE
1971 LEMANS T37 (PARTED OUT)
1976 TRANS AM (PARTED OUT)
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #84
Old 02-18-2011, 02:39 AM
72TAMAN's Avatar
That's why I bought them , I couldn't pass up on them not the proper codes but for now it works for me . What is the proper code or date code for my 72 Trans Am ,build date is 09D fourth week of sept 71
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #85
Old 02-18-2011, 08:24 PM
72TAMAN's Avatar
Does anybody have this 72 forms that were filled out in 1971 or in 1972 to see what kind of markings they used to check off the option box , a check mark or "x" or whatever they did in 1972
The 2 example of the forms are the ones PHS supplies with the package I bought . I want to try to duplicate the way they did it in 72 and not just green highlights over a few obvious options like motor, color ,trans ,etc that PHS does
ID:	235189   Click image for larger version
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #86
Old 02-19-2011, 02:24 AM
72TAMAN's Avatar
August 2010
restore the left side L bracket for the front rad support and nose
Name:	1972 TRANS AM #435 21 APRIL 2010 L BRACKET FOR RAD SOPPORT LEFT ONE OUTSIDE VIEW.jpg
ID:	235201   Click image for larger version
Name:	1972TRANS AM #434 21 APRIL 2010 L BRACKET RAD SOPPORT LEFT ONE INSIDE VIEW.jpg
ID:	235203   Click image for larger version
Name:	1972 TRANS AM #436A  2 AUG 2010 L BRACKET OFR RAD SUPPORT LEFT ONE INSIDE VIEW SANDBLASTED.jpg
ID:	235204   Click image for larger version
Name:	1972 TRANS AM #437 2 AUG 2010 l BRACKET FOR RAD SUPPORT LEFT ONE INSIDE VIEW  PAINTED  VHT PAINT.jpg
ID:	235205   Click image for larger version
Name:	1972 TRANS AM #438 2 AUG 2010  L BRACKET FOR RAD SUPPORT LEFT ONE OUTSIDE VIEW  PAINTED VHT SATI.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #87
Old 02-19-2011, 02:34 AM
72TAMAN's Avatar
August 2010
restore the right side L bracket for rad support and nose
Name:	1972 TRANS AM #439 21 APRIL 2010  L BRACKET FOR RAD SUPPORT  RIGHT ONE OUTSIDE VIEW.jpg
ID:	235207   Click image for larger version
Name:	1972 TRANS AM #440 21 APRIL 2010  L BRACKET FOR RAD SUPPORT RIGHT  ONE INSIDE VIEW.jpg
ID:	235208   Click image for larger version
Name:	1972 TRANS AM #441 2 AUG 2010 L BRACKET FOR RAD SUPPORT RIGHT ONE OUTSIDE VIEW  SANDBLASTED.jpg
ID:	235209   Click image for larger version
Name:	1972 TRANS AM #443 2 AUG 2010  L BRACKETFOR RAD SUPPORT RIGHT ONE OUTSIDE VIEW  PAINTED VHT SATI.jpg
ID:	235210   Click image for larger version
Name:	1972 TRANS AM #444 2 AUG 2010 L BRACKET FOR RAD SUPPORT RIGHT ONE INSIDE VIEW PAINTED VHT SATIN .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #88
Old 02-19-2011, 02:48 AM
72TAMAN's Avatar
August 2010
restore the two rad support rubber mount
Name:	1972 TRANS AM #445 2 AUG 2010 FENDER RAD  SUPPORT RUBBER MOUNT BUSHING SANDBLASTED          RIGH.jpg
ID:	235212   Click image for larger version
Name:	1972 TRANS AM #446 2 AUG 2010 FENDER   RAD SUPPORT RUBBER MOUNT BUSHING    SANDBLASTED       PAR.jpg
ID:	235213   Click image for larger version
Name:	1972 TRANS AM #447 2 AUG 2010   FENDER  RAD  SUPPORT RUBBER MOUNT BUSHING SANDBLASTED      LEFT .jpg
ID:	235214   Click image for larger version
Name:	1972 TRANS AM #448 2 AUG 2010  FENDER  RAD SUPPORT RUBBER MOUNT BUSHING    SANDBLASTED       PAR.jpg
ID:	235215   Click image for larger version
Name:	1972 TRANS AM #450 2 AUG 2010  FENDER  RAD RUBBER MOUNT       BUSHINGS             PAINTED  VHT .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #89
Old 02-21-2011, 01:22 AM
72TAMAN's Avatar
Summer 2010
Picture #379a two rear spoiler end caps
Picture #384 left side rear spoiler end cap with hand written date 1-14-1
Picture #385 rear spoiler
Picture #387 rear spoiler with hand written date 8-20-1
Picture #389 rear spoiler with hand written date and part of the original blue stripe still
showing
PS what do you guys do to preserve those markings.
