Old 05-05-2011, 07:54 AM
mkoser's Avatar
mkoser mkoser is offline
Default Speedometer Rattle
Even since I bought my Catalina in 1998, it's had this annoying speedometer "rattle."
It only makes the noise when the car is moving, and it is a mechanical rattle in the speedometer mechanism. It changes "pitch" at increased speed. I've taken the cable off and shot some white grease down it. That didn't change it at all.
I figure it's probably a bushing, or bearing that needs some lube.
Before I tear the dash apart, is there anyway to open the Speedometer itself to access the components?
Thanks,
MK
Old 05-05-2011, 08:41 AM
Old Goat 67's Avatar
Yes, there was dis-assembly provisions back then, but I would try a new cable first.
Old 05-05-2011, 09:51 AM
Heybuck's Avatar
Heybuck Heybuck is offline
Thanks,
MK
MK, if you take the cable off the back of the speedo, you can then pull the entire inner cable out of the casing. Wipe it down to get the old hard & dry grease off it, then give it a very light coating of new grease and slde it back in.
Might make a difference. Easier that changing out the whole speedo head anyway
Ian
To laugh at men of sense is the privilege of fools.
Old 05-05-2011, 09:57 AM
mkoser's Avatar
Ian
Do you have to remove it at the transmission as well?
Old 05-05-2011, 01:05 PM
Deadhead's Avatar
Deadhead Deadhead is offline
You can but you don't have to. You can get either take off the pad or lie under there to unscrew it. I think you might be able to take the speedo out with the pad off if you had to.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 05-05-2011, 04:30 PM
mkoser's Avatar
I took it all apart, and got the cable out. It was really clean, but I cleaned it and lubed it up. I had a heck of a time getting it back in, I haven't taken it for a test yet, since it is raining out now..
MK
Old 05-05-2011, 04:56 PM
mkoser's Avatar
Couldn't wait. Took it out in the rain. GASP! (First time driven in the rain since 1999.)
No more rattle. Once again, PY forums worth a mint.
Thanks,
MK
