Old 10-14-2010, 08:29 PM
DOC DOC is offline
Default What to do with old antifreeze?
I used to let it just go down my driveway but now have this gut feeling I shouldnt be doing that. I called the local parts stores who take my oil and nobody takes it. Local shop has a company come get it out of big drums and will not let anyone dump thiers in w/ thiers. Short of calling the local HAZMAT office for the county, Any other ideas?
Old 10-14-2010, 09:19 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
I thought that if it was diluted it was harmless to animals and environment. If so run a hose into container till gone/clear,,,not that I would do that
Leo
Old 10-14-2010, 09:51 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
Why not call the hazmat office? They should be able to tell you what is suppose to be done with it. Just do not tell you spilled any.......
Some places you can poor it down the drain, but I am not sure what the limitation are in your area.
I built it one piece at a time and it cost me more than a dime.
Old 10-14-2010, 10:58 PM
Engine-Ear's Avatar
Hey, most mobil/service stations take it as does your local city salvage. Worst case you can put your used drain-fluids into containers and set it by your local service station after they close.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 10-15-2010, 01:41 AM
elefantrider's Avatar
elefantrider elefantrider is offline
That stuff is nasty. I try not to use it. Prefer redline water treatment instead.. at least it LOOKS less nasty. I think there is biodegradable antifreeze out now. In anycase, I try to reuse it when possible. Most of that stuff doesn't break down like oil and is good for 5-10 years.
Old 10-15-2010, 09:47 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Default Anti-Freeze?
What I do for all of my USED oils and freezes..
The used oil that I get from oil changes goes in a 5 gallon bucket from Home Depot. When I get enouh of it I bring it to the shell station next to the house. They have a waste oil heater that they use for heat in the winter. They NEVER complain and take as much as I can give them for obvious reasons. If the oil has gear oil or ATF I bring it to the town waste facility.
Same goes for antifreeze. I fill 5 gallon buckets and drop it off at the town recycling facility. I have reused it if it is not old. I put a piece of cheesecloth over another 5 gallon bucket and strain it over that. Works good.
Also check your town, if you have city sewage, they might allow you to pour it down the drain. Seriously. Check on it.
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 10-15-2010, 10:58 AM
65gto69's Avatar
65gto69 65gto69 is offline
I call my local HAZMAT and they tell me who in my area will take motor oil and antifreeze. Through them I found a local garage that takes both motor oil and antifreeze. Works out good, only have to make one trip to one place and drop it off, no questions.
maybe contact your local township or municipality building for recycling info.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 10-15-2010, 12:53 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
if youre still in VA beach just find the local transfer station down there.
i'm in FFX county the ox road transfer station - nee DUMP - takes it.
costs too much
Old 10-15-2010, 08:23 PM
DOC DOC is offline
I'll give the county a call next week. I was just curious and do appreciate the help. I am now living in St. Johns Florida and the local transfer station is about 1/2 hour away. Didnt think about them.
Old 11-04-2010, 05:11 PM
Old Goat Racer's Avatar
Stray dogs will take it but then ya gotta get rid of the dog.
Everybody knows somthin.
Nobody knows everything !
Old 11-04-2010, 05:44 PM
66Post's Avatar
66Post 66Post is offline
County recycling place takes it, what they do with who knows. In my old age I just feel right about dumping it down the drain anymore.
Old 11-04-2010, 07:32 PM
wytnyt's Avatar
wytnyt wytnyt is offline
find a garage that has a waste oil heater,,,they'll take it
they always run low in winter
Old 11-25-2010, 03:45 AM
cuz68's Avatar
cuz68 cuz68 is offline
That is what i would do also.
Old 02-27-2011, 08:30 PM
harleyflhx harleyflhx is offline
Dump down the toilet!
Old 02-28-2011, 04:36 PM
GT182's Avatar
GT182 GT182 is offline
Elefantrider, you might be thinking of Sierra Antifreeze. It's safer... less toxic. Supposedly NAPA carries it.
http://www.sierraantifreeze.com/ Click on Product Info.
From their website:
A 50/50 blend of SIERRA Antifreeze and water has a freezing point of -26�F.
SIERRA's formulation has demonstrated outstanding performance in tests that measure its ability to prevent corrosion in all cooling system metals including aluminum, copper, cast iron, steel, and solder.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-06-2011, 11:15 AM
I think Sierra uses more propylene glycol than ethylene in it.
