Old 11-25-2013, 11:32 AM
Bentwheelbob's Avatar
I purchased the PHS documents on the Red Car about 3 years ago and did not receive this information. Thanks for tempering my enthusiasm though.
  #1822
Old 11-25-2013, 01:49 PM
70RAlll 70RAlll is offline
BWB..after I hit submit on my previous post I thought my posts' tone would be taken contrary to how I meant it to be. Apologize if it came across nasty, wasn't meant to be. PHS.... if they fax you the sheet, you just get your invoice, if they mail you the PHS documents,you get the invoice,a glossy black and white "press" photo of the TA, plus a half inch thick stapled AMA specs. Please don't take my comments as anything but trying to keep you from scanning all the pages in and posting on this thread. Was just trying to save you some legwork(you mentioned something about scanning at your office?) anyway, if an apology is in order, then consider this one..
The Following User Says Thank You to 70RAlll For This Useful Post:
  #1823
Old 11-25-2013, 02:31 PM
Bill,
Here I was half way to Tennessee and you reach out with niceties...maybe I'll just keep heading west and you can buy me some BBQ. Truthfully, I didn't take it any way other than informative, but even if I had my skin is pretty thick. You can't be as big a smart aleck as I am without coming under assault quite frequently. Thanks for checking.
I'll look at the packet I got on the Lemans Sport just to verify, but I remember being a little underwhelmed at the time and don't recall the AMA booklet. However, I am becoming convinced my mind is going...
BWB
  #1824
Old 11-25-2013, 03:03 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
I think it may depend on when you got it also. I got mine years ago, and it was pretty thin. a picture, the PHS sheet, and one explaining some of the options and that was it.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #1825
Old 11-25-2013, 04:03 PM
Exactly, I have PHS on all my vehicles and never got an AMA set, some I got a b&w pic.
  #1826
Old 11-27-2013, 12:01 AM
2manyT/A'S's Avatar
Default 455 HO head.....
Looking for a single 197 head...rebuidable core or WHY?
See my ad posted in Firebird parts wanted....
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
  #1827
Old 11-27-2013, 12:16 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
What gear ratio would a 71 4sp with AC have? I should know this but I can't remember.
  #1828
Old 11-27-2013, 12:29 AM
transam1972 transam1972 is offline
Default ratio
I am thinking close ratio 3:42:1 an automatic would be the same, except adding a/c it gets a 3:08:1 I know that should be correct for 1972..I believe 1971 offered both close and wide so it will be interesting if there are more ratios
  #1829
Old 11-27-2013, 02:14 AM
HO Kenny's Avatar
I know the standard rear ratio was 3.42:1 auto or stick. Adding AC to an automatic got you 3.08:1 gearing. I had the thought that AC in a stick got you 3.23:1. I don't know where I got that.
  #1830
Old 11-27-2013, 04:05 AM
roundportponchos's Avatar
Wink 71 parts needed
please parts needed for the new 71 Blue TA, thanks
  #1831
Old 11-27-2013, 12:14 PM
OVERULD's Avatar
OVERULD OVERULD is offline
3.31:1 is correct ratio for 455 H.O./4-Speed M22/AC. Edit: For the GTO. Not sure about T/A
BJ
  #1832
Old 11-27-2013, 12:56 PM
3.42 was the correct ratio in '71 for 455 HO bird with manual trans & AC. No 3.23 gears till later in the 70's.
In '72, whether one ordered a/c, or not, the '72 HO M22 Birds came with 3.42's.
  #1833
Old 11-27-2013, 01:18 PM
Default close or wide?
in 1971 did you get a choice of close or wide ratio shifter?..and if so the axle ratio was only one, for the both?
  #1834
Old 11-27-2013, 02:12 PM
2manyT/A'S's Avatar
ALL 71 & 72 T/A's came with 455 HO's as standard equipment.....all manual trans T/A's came with M22's....there were NO options....TH400 or M22...
  #1835
Old 11-27-2013, 02:14 PM
HO Kenny's Avatar
Close or wide ratio refers to the transmission. The ratio part referred to the percentage drop of rpm between gears. The m22 is a close ratio tranny. It is the same gearing as the m21. The m20 was the wide ratio. I think The wide ratio would have suited the torque of a Pontiac better. The m22 was a stronger tranny because of the straiter cut gears. It made more noise however. Therefor the nickname rock crusher.
  #1836
Old 11-27-2013, 02:28 PM
2manyT/A'S's Avatar
Totally addictive to listen to........if you've got an M22,you don't need a radio....
  #1837
Old 11-27-2013, 02:34 PM
blue71ta's Avatar
blue71ta blue71ta is offline
I concur - music to my ears
  #1838
Old 11-27-2013, 02:51 PM
2manyT/A'S's Avatar
Goes hand in hand with the "quadrajet flush"..... BahWaaaaa....ampified by the open shaker door....
  #1839
Old 11-27-2013, 04:20 PM
could I have read a sales brochure that offered close or wide ratio, but in reality only one being close was offered?..actually I just read in a 1971 brochure...Transmission fully synchronized 3 speed muncie
  #1840
Old 11-27-2013, 04:55 PM
HO Kenny's Avatar
Just got a 71 ta that someone put a doug nash 5 sp in it. They are supposed to have the "straight" cut gears as well. Can't wait to hear it once its road worthy.