Name:	1972 TRANS AM #379A  21 APRIL 2010  REAR SPOILER END CAPS  BACK VIEW.jpg
ID:	235423   Click image for larger version
Name:	1972 TRANS AM #384 21 APRIL 2010 HAND WRITTEN DATE UNDER LEFT SIDE SPOILER END CAP  1-14-1.jpg
ID:	235424   Click image for larger version
Name:	1972 TRANS AM #385 21 APRIL 2010 REAR SPOILER FRONT VIEW.jpg
ID:	235425   Click image for larger version
Name:	1972 TRANS AM #387 21 APRIL 2010 REAR SPOILER UNDERSIDE VIEW HAND WRITTEN DATE  8-20-1.jpg
ID:	235426   Click image for larger version
Name:	1972 TRANS AM #389 21 APRIL 2010 FAR VIEW OF UNDER REAR SPOILER WITH HAND WRITTEN DATE 8-20-1  A.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #90
Old 02-21-2011, 01:43 AM
72TAMAN's Avatar
Mid summer 2010
1972 Trans Am battery tray. I sandblasted the tray primed it and painted it to try to preserve it has long has possible . I will not used that tray on the Trans Am .I will replace it with a repro or a good used one .
Name:	1972 TRANS AM #403 21 APRIL 2010 72 TA BATTERY TRAY TOP VIEW.jpg
ID:	235429   Click image for larger version
Name:	1972 TRANS AM #413 31 JULY 2010 72 TA BATTERY TRAY PRIMED TOP VIEW.jpg
ID:	235430   Click image for larger version
Name:	1972 TRANS AM #414 31 JULY 2010 72 TA BATTERY TRAY PRIMED BOTTOM VIEW.jpg
ID:	235431   Click image for larger version
Name:	1972 TRANS AM #415 1 AUG 2010  72 TA BATTERY TRAY PAINTED  DUPONT A-5099S  BUMPER & TRIM SATIN B.jpg
ID:	235432   Click image for larger version
Name:	1972 TRANS AM #416 1 AUG 2010 72 BATTERY TRAY PAINTED DUPONT A-5099S BUMPER & TRIM SATIN BLACK  .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #91
Old 02-21-2011, 02:29 AM
72TAMAN's Avatar
Summer of 2010
Restore original master cylinder ( paint wise) but did not rebuild it yet
Name:	1972 TRANS AM #462 21 APRIL 2010 72 TA MASTER CYLINDER LEFT SIDE VIEW.jpg
ID:	235434   Click image for larger version
Name:	1972 TRANS AM #465 7 AUG 2010  72 TA SANDBLASTED MASTER CYLINDER RIGHT SIDE VIEW.jpg
ID:	235435   Click image for larger version
Name:	1972 TRANS AM #469D 11 DEC 2010 MASTER CYLINDER UNDERSIDE VIEW        PAINTED DUPLI-COLOR CAST C.jpg
ID:	235436   Click image for larger version
Name:	1972 TRANS AM #467 8 AUG 2010 72 TA PRIMED MASTER CYLINDER UNDERSIDE VIEW PART # 5470409-1  1.8 .jpg
ID:	235437   Click image for larger version
Name:	197 TRANS AM #469B 11 DEC 2010  MASTER CYLINDER PAINTED DUPLI-COLOR CAST COAT IRON         #CDE1.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #92
Old 02-21-2011, 11:30 PM
tajohn tajohn is offline
My ears perked up when I saw that you had a 9D T/A. My '72 was built 70 units after your car.
