Old 03-17-2012, 10:27 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
car is off to the frame and body fab shop this week
ID:	278648   Click image for larger version
Name:	coup sat 2.jpg
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 03-18-2012, 10:37 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
Came across an Oakland yesterday in the Good-Guys swap meet. The only cool thing there... If it wasn't an overpriced rust box I'd own it right now. You may have scored the last build worthy pre-32 split grill...
Old 03-20-2012, 10:21 PM
GTOWAGON's Avatar
It took me 25 years to find a nice car like this I had almost given up
2015 GMC Yukon SLT
Old 10-06-2012, 11:37 PM
GTOWAGON's Avatar
Car is a roller
2015 GMC Yukon SLT
Old 10-06-2012, 11:46 PM
GTOWAGON's Avatar
Pic
2015 GMC Yukon SLT
Old 10-07-2012, 03:03 PM
RA6T7GTO's Avatar
RA6T7GTO RA6T7GTO is offline
Send a message via AIM to RA6T7GTO
that is going to be a cool ride !
1967 RAM AIR GTO 1 OF 156 AUTOMATICS
Old 10-12-2012, 02:22 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Those front brakes are eye-candy! What are the finned backing plates from?
Old 10-12-2012, 04:05 PM
virgil381 virgil381 is offline
Awesome car. These are so stinking hard to find.
I have a 30 ford sedan i have been working on
Keep the updates coming.
Pontiac GTO rollin, cruisin and banging gears!
Old 10-12-2012, 05:08 PM
63Banshee's Avatar
Let me know when it goes up for sale.
Old 10-12-2012, 08:15 PM
GTOWAGON's Avatar
They are from Wilson welding it is an aftermarket backing plate made to match the Buick aluminum drums they also bolt directly to early ford type spindles
2015 GMC Yukon SLT
Old 10-26-2012, 08:09 PM
GTOWAGON's Avatar
The engine is coming together
2015 GMC Yukon SLT
Old 11-29-2012, 04:53 PM
GTOWAGON's Avatar
Engine has been run in and will be home soon car is coming along and will be getting chop and a small channel soon
2015 GMC Yukon SLT
Old 12-22-2012, 10:23 PM
GTOWAGON's Avatar
Engine came home today hopefully car will be ready for it by end of January
2015 GMC Yukon SLT
Old 01-04-2013, 04:31 PM
GTOWAGON's Avatar
I used a ford type transverse spring with a dropped axle and hairpins all from SoCal speed. The stock parallel springs are horrible and if you are not using fenders they have to go the ford stuff is easily available
2015 GMC Yukon SLT
Old 01-04-2013, 05:02 PM
Ken K Ken K is offline
I was told to use a Ford front end with the hairpins on my 31 Plymouth 3 window. I have 2 frames. The body is sitting on a 34 Plymouth frame now that has factory independent front suspension. The front end has to be changed. The 34 frame is boxed with a X member. The frame will take any kind of drivetrain I put in it. What did you use for a rear end? I have some vintage torq thrust that will go on mine. I have to use either a 4.75 bolt pattern or a 4.5 bolt patttern.
Old 01-04-2013, 05:14 PM
GTOWAGON's Avatar
My frame is using the original rails they have been boxed and have an x member I am using a 70 firebird 10 bolt with 3:42 gears the rear suspension is ladder bars from SoCal and coil over shocks with a panhard bar. I went with the 5x4 3/4 pattern since the rear already has it in the front I used buick aluminum drums from a 59 so they were redrilled for 4.75 pattern. The rear drums are 80's Grand Prix aluminum
2015 GMC Yukon SLT
Old 01-04-2013, 05:32 PM
I know where to get a late 70s T/A rear end with a limited slip. The problem is it has something like 2:73 gears in it. I want to use a 4 speed transmission. I have both the aluminum brake drums and rear disc brakes that I can use. The 34 frame will take a lot less work than the original 31 frame. Your body is cleaner than the one I have. I have a few small rust issues that need to be fixed. I was also thinking about chopping the top and channeling the body
  #38
Old 01-04-2013, 05:39 PM
GTOWAGON's Avatar
You can always change the gears f body rears are cheap I only paid 150 for mine I would stay away from the rear discs that come on the rears if you realy need them use the s10 setup it's a straight swap and works very well. I don't know about the dodge but my car only weighs about 2000 so drums all around are fine. There are lots of disc set ups for the ford front ends if you go that way. Are you running fenders on your car I know that dodges are the first all steel body so you don't have to deal with the wood like I had to
2015 GMC Yukon SLT
  #39
Old 01-04-2013, 05:47 PM
I have the fenders but I don't think I am going to use them. I want a traditional hot rod. Mine is a 31 Plymouth PA. The info is sketchy on them. It might actually be considered a 32. It uses wood behind the door frame opening but that's about it. It had a canvas top at one time and the body was made to flex near the windshield post on top. Mine has a oval back window. I think some of the late 20s Pontiacs also used a oval back window.
  #40
Old 01-04-2013, 08:33 PM
rohrt rohrt is offline
Love the progress!
