Old 05-04-2012, 08:07 AM
J.C.you's Avatar
J.C.you J.C.you is offline
insert looks like beryllium copper. Probably work good in the application.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #42
Old 05-04-2012, 08:23 AM
60man's Avatar
60man 60man is offline
Originally Posted by Glenn Sedig View Post
My engine is 14.5 to 1
Thanks....mine to..
I'm thinking of going bigger(more cubes) and droping CR by 1.5 pints..to help gaskets live?
Probably just a band aid..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #43
Old 05-04-2012, 09:04 AM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by 60man View Post
Thanks....mine to..
How many pass are you currently getting on your head gaskets before they need changed?
I didnt realize this was an issue for the Tiger heads unless you really pushed the compression and hp like Langer, Rex & Dwight.
  #44
Old 05-04-2012, 09:31 AM
Robert C.'s Avatar
Robert C. Robert C. is offline
It is not a must do item. Most racers don't have any problem. Look at it as insurance.
You know the head gasket will always fail in the final round at the big money event.
Right?
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
  #45
Old 05-04-2012, 10:43 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
i am very surprised that you are having problems with that compression ratio.. how many passes are you going before you notice a gasket going?? i had 14.7 to 1 and could go all year with my e-heads without changing gaskets, but its only like 45 tp 50 passes a year. I upped the compression for this year so we will see how it acts now.. i have no water going to the head either in the middle.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #46
Old 05-04-2012, 01:53 PM
60man's Avatar
Can't say it's a Tiger "issue"...I have had some cooling problems to..which sure didn't help. My Cometics went at about double the passes of Kinsler's....like about 85-90 passes...at Norwalk last year...natchurally .......right Bob C.
I feel my excessive 215* temps at times sure didn't help..
I have added rear cooling lines and new bigger fan and different restrictor + 16v zings the water pump & fan. Temps haven't gone over190-195* so far......but it's not HOT yet.
Going to keep a close eye on them this time..First sign of leaking they're going to Calvin..
ECM member.
MANDRA
  #47
Old 05-14-2012, 04:13 PM
Glenn Sedig Glenn Sedig is offline
Default Tiger Inserts
New inserts where tried at Cordova on Fri and Sat for the West Q-8 bracket race. Stars where aligned correctly and won the race. Have to believe the inserts worked very well as this engine has never been this consistant except for the first several runs after changing the head gaskets.
Fri 4500 launch rpm--------60ft
1st run-8.82 @153.96-----1.302
2-------8.84 @153.30-----1.303
3-------8.83 @153.61-----1.293
Sat 5500 launch rpm
1st------8.76 @152.76-----1.241
2--------8.77 @153.44-----1.250
3--------8.76 @153.70-----1.252 elimination run
4--------8.75 @153.35-----1.253 elimination run
5--------8.75 @153.65-----1.246 elimination run
For the car to be this consistant I am quite sure there was no insert problem or head gasket leak. We are checking leak down today to see if there are any changes.
  #48
Old 05-14-2012, 07:36 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Glen congrats on the victory, please keep us informed on the leakdown. I am getting tired of buying headgaskets and shaving the heads. thanks MK
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
  #49
Old 05-14-2012, 07:41 PM
Thumbs up
[QUOTE=Glenn Sedig;4631844]New inserts where tried at Cordova on Fri and Sat for the West Q-8 bracket race. Stars where aligned correctly and won the race....this engine has never been this consistant except for the first several runs after changing the head gaskets.
Sat 5500 launch rpm
For the car to be this consistant I am quite sure there was no insert problem or head gasket leak. We are checking leak down today.../QUOTE]
Stellar results. LETS begin to ponder the berylium bridge connection to consistency. Cool running allow 4 CYLS to fire better (at proper advance)?
  #50
Old 05-14-2012, 08:49 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Extremely consistent, looks like you found some HP with the increase in MPH too.
Calvin Hill
Hill Performance
708-250-742-
  #51
Old 05-14-2012, 10:41 PM
Bill Bolin's Avatar
Bill Bolin Bill Bolin is offline
Wink
Originally Posted by Robert C. View Post
Yes this has been proven to work on the Dirty Bird Engine. It helps when the Melting temp. of the material is over 3000 Deg. and aluminum is 1125 Deg.
It is places deep in the head well below the valve seats. He did this 2 years ago. It als pull heat away for the valves too.
OK.....I say we just make the WHOLE head out of this material!!!!!!
  #52
Old 05-15-2012, 01:44 AM
john marcella john marcella is offline
Get your wallet out for that one.
  #53
Old 05-15-2012, 01:53 AM
Sat 5500 launch rpm
Good deal Glenn. Congrats on the win as well
I was sceptical at first but it is looking like my initial thoughts were wrong. Ya learn something every day
  #54
Old 05-15-2012, 07:13 AM
congratso on the win. how much were you weighing ?
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #55
Old 05-15-2012, 07:27 AM
Brian Baker's Avatar
It's an issue on any Pontiac running 12:1 CR and higher, due to the 4 fasteners per cylinder arrangement. Bump the compression up higher through more cubes and bigger bores and the problem is only exacerbated by less area between cylinders (especially on the center two cylinders where the heat from the siamesed exhaust ports wreaks havoc).
I remember a conversation with Jack Gaydosh about high CR and head gaskets when he was still running Pontiac power in his old car. I remember him saying when he ran coppers with an O-ring that he had to replace the gaskets after about 15 passes because the leakdown between the two center cylinders would be too great. He went with Cometics when they became available and was able to more than double the cycle life of the head gaskets.
  #56
Old 05-15-2012, 08:11 AM
Hey, interesting. I'd like to hear what the PROs are thinking about now.
  #57
Old 05-15-2012, 09:47 AM
GTOGEORGE's Avatar
So................Glenn, how much were you squirting it? Glad to hear everything seems to be A-OK.
I'm using a double o-ring set up in my engine and after 50 or so runs (only at 9-11 lbs. of boost) everything was OK. When I took a leak down test.
GTO George
  #58
Old 05-15-2012, 10:31 AM
GTO George
Glad ur having success with ur set up George! I think u might find if u turn the wick up in the mid to high 20lbs, u might find there is a bit more maintenance and issues... you are running at relatively low boost. Don't know if u ever plan to turn it up that high? If you do you will certainly fly but it comes at a cost with issues like this...
  #59
Old 05-15-2012, 12:11 PM
GTOGEORGE's Avatar
Scott I understand that I am not running at high boost levels right now, just was wondering what Glenn's set up is on his 7 passes.
George
  #60
Old 05-15-2012, 01:27 PM
You probably wouldn't believe 3195 lbs. So I won't lie. 2950 lbs
