Old 09-28-2012, 06:52 PM
Aus Goat Aus Goat is offline
Default Power steering box help
Guys
Some bright spark put in the wrong hose connectors for my power steering box.
This could have been done when converted to RHD but anyway.
What is the right thread size for the SAGINAW steering box for a 1968 GTO.
I will be looking for the connectors / steel tube only ( steering box end only ) as i will need to wield into my lines at the steel tube lines due to the length of hose required for RHD
Craig
Old 09-28-2012, 09:17 PM
scott0 scott0 is offline
As long as it is a older steering box one fitting is a 5/8 the other is a 11/16. On my car I used steel adapters to change it to 6an hose. that way you can make your own hose whatever length you need. It worked out really well. My car is not rhd, but the concept is the same.
