Old 12-08-2011, 11:22 PM
Just a comment, You don't run the times that Rodney and Travis run with their 63 Tempest without having a bunch of this stuff figured out.
It might take a while to get there BUT eventually with everyone helping each other you get it figured out.
Tom Vaught
  #62
Old 04-15-2012, 10:29 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Thought I would give another update on my car. Even though I dont have pictures of my engine back in at least I'm making progress with the chassis. Waiting on a few parts to start mocking up a new set of headers for the turbo's.
The 25.5 is done and ready for the inspector next Sat. I still have a few gussets I want to add but the cage is ready for him to look at.
The rear end housing will be next, I have to either build a new housing or add a back brace and new housing ends to the current 9" I have. Most likely to save time Ill use the one I have to start out, if I need to shed some pounds I'll build a new chrome moly housing.
I eneded up with a new set of Strange dual caliper rear brakes. Hopefully they will help hold my car at the line with a set of stock front brakes.
After the housing is done I'll get the body back on the chassis and start putting in the tin work.
I've decided to take the car on Drag Week so I'll have to set up a second fuel system and add some wiring.
One of my buddies back out so I might have a empty seat for the 1200 mile trip!! If I dont hurt the twin turbo engine I'll be taking it on the trip. If I hurt it, I'll put in a nitrous motor and run one of the slower classes.
Name:	69 chassis 008.jpg
ID:	281750   Click image for larger version
Name:	69 chassis 011.jpg
ID:	281752   Click image for larger version
Name:	69 chassis 012.jpg
ID:	281754   Click image for larger version
Name:	69 chassis 013.jpg
  #63
Old 04-16-2012, 05:21 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Jeff,
Your project is moving right along! Looks great.
Was the IA-II block size/location much different than the stock block? We need to figure out where the engine and trans is going to sit in order to locate the 6C bar.
  #64
Old 04-16-2012, 06:45 PM
jdw_poncho's Avatar
I built my front and mid plate mounts with the stock block and everything fit when I bolted in my IA2. I didnt have my trans at the time so I built 6C after everything else was put in.
Something you might ask about, will the 6 bars be angled up to the rocker bar to clear your exhuast? If you havent already figured that out I would strongly suggest getting a mock up block and route your exhuast before he welds your inner 2A-B and 6 bars.
Since Im running the car on the street I still have to figure out exhaust placement. I dont think I exhuast running through the fender wil pass MO's safety inspection.
What trans are you using? I bought a JW Ultra HP T400 rated at 2800HP.
  #65
Old 04-16-2012, 08:57 PM
RAIV-Z's Avatar
Got a mockup stock block and turbo400 case at the shop. I talked to Mike about exhaust placement on Saturday. The 6 bars are going to be angled up, I'll have to ask about 2A-B.
Nice Trans! I currently have a fairly new TCI T-400 and 8" converter which will need to be replaced
Which converter did you go with?
  #66
Old 04-16-2012, 10:29 PM
jdw_poncho's Avatar
I havent bought the converter yet. I want to get a price for a bolt together from Chance but most likely one from PTC. Im not sure what the cost difference is or what I would gain spending the extra money for a bolt together.
Glad he is moving the bars up, Im kinda screwed on mine right now. I wasnt building it to drive on the street.
  #67
Old 04-16-2012, 11:26 PM
With the bolt together convertor you get to tune it to your combo better. Worth it in the long run IMO. As you work your way up the boost levels your stall and slip change.
  #68
Old 04-20-2012, 11:12 AM
jdw_poncho's Avatar
I talked to PTC yesterday about a converter. $1000 to buy $200-$300 to change my stall for the standard converter. $2000 to buy a bolt through, I didnt realize there was such a difference in the two converters. I'll start out with a standard conv until I can figure the car out.
  #69
Old 04-20-2012, 11:26 AM
bankbook's Avatar
bankbook bankbook is offline
There are a few bolt together's on the bullet. Usually 1-1200.00 in price. Then send it to Marty for the "tune" specific to your combo.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #70
Old 10-17-2012, 09:09 PM
jdw_poncho's Avatar
I keep forgetting how long ago I started this project. A few updates..
Car was put together in a hurry to make it to drag week. Just put a smaller N/A motor in it with plans to run a little nitrous to get by until I can get the boosted engine back together. Didnt do too well at Drag Week but I will be ready for it next year.
