Old 05-25-2013, 07:41 AM
400 plus's Avatar
400 plus 400 plus is offline
Default Drag radials to hook
On my 68 I have a set of M/T 275/60/15s I do have traction bars already. Is air pressure the trick to getting these to hook at street lights?
Old 05-25-2013, 08:33 AM
400 plus's Avatar
Looks like I found it. Nahhh LOL Went to M/T website. Looks like 16-18 lbs for the street is about right. I got killed last night LOL
Old 05-25-2013, 08:59 AM
Hooter's Avatar
Hooter Hooter is offline
I ran 18 on my 255/60/15 drag radials. Hooked good at the track, but never really hooked on the street. Good luck.
67 Bonneville ragtop
Old 05-25-2013, 10:09 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Too many variables on the street....
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 05-25-2013, 10:18 AM
ponjohn's Avatar
ponjohn ponjohn is offline
My Ventura made 530 ft lbs at 3200 rpm.
Drag radials were no contest.
They hooked fine at 20 lbs at the track.
Loosen the front end.
Old 05-25-2013, 11:42 AM
ta man ta man is offline
Mickeys work great on a well prepped track and after a good burnout.On the street from a roll isn't too bad all depends on power.Try a good burnout while waiting for the light..
Old 05-25-2013, 12:36 PM
Lee's Avatar
Lee Lee is offline
I kept my 275/60-15 MT's at 24psi most of the time, and hooked great. Best 60' at that pressure was 1.52 with my wagon. In my old Firebird with the same pressure, I got some 1.53's.
I'm now running the Goodyear DR's on my wagon. Even though they are the same size, the Goodyears are a bit wider. I haven't had them on the track yet, but they hook GREAT on the street for me.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-25-2013, 05:16 PM
400 plus's Avatar
This was on the street with 24 pounds of air. I hit the gas and all I did was spin the tires and that tang was 3 car lengths out LOL
Old 05-25-2013, 06:09 PM
73 bird 73 bird is offline
I just got a set of the new M/T Drag Radial Pros 275/60/15(only size offered right now). Night and day difference. No more burning through 2nd. Hooks up decent in 1st on the street. Not much more tread than a slick, but they are DOT approved.
73 firebird 455 6x-4 heads 350 turbo 3.73 gears
1/8 7.65 @ 90.95
1/4 11.96 @ 112.60
new best in 1/8th 7.57@91 mph(4-13-12)
Old 05-25-2013, 06:13 PM
ponjohn's Avatar
They are or are not?
Old 05-25-2013, 09:15 PM
Hooter's Avatar
I don't think they are street legal. Great hooking tire though.
Old 05-25-2013, 09:30 PM
goatless's Avatar
goatless goatless is offline
From the listing of them on the Summit Racing site- They're DOT approved but then add "Mickey Thompson ET Street Radial Pro tires are designed for drag racing use only; they're not legal for street use."
1966 GTO
Old 05-25-2013, 09:46 PM
I'm going with DOT approved.
1/8 7.65 @ 90.95
1/4 11.96 @ 112.60
Old 05-25-2013, 09:50 PM
GTOGreg's Avatar
GTOGreg GTOGreg is offline
I run M&H Racemasters in an 18 no less (on other car), and right aire pressure AND heat is key. I drive to the track with 26 or 27 lbs and then air down to 19 at the track. Good 3-4 sec burnout in the box and it's a dead hook @ 3500 RPM. On the street? Much better than a street tire, but still breaks loose behind 675 lbs/ft torque and a manual trans - try not to do this too much though...
1967 GTO
Tyrol Blue/Blk Cordova
400, TKO-600, 8.2 Posi w/3.55
400 + .020, decked to .005
SD Performance 240+CFM 670 heads
RARE HO/RA manifolds
RARE 2.5" Exhaust (18" Magnaflows)
SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL)
PRW stainless 1.52 roller rockers
Forged TRW slugs
SCAT H-Beam forged rods
