Old 07-02-2012, 05:41 PM
GT182's Avatar
GT182 GT182 is offline
Dominic, hope you don't mind me being nosey, but what wes the cost of your windshield with the date code.
I've got to do mine this summer and want a proper coded windshield. Im just quessing, but would the code be a week to a month before the car was built? My 66 was built 4th week of March 66..... in Baltimore.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #102
Old 07-02-2012, 10:06 PM
RedDirtRoad RedDirtRoad is offline
Gary
Windshield was 180.00 plus 50 for the original date coded logo
My car was 3rd week of January and my date code was CA
I dont have my book right now so I cant tell you month.
I can get you that info tomorrow
  #103
Old 07-02-2012, 11:16 PM
Correction:
My car was 3rd week of December
My glass date code is CA which is November 66
  #104
Old 07-02-2012, 11:17 PM
FYI
http://www.iegtoclub.com/Tech%20Lib/..._lof_codes.htm
  #105
Old 07-03-2012, 10:12 AM
GT182's Avatar
Thanks for the link Dominic.
Looks like mine is more than likely a replacement. Shaded Soft Ray AS-1 M23 l-67 and read from the inside, not outside like I've seen on most cars. Not sure tho if it's an I or L as it looks to be a lower case letter. There are no other codes than these and they are copied as they appear. Month could be either March or June.
Gary
  #106
Old 07-29-2012, 09:29 PM
Getting ready to paint my trunk and complete all the misc. like jack, spare tire etc.
Can anyone tell me where the seam starts and stops for the trunk weatherstripping?
  #107
Old 07-29-2012, 09:39 PM
BANJO1 BANJO1 is offline
I was allways told that it starts/ends 6" - 8" inches left of the latch when looking to the front of the car. and this 19k mile lemans is like wise,, good luck with the trunk spatter
  #108
Old 07-29-2012, 09:44 PM
Clarence,
The paint should be here tomorrow.
I called them and they are sending the paint and hardner like we talked about.
I have a 2.5 tip too so it should go on nicely
I will email you some pics after its done. Thanks for the info on the paint
-Dominic
  #109
Old 07-29-2012, 10:08 PM
lazlo's Avatar
lazlo lazlo is offline
My 67 has it right in the center, with the original two white lines still visible top center
[SIGPIC][/SIGPIC]
http://www.gogtoaa.com/leibys%20rides.html
  #110
Old 07-29-2012, 11:07 PM
what white lines are you talking about?
can you snap a photo maybe?
I assume this is your survivor LeMans?
  #111
Old 07-30-2012, 12:09 AM
lazlo's Avatar
I'll get you pictures tomorrow. My 67 Lemans took gold in the survivor class at St Charles couple weeks ago.
The rubber has two lines and as I understand, when it was installed the two lines went center top ( or to the center front of the opening) & the seam ended up where ever the ends came together
[SIGPIC][/SIGPIC]
  #112
Old 07-30-2012, 04:57 PM
RA1John RA1John is offline
Old Goat:
Question regarding the AC Cowl Box. With the Fender off, I can sort of see the attaching studs/nuts. What is your opinion on being able to remove this (on a '64 GTO) to replace the Heater Core (factory AC car) w/o removing Fender?
From what I've heard, it's almost impossible to do w/o removing Fender or cutting an access hole in Fender Skirt.
Appreciate your thoughts.
Thanks!
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
  #113
Old 07-30-2012, 06:22 PM
Old Goat 67's Avatar
Not impossible, because I have done it without removing the fender or cutting a hole, BUT you'll wish you had by the time you're done.
It's that one damned bolt at the bottom outside of the box to the firewall that is the Beach.
Be very careful with that kick panel to heater box seal if it's still there. Not reproduced and it is a fun thing to try to duplicate.
Put a Murray heater core in there from O'Reillys and forget about it.
Charles
ID:	292947   Click image for larger version
ID:	292948   Click image for larger version
Name:	Kick panel Seal 65-2.jpg
ID:	292949   Click image for larger version
  #114
Old 07-30-2012, 06:51 PM
lazlo's Avatar
Here are the requested pictures of the original trunk seal on my 67 Lemans. If you want larger pics send me your email address to [email protected] & I'll send them to you.
On another subject, I just replaced my heater core. I jacked the car up, loosened the outer fender all the way around. I unbolted the inner fender and was able to turn it toward the outside of the car until it came out of the car. Time consuming but not difficult. I put tape between the door & outer fender to protect both. Wasn't hard to see where the fender bolts had been for the last 45 years & I bolted it back together based on that.
heres the pics
Name:	trunk seal 1 szd.jpg
ID:	292958   Click image for larger version
Name:	trunk seal II szd.jpg
ID:	292959   Click image for larger version
Name:	trunk seal III szd.jpg
[SIGPIC][/SIGPIC]
  #115
Old 07-30-2012, 06:53 PM
lazlo's Avatar
and one more pic of the two painted white lines used to center the seal at the top of the trunk opening to start the installation. My 71 has one white & one orange stripe. I duplicated them on the replacment seal with paint pens..
Name:	trunk seal IV szd.jpg
[SIGPIC][/SIGPIC]
  #116
Old 07-30-2012, 09:27 PM
Uda man!
Thanks for those pics!
  #117
Old 07-30-2012, 09:39 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
lazlo...
Was your car parked by the big side door that entered the building on Saturday (at St Charles)?
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #118
Old 07-30-2012, 09:46 PM
lazlo's Avatar
Originally Posted by 6 Grrrs View Post
lazlo...
Yes it was... the creamsicle orange 64 convertible was on the other side of the driveway
[SIGPIC][/SIGPIC]
  #119
Old 07-30-2012, 10:02 PM
6 Grrrs's Avatar
Yessir. Your car looked nice. I love to see original cars.
Tod Hoffmann
2002 Honda VTX1800C
  #120
Old 07-31-2012, 12:26 AM
lazlo's Avatar
Thanx
[SIGPIC][/SIGPIC]