Chassis is done and the car drives just fine. It rode a lot rougher than I had imagined it would. I started out with 130lb springs in the rear and loosened up the QA 1 springs in the front. But the 130's just couldnt handle the weight of the u-haul trailer so I cranked them as tight as I could. QA-1 suggested a 150lb spring.
Ended up with a JW t400 trans and a PTC converter. It was pretty funny trying to get the car up on the converter with my little motor. I couldnt get it past 2600rpm's on the trans brake, the converter was spec'd out for a 2000HP engine so its a touch to tight for my little 400hp engine.
Ended up putting flowmasters on the car, hate them! The resonance along with the tin work just about drove me nuts driving down the rode.
Starting building another set of headers for the CV-1's. Had my 78's sold a could weeks ago but they back out. Was planning on stepping up to 88's or 91's. Now I think I'll just try the 78's and get it on the track next year.
Name:	Chassis 103 edited1.jpg
ID:	300659   Click image for larger version
ID:	300660   Click image for larger version
ID:	300661   Click image for larger version
ID:	300662   Click image for larger version
  #71
Old 10-18-2012, 07:52 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Cool project.
Do you worry about over heating the trans with a stall and towing?
  #72
Old 10-18-2012, 08:20 PM
RAIV-Z's Avatar
Congrats on getting the car on the road and to the track, looks great.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #73
Old 10-18-2012, 09:25 PM
jdw_poncho's Avatar
Originally Posted by ponjohn View Post
Cool project.
Nope, I have a huge plate and frame oil cooler with a 12" fan on it. That was the only thing I could keep cool on the car during the heat. I was pleasanty surprised how cool the oil was after 2-3 hours of crusing around town without the trailer.
I pulled the trailer on the interstate for probably 10 miles in Tulsa during Monday morning traffic along with a few miles of stoplight traffic in town. It never got over 148 degrees. I know it sounds like a cliche, but I could hardly tell it was back there. I had it packed full of tools, spare wheels &slicks, 2 oil changes, 2 cases of trans oil, fullsize jack and stands, air tank, a weeks worth of clothes for two people and 15 gallons of gas.
  #74
Old 12-28-2012, 07:41 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... how did your headers turn out for the new heads ?? ... any pic's ?? ...
  #75
Old 12-29-2012, 12:32 AM
jdw_poncho's Avatar
I have them started but not finished. I thought I had a few build pics but cant find them right now. After I started on them I didnt like how they looked so Im starting over when I get my heads back and when the new T6 turbo's come in. I will say the rear driver side cylinder sure makes a 2" tube tough to clear the steering shaft. I think I've decided to replace the stock steering shaft so it will make it easier to build the headers.
The first try was to have the turbo right where the high beam light is. Now Im thinking about splitting the rad and put them side by side in the center of the car. For some reason it makes it easier to run the exhaust out the front fender.
I have my stock block and another set of e-heads on it right now. Not as exciting as using new parts....
  #76
Old 12-29-2012, 03:19 PM
... i thought you already had the heads ?? ... but i cant wait to see what you come up with for your headers ... ... are you using steel, or stainless, or inconel ?? ...
... how much boost are you lookin' to start out with ?? ... the pics are great though, thank you ...
  #77
Old 12-29-2012, 10:27 PM
jdw_poncho's Avatar
I did have them, just making one more update before I put them back on. I have enough material to build a set in 304L or mild steel. I still think starting out with mild steel and coating them will be ok.
I was looking for 25-27lbs with the 78's. I think they made 22lbs at 4500rpm but it wasnt climbing very fast. I have to look but I think it made a touch over 1300hp at 4500rpm's so hopefully I'll hit my 1800hp goal. My car weighs 3457lbs, I need all the HP&TQ I can get!
Each turbo is rated at 1200, just not sure how accurate that is. Precision doesnt make them anymore so Im concerned about why they were discontinued.
Trying to learn my new meagsquirt ECU right now. I have it installed a 5.3 LS engine while I figure out all the little settings. Then its going on the race car.
  #78
Old 12-29-2012, 11:28 PM
... if you use the mild steel, depending on the gauge, i would suggest "Gusseting" the tubes to the flanges ...
  #79
Old 12-31-2012, 07:42 PM
jdw_poncho's Avatar
My plan was to support the turbo from the frame. Should take most of the stress off the headers.
  #80
Old 12-31-2012, 08:38 PM
