Old 04-28-2011, 11:22 PM
Fat Cat's Avatar
Fat Cat Fat Cat is offline
Default Wing Window Rubber
So I finally figured out last year where I was getting all of my wind noise from... Turns out it's the rubber wing window seal. If I press the glass tighter against it, wind noise cuts down to nearly nothing. Looking closely at it, it's very dry and cracked. I've seen replacement pieces for these on ebay but don't know if they are any good. Has anyone replaced these and have any suggestions where to buy? Also is it a tough job?
"A bend in the road isn't the end of the road unless you fail to make the turn."
Old 04-28-2011, 11:33 PM
Engine-Ear's Avatar
"Has anyone replaced these and have any suggestions where to buy?" -FC
Tried PY? (just sayin')
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 04-28-2011, 11:58 PM
Fat Cat's Avatar
I looked at their site, but wasn't sure about any of it being the right piece. Kind of confusing...
Old 04-29-2011, 12:10 AM
Engine-Ear's Avatar
I'd call PY tech support and also Steele (after PY). Should be a slam-dunk given shared glass app with Shivvy.
Old 04-29-2011, 02:26 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Fat Cat View Post
... is it a tough job?
Somewhat challenging, patience required. A shop manual is invaluable for removing/installing the vent window assembly from/into the door.
Old 04-29-2011, 06:38 AM
62 bv 62 bv is offline
Default rubber
i got mine from steel rubber products once you get out of the car you have to drill out some rivets out to get it apart
Old 04-29-2011, 09:21 PM
Fat Cat's Avatar
Ok, I'll look into it some more, thanks.
Old 04-30-2011, 08:12 AM
Heybuck's Avatar
Heybuck Heybuck is offline
Question What year car???
I'm not sure what Year car Fat Cat is talking about but if it's a '65 or '66, you don't need to drill any rivets out that I'm aware of.
First job is pulling the entire quater vent assembly out of the door. It's actually quite easy to do and if you mark the settings carefully, it will go back into the same position without difficulty.
You pull out the felt chanel and there are screws behind which simply undo. The window will pull out and it all becomes quite clear on how they are assembled.
Good Luck
Ian
To laugh at men of sense is the privilege of fools.
Old 04-30-2011, 08:59 PM
Fat Cat's Avatar
Yes Ian, it's a 66. I have had the quarter window and track out before, just never took it apart further, so that much I can handle. Seems pretty straightforward after that. Thanks.
