Old 06-10-2012, 05:31 AM
Gasman Gasman is offline
Send a message via AIM to Gasman
Originally Posted by Gasman View Post
1969 Gto The Judge
14"x7" 245/60-14 Front
15"x11" 295/50-15 Rear
Changed to 8x15 235/60-15 front
Torque dirty to me
  #102
Old 08-31-2012, 01:36 AM
Greenbird76's Avatar
Greenbird76 Greenbird76 is offline
Original to car 15 x 7 rally IIs. 4.5 inch back spacing
Mastercraft Avengers 255/60 r15 on all 4 corners
Suspension
Front: Stock stamped control arms with OEM rubber bushings, TRW coils for 76 TA, 1 3/16th inch ws6 sway bar with Energy poly bushings' stock refurbished spindles with OEM quality ball joints
Rear: Eaton 4 leaf springs with 126 lb/sq/in rate, OER spring kit with rubber bushings, 7/8 ws6 rear sway bar with Energy poly bushings.
STOCK WITH WORN 5 LEAF REAR FACTORY 76 ESPRIT SUSPENSION- LAME!
AFTER new suspension, wheel resto and new tires- SWEET
Lean, Mean and GREEN
  #103
Old 08-31-2012, 08:46 PM
wfbarto's Avatar
wfbarto wfbarto is offline
Very cool looking bird! Me likey!
1966 Bonneville Convertible, 421, 4spd. (in progress)
1966 Bonneville 4 Dr. Hdtp. (survivor)
1999 Trans Am Hatchback, red, 6 spd.
  #104
Old 08-31-2012, 10:23 PM
Thankyou! Factory 76 metalime green. Car will be resprayed that color. Love the deluxe white/ black interior too!
  #105
Old 09-01-2012, 09:57 AM
hada76's Avatar
hada76 hada76 is offline
formie hood would be nice
___________________________________________
the more im around people, the more i like my dogs
  #106
Old 09-01-2012, 11:05 AM
wfbarto's Avatar
Yep...if you are going to respray anyway. Put a formula hood on it!
  #107
Old 09-01-2012, 04:40 PM
Yep. A 70-75. I have a 76 lined up too, but i like the early 2nd gen ones more
  #108
Old 09-01-2012, 05:38 PM
wfbarto's Avatar
Do you have a pic of a '76 with a 70-75 hood on it? Not sure if I have ever seen this...?
  #109
Old 09-02-2012, 09:48 AM
The body lines on a 76 are the same as 75. Only difference is the bumpers. Would be no problem. Here is a 76 resto mod with 79 10th anniversary wheels. The scoops look really cool with that nose. They also cut the rare fiberglass hood for a scoop. What a shame. I would love to have that motor however, a nice 455
http://www.davidt.com/thumbnail/19066/400/300
  #110
Old 09-03-2012, 12:54 AM
virgil381 virgil381 is offline
Originally Posted by 67GTONUT View Post
235/60r15 Front
245/60r15 Rear
Rally I's Chrome from http://www.specialtywheelsltd.org/
15x7's Front
15x8's Rear
Thats is a great look.
Pontiac GTO rollin, cruisin and banging gears!
  #111
Old 09-14-2012, 11:36 AM
Formula jg Formula jg is offline
Front 245/60/15 Dunlop Qualifier and Rear 275/60/15 Nitto DR on powder coated oem snowflakes.
Front and rear springs were replaced in 1987 (front cut about 1/2 turn) and Koni red.
Currently looking at a set of Year One 17x9 gold snowflakes (not sure of tire size yet but definitely open for suggestions).
Sorry if this is a double post.
  #112
Old 09-14-2012, 12:24 PM
hada76's Avatar
a popular combo ive seen on the forums is 245/45/17 front and 275/40/17 rear (some go a bit wider on rear, one guy went to a 315 but it was very tight)
  #113
Old 09-14-2012, 12:38 PM
Will that combo leave a larger gap between the tire and the fender/quarter openings?
  #114
Old 09-14-2012, 12:41 PM
hada76's Avatar
yes...most guys do some susp. mods to lower car when going to a 17" wheel. ive also heard of using a 50 series tire to fill some of the gap.
  #115
Old 09-17-2012, 10:43 PM
kustom66 kustom66 is offline
Default my 72
20x10 on the rear and 20x8 in the front, lowered just a tad
  #116
Old 09-17-2012, 11:36 PM
Curly Joe's Avatar
Curly Joe Curly Joe is offline
Thumbs up bigger pic
Kustom66, post a bigger pic
"Chief" Knucklehead
462 E Heads Solid Roller 91 Octane Nash Stick
  #117
Old 09-18-2012, 10:28 PM
i am not very computer savvy and the wifes asleep i will try to figure it out tomorrow, keeps telling me my pics are to big for the file not sure on how to make them smaller
  #118
Old 09-19-2012, 03:43 AM
A.J.'s Avatar
A.J. A.J. is offline
Don't save it as a.bmp as it not compressed. Save pictures as .jpg instead and you will have no problem posting them eventhough they're larger.
Reef turqoise -66 GTO
Firebird Convertible -68 R.I.P.
-73 LeMans 350/350 Barnfind
  #119
Old 10-21-2012, 09:56 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Lightbulb 69 goat
275 50 Nittos on back with 17"x9.5" TTIIs with 5.5 bs. 61 1/4" outer drum to drum 12 bolt rear. Wheels and tires fit perfect with no modifications.
Fronts are 255 60 Nittos on 17"x8 with 4.75 bs. I had to massage the front lower fender lips for the front wheels/tires to work.
ID:	301051   Click image for larger version
ID:	301052   Click image for larger version
ID:	301053   Click image for larger version
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #120
Old 03-15-2013, 08:14 PM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
17" x 9.5" American Racing 200s with 5.25" BS all 4 corners. Center caps are a set of PMD red on black originals.
275 40 17 General UHPs
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
The Following User Says Thank You to Evil Stu For This Useful Post:
