Old 12-16-2011, 11:50 PM
dda72's Avatar
dda72 dda72 is offline
Originally Posted by slowbird View Post
Just thought I would bump this back up and say the plug location looks good to me.
Agree. Like that intake valve!
  #222
Old 12-17-2011, 02:26 AM
Ron H's Avatar
Ron H Ron H is offline
What CC did that chamber end up with?
68 Firebird
Are you running with the wind or breaking it?
  #223
Old 12-17-2011, 10:22 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Slow,
Yes all is looking good with that chamber Thanks for contributing.
What are the valve sizes?
Any cross-section areas or flow numbers?
  #224
Old 12-17-2011, 12:09 PM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by Jim Robertson View Post
Slow,
All I will say right now is it far exceeds any flow numbers that have been posted so far in this thread.
  #225
Old 12-18-2011, 06:45 PM
Bruce all I know is I like the fact you see problems that to me means its good because the head you like and see no problem with aint doing so hot.
Not quite... I'd have prefered the CV2 configuration from the start. To me it would have been an evolution of the RA5. Much along same lines as Ford's 429 SCJ iron heads evolved to Blue Thunders and P51 heads. To me, I would consider it as something that "might" have been, had Pontiac been allowed to play more. Thats something I did mention to Jim quite a long time ago.
As far as results... its doing OK much has to do with learning curves and budgets and of course perceptions. I think we have all seen examples of all the right pieces and yet somehow someone gets less than expected results while others are getting good results with same pieces. Certain "talk" good or bad may help ego's but does nothing for development of anyones favorite brand cylinder heads.
As far as finding problems... Bad habit I guess. Thats what I got paid to do for over 35 years. That included finding ways to resolve problems. At some point if you see something that might be problematic or simply could be done better do you sit on the sidelines and do nothing, or do you see if a revision may be a consideration?
However I may come across, my criticisms are generally intended to be constructive. (Hey I'm no more perfect than anyone else here. I need no reminders of where I've been less than constructive. ) Constructive criticism is good. Ill spirited and vendictive criticism that some spew is destructive for ALL of us.
I'm NOT an Edelbrock head hater! (or any other for that matter) Way back it was like we had to wait for everyone else before Pontiac got any attention from Edelbrock. Then while they continued with new developments for other brands,for years(decades?) we Pontiac lovers just kind of got put on hold again. So... now, finally, some new stuff and there are things there that dont have to be the way they are... unless we let them think we'll take it anyway and fix things ourselves like we always seem to end up doing.
Personally I'd rather not invest in labor to work around something so I could "get by", if it could have been addressed at the manufacturing level. ANY product.
  #226
Old 12-21-2011, 09:46 PM
Discussion is now open.
Feel free to contribute if you have first-hand experience with the head being discussed, otherwise stay out of this thread.
  #227
Old 12-22-2011, 10:27 PM
b-man,
Thanks for re-opening.
Our work on the Pro Ports continues and I look forward to shaping these and post progress.
Jim
  #228
Old 12-25-2011, 10:24 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
b-man,
Jim
... how are you coming coming with your shape Jim ?? ... i really like the look of the oval entry, i was wondering what % you are at on your secondary choke point with the oval entry ?? ... i wanted to experiment with ours with that entry depending on what it does to the choke ... i would expect it to be around .350-.400 less in CSA compared to it being a squared entry ... also does the Victor look like it will line up to the entry you have ?? we dont have one in the shop for me to compare, so i figured i'd ask you ...
  #229
Old 12-26-2011, 10:51 PM
Progress is forward on this set. Entry size in head now will allow me to port the Victor and fit/align without welding. It would be great if the Tiger intake would physically fit. From what I understand at this point the intake flange (on head or manifold or both) will require milling to install. IMHO the Tiger has enough area to take advantage of the predicted head flow.
Wade,
Any update on the BOP manifold you mentioned a few weeks ago?
  #230
Old 12-26-2011, 11:13 PM
Wade,
... we have a Tiger intake in the shop, when we get back we'll measure it up and see where we stand with it, maybe we'll get lucky ...
  #231
Old 12-29-2011, 09:44 PM
slowbird's Avatar
Don't know if anyone cares but here are some pics of a 11 degree pro port next to half a HP head.
ID:	268613   Click image for larger version
ID:	268614   Click image for larger version
ID:	268615   Click image for larger version
  #232
Old 12-29-2011, 10:12 PM
Ron H's Avatar
Thanks. Higher than a high port!
68 Firebird
  #233
Old 12-30-2011, 10:56 AM
Does the 11º intake bolt holes look a little too high to use a standard Pontiac intake?
  #234
Old 12-30-2011, 04:11 PM
Not if the intake face actually sits closer to block center. The intake face placement relative to the head bolts would determine that. It would still bolt up but sit higher off the valley if the faces end up further inboard and higher than the other head.
  #235
Old 12-30-2011, 04:57 PM
gearbanger's Avatar
gearbanger gearbanger is offline
Looks like they have actually changed the angle that the valve cover sits on to get more meat to raise the intake ports. Seems like that kind of mods would cause NHRA eyebrows to raise. Are these heads approved?
  #236
Old 12-30-2011, 05:05 PM
cgeise's Avatar
cgeise cgeise is offline
I doubt these heads are ment or approved for any class like stock or SS
  #237
Old 12-30-2011, 05:07 PM
cgeise's Avatar
What I do see is the location for the bolt on the water crossover -- looks like they moved them all up - including that one - -but left the water hole in the standard location - HMMMMMMMMM
  #238
Old 12-30-2011, 10:38 PM
gearbanger's Avatar
eah,and the water hole is almost to low to seal where the casting breaks on an angle at the bottom.
  #239
Old 12-31-2011, 05:47 PM
cgeise's Avatar
im going to "assume" its threaded and will require the use of a fitting and hose???
  #240
Old 12-31-2011, 06:33 PM
If not threaded just one more thing to do. I dont think anyone is going to worry if it cant take a factory crossover.
