Old 09-05-2011, 01:31 PM
61 vent 61 vent is offline
Default Master cylinder removal
Hello all, I am trying to remove my master cylinder, and as I try and remove it from the booster, it is stuck. I am assuming that corrosion is the problem but just wanted to check in with the group to make sure I am not missing anything, as I pull the M/C out it pulls the pedal to the floor and that is as far as it will go. I am hesitant to spray anything inside the booster, but would feel better if you guys think the PB buster wont hurt anything. Thanks Andy
Old 09-05-2011, 01:48 PM
Oh and just as a note, I have the Morain type booster and M/C according to my manual, amazing the original screw type lid on the M/C.
Old 09-05-2011, 01:52 PM
stevep's Avatar
stevep stevep is offline
The master will come off the booster after you unstick it, but it will just be an empty casting as the piston is part of the booster.
If you had a Bendix, the master and booster can be serviced seperately.
Old 09-05-2011, 02:25 PM
Thanks, will I need to spray something inside? I can't really tell what part is to be unstuck
Old 09-05-2011, 02:29 PM
I have some pry bars but I dont want to mess anything up, I am going to be swapping the single lunger out for a duel M/C maybe it won't even matter if I need to use a different style because of the Morain booster.
Old 09-14-2011, 04:15 PM
mikediaz mikediaz is offline
I had a screw type master cylinder on my ''65 bonnie. I don't remember if that meant it was bendix or moraine but it sounds like it was the same as yours.
It was a while back so I don't remember details but I certainly don't remember anything 'holding' the master cylinder together to the booster that would be hard to separate.
I remember just leaning a little on the master cylinder (nothing too hard)... I will look for pictures tonight if I have a chance as I remember taking many.
The only interface between the m/c and the booster is a small little rod/piston from the booster that goes into the m/c. Certainly enough play that it would NOT be responsible for holding the M/C to the booster. Give it a little controlled force after loosening the nuts a lot that hold the two together and it'll separate.
Will try to see if I find pics tonight!
Old 09-14-2011, 07:41 PM
Engine-Ear's Avatar
I had the same problem with my Catalina Safari...I ended up adding PB Blaster to the reservoir, letting it soak for a week, adding heat (with a Bernz-O-Matic torch) to the bottom of the m/c where the piston traveled, then gave it a good tug and it came off.
Main problem is the aluminum piston fuses to the iron cylinder.
I sent my booster to a cat named Dewey on the left coast for a rebuild. Ten years later it's still the "Cats" meow.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 09-14-2011, 10:34 PM
I found the old thread I had (wow almost 5 years ago...) when I took the m/c+booster off the car and rebuilt the M/C and repainted everything.
It's probably only been 5k miles since then but the system is still stopping me.
http://forums.maxperformanceinc.com/...aster+cylinder
The first page has pics of what's behind the M/C.
Hope it helps!
Old 09-16-2011, 11:42 AM
Thanks guys, I have pulled the entire lot off of the firewall and am looking at a dual master cylinder and newer booster swap, Good news is it is starting to cool off here and I will be able to start throwing man hours at this thing, and some cash also. Thanks for the replies. Andy
Old 09-19-2011, 10:53 AM
Steve Barcak's Avatar
Andy,
I used a disc booster/master off of a 70 Bonneville on my 61 Safari. It has a large diameter booster and had to dent the wheel well and it works well. This is with 4 wheel disc brakes.
Also have smaller boosters that should not need denting of the well.
Steve
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 09-19-2011, 01:32 PM
Thanks Steve, I will keep you in mind. I hope to find something here, and I may be pretty close. Andy