I have a Blue/blue auto car. Mine came with the KR Rallys.
  #93
Old 02-24-2011, 07:50 PM
72TAMAN's Avatar
Yours ears are going to perk up even more. Bossbirdta 1972 Trans Am is a 09D TA also and his was build about 30+ cars before mine ,maybe build on the same date . Maybe all three Trans Am were build on the same day? Amazing that after almost 40 years that we could talk or email guys that have the same cars and that were build probably the same day. Blows my freaking mind
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #94
Old 02-25-2011, 02:53 PM
72TAMAN's Avatar
Summer 2010
Restore the master cylinder cap ,I know it not the right color but this is the original cap and at one point I'll get it done the proper color
Name:	1972 TRANS AM #472 21 APRIL 2010 MASTER CYLINDER COVER TOP VIEW.jpg
ID:	235847   Click image for larger version
Name:	1972 TRANS AM #473 21 APRIL 2010 MASTER CYLINDER COVER BOTTOM VIEW.jpg
ID:	235849   Click image for larger version
Name:	1972 TRANS AM #474 31 JULY 2010 PRIMED MASTER CYLINDER COVER TOP VIEW.jpg
ID:	235855   Click image for larger version
Name:	1972 TRANS AM #478 1 AUG 2010 MASTER CYLINDER COVER PAINTED CAST COAT IRON   #CDE 1651 TOP VIEW.jpg
ID:	235856   Click image for larger version
Name:	1972 TRANS AM #479 1 AUG 2010 MASTER CYLINDER COVER PAINTED CAST COAT IRON   #CDE 1651 BOTTOM VI.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #95
Old 02-25-2011, 03:11 PM
72TAMAN's Avatar
Summer 2010
Restore left hood hinge w/spring
Name:	1972 TRANS AM #645 22 MAY 2010 LEFT SIDE HOOD HINGE OUTSIDE VIEW.jpg
ID:	235858   Click image for larger version
Name:	1972 TRANS AM #646 22 MAY 2010 LEFT SIDE HOOD HINGE INSIDE VIEW.jpg
ID:	235859   Click image for larger version
Name:	1972 TRANS AM #647 3 AUG 2010 LEFT SIDE HOOD HINGE OUTSIDE VIEW PRIMED.jpg
ID:	235860   Click image for larger version
Name:	1972 TRANS AM #649 7 AUG 2010 LEFT SIDE HOOD HINGE OUTSIDE VIEW PAINTED DUPONT SATIN BLACK #A-50.jpg
ID:	235861   Click image for larger version
Name:	1972 TRANS AM #650 7 AUG 2010 LEFT SIDE HOOD HINGE INSIDE VIEW PAINTED DUPONT SATIN BLACK #A-509.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #96
Old 02-25-2011, 03:24 PM
72TAMAN's Avatar
Summer 2010
Restore right side hood hinge w/spring
Name:	1972 TRANS AM #651 22 MAY 2010 RIGHT SIDE HOOD HINGE OUTSIDE VIEW.jpg
ID:	235869   Click image for larger version
Name:	1972 TRANS AM #652 22 MAY 2010 RIGHT SIDE HOOD HINGE INSIDE VIEW.jpg
ID:	235870   Click image for larger version
Name:	1972 TRANS AM #654 3 AUG 2010 RIGHT SIDE HOOD HINGE INSIDE VIEW PRIMED.jpg
ID:	235871   Click image for larger version
Name:	1972 TRANS AM #655 7 AUG 2010 RIGHT SIDE HOOD HINGE OUTSIDE VIEW PAINTED DUPONT SATIN BLACK #A-5.jpg
ID:	235872   Click image for larger version
Name:	1972 TRANS AM #656 7 AUG 2010 RIGHT SIDE HOOD HINGE INSIDE VIEW PAINTED DUPONT SATIN BLACK #A-50.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #97
Old 02-26-2011, 10:39 AM
72TAMAN's Avatar
Summer of 2010
Restore alternator bracket
