Old 01-16-2014, 10:38 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default what bolts here?
Is there something that goes here?
https://db.tt/FqX7YiN4
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-17-2014, 02:30 AM
gtofreek's Avatar
gtofreek gtofreek is offline
The only thing I can think of would be a hydraulic slave cylinder. But, I really don't know.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 01-17-2014, 08:38 AM
importsmasher's Avatar
importsmasher importsmasher is offline
If you mean the two bolt holes to the left of the clutch fork, those are for the 65-70 full size cars. The z-bar pivot bracket attaches there (rather than using the ball stud screwed into the block that A and F bodies use).
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
The Following User Says Thank You to importsmasher For This Useful Post:
Old 01-17-2014, 08:41 PM
67gtospud's Avatar
Alright, then I know I'm not missing anything. Thanks. I will make some plugs then to plug the holes.
