www.hrpartsandstuff.com
Has Anybody tryed this stuff? I need to get my low 10 sec car to go straight.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I was going to use their rear anti roll bar, did research and spoke to people that run it. Everything I found was positive.
I run a Ford 9" with a backbrace and their axle tube attachment would not work for me. Wasn't worth paying that much and still needing to fabricate custom mounts. Last edited by GTO Dan; 10-19-2012 at 02:26 PM. |
check out http://www.spohn.net/#1.
68 Firebird Are you running with the wind or breaking it? |
Hey Ron i just put a spohn in my car and im finally going to test it out tomorrow.
I installed a hrpartsandstuff.com anti roll bar in my car 6-7 years ago. Worked great. I run radial slicks and the car goes straight as an arrow. It runs high 1.30s 60'
Tom Syron |
Keep me updated, I've had a 139-141 60'
What rear control arms do you have now? Are you preloading the uppers?
Brian Rock '65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs. 9.88 @ 134 N/A on Cali 91 octane. http://www.youtube.com/watch?v=NJEIY5OJ68g
Car & driver weighs about 3000#. It has a set of south side bars with air bags.
I bought the car last year with a 400 engine running 11.40's
I am very impressed with how well your cars leaves. So the next time your at the track and see a pair of 13 size boots sticking out from undreneath the back of your car it's just me admirering your suspenstion. LOL GT. |
Is the car driving to one side off the line, or is it the twist at launch you are trying to correct? Do yo have the chassis braces that connect the upper and lower control arm mounting points at the frame?
Not much seat time yet, 10 passes. Had to abort 1 run 100' out heading for the wall, right lane. Some twist at launch also. No chassis braces. Previous owner fabbed his own "anti roll bar".
This is the car in question, not the black 1
Ron i got out yesterday the car went straight but when it shifted to 2nd the tire broke loose.
60' ?
Being a bit of an unknown car, I would start by taking everything apart in the rear. Make sure that the frame is sound and none of the control arm mounting points are cracked and deflecting. Thank make sure that the lower control arms are the same length. Is there any adjustability with the sway bar right now? Maybee eliminate it all together just to see what happens.
I would also measure the circumference of the rear tires. You never know.
Brian - Can you explain how you preloaded your uppers, i.e., how much?
There could be a few things that cause that. Maybe the track had something on it where you shifted, etc. How'd the car 60', better than previous? Do you have adjustable rear shocks?
I do run at least one full turn of preload with the AS bar though. Nothing else.
Just be careful and don't back out over blueghoast when they call your class to the lanes.... K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