Name:	1972 TRANS AM #759 24 MAY 2010 76 ALTERNATOR BRACKET WILL BE ON 72 TRANS AM FRONT VIEW.jpg
ID:	235931   Click image for larger version
Name:	1972 TRANS AM #764 31 JULY 2010 76 ALT BRACKET PRIMED BLACK FRONT VIEW.jpg
ID:	235932   Click image for larger version
Name:	1972 TRANS AM #767 1 AUG 2010 76 ALT BRACKET PAINTED SATIN BLACK VHT PAINT  #CSP671 FRONT VIEW.jpg
ID:	235934   Click image for larger version
Name:	1972 TRANS AM #768 1 AUG 2010 76 ALT BRACKET PAINTED SATIN BLACK VHT PAINT #CSP671 REAR VIEW.jpg
ID:	235935   Click image for larger version
Name:	1972 TRANS AM #769 1 AUG 2010 76 ALT BRACKET PAINTED SATIN BLACK  VHT PAINT #CSP671 PART #499749.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #98
Old 02-26-2011, 10:58 AM
72TAMAN's Avatar
Summer of 2010
Restored AC bracket
Name:	1972 TRANS AM #770 7 AUG 2010  76 TOP FRONT  AC BRACKET SANDBLASTED TOP VIEW.jpg
ID:	235937   Click image for larger version
Name:	1972 TRANS AM #773 8 AUG 2010 76 FRONT TOP AC BRACKET PRIMED TOP VIEW.jpg
ID:	235938   Click image for larger version
Name:	1972 TRANS AM #774 8 AUG 2010 76 FRONT TOP AC BRACKET PRIMED UNDERSIDE VIEW.jpg
ID:	235939   Click image for larger version
Name:	1972 TRANS AM #775B 11 DEC 2010 76 TOP AC BRACKET PAINTED SATIN BLACK   VHT PAINT      #CSP671  .jpg
ID:	235940   Click image for larger version
Name:	1972 TRANS AM #775C 11 DEC 2010 76 TOP AC BRACKET PAINTED   SATIN BLACK  VHT PAINT #CSP671 VIEW .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #99
Old 02-27-2011, 03:21 PM
72TAMAN's Avatar
Summer of 2010
Restored the Y bracket for AC
Name:	1972 TRANS AM #776 24MAY 2010 76  Y AC BRACKET TOP VIEW.jpg
ID:	236033   Click image for larger version
Name:	1972 TRANS AM #777 24 MAY 2010 76 Y AC BRACKET UNDERSIDE VIEW.jpg
ID:	236035   Click image for larger version
Name:	1972 TRANS AM #779 31 JULY 2010 76 Y AC BRACKET UNDERSIDE VIEW SANDBLASTED.jpg
ID:	236042   Click image for larger version
Name:	1972 TRANS AM #780  1 AUG 2010 76 Y AC BRACKET TOP VIEW PAINTED  VHT PAINT  SATIN BLACK #CSP671.jpg
ID:	236043   Click image for larger version
Name:	1972 TRANS AM #781 1 AUG 2010 76 Y AC BRACKET UNDERSIDE VIEW PAINTED SATIN BLACK WITH VHT PAINT .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #100
Old 02-27-2011, 04:58 PM
72TAMAN's Avatar
Summer of 2010
Restored 400 motor crank pulley w/pulley plate
Name:	1972 TRANS AM #807 31 JULY 2010 400 MOTOR  CRANK PULLEY SANDBLASTED FRONT VIEW.jpg
ID:	236053   Click image for larger version
Name:	1972 TRANS AM #809 31 JULY 2010 400 MOTOR  CRANK PULLEY PLATE PART #9790845 SANDBLASTED.jpg
ID:	236054   Click image for larger version
Name:	1972 TRANS AM #811 31 JULY 2010 400 MOTOR CRANK PULLEY            PRIMED        FRONT VIEW.jpg
ID:	236055   Click image for larger version
Name:	1972TRANS AM #815 1 AUG 2010 400 MOTOR CRANK PULLEY  PAINTED SATIN BLACK  VHT PAINT #CSP671 FRON.jpg
ID:	236056   Click image for larger version
Name:	1972 TRANS AM #817 1 AUG 2010 400 MOTOR CRANK PULLEY PLATE  PART #9790845 PAINTED SATIN BLACK   .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
