Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-29-2014, 07:40 AM
LPI's Avatar
LPI LPI is offline
Default New increased inlet capacity oil pump
All of us at LPI are pleased to announce a new chapter in the pursuit of better oiling systems for our beloved Pontiacs.
After extensive R&D we are now offering our increased inlet capacity oil pump with bolt on conical shaped pickup screens. The bolt on pickup screen can be tailored to most any pan depth, stock to race depths.
The new pump features O-ring seals from the block mounting flange to pick-up flange to minimize any type of leakage which can contribute to cavitation.
We will be introducing our new thrust plate with integral pressurized oiling mods for the bottom of the pump gears. This plate is made out of a new material used exclusively in hydraulic pump industry.
The plate is available as a separate item also. Price is $51.00
We have incorporated our new linear piloted pressure relief ball and spring assembly to minimize cracking and erratic movement typically found in the stock arrangement.
The main improvement comes in the area of increased inlet size and capacity.
We have increased the inlet tube size and redesigned the actual pickup screen to be a cone for better inlet flow with less turbulence.
These changes have produced approximately a 90% increase in area over the performance ¾” inlet pickups currently being used.
Why is this important? As the rpm of the engine goes up so does the rpm of the pump. The current design moves into a cavitation state around 5000 engine rpm due to the lack of flow volume to the pump gears. As the engine rpm increases the pump has to work harder and the output demand surpasses the supply and causes even more cavitation.
Another contributing factor in the oiling system is the necessity of windage plates in the oil pan.
With today’s large stroke crankshaft motors there is more windage in the oil pan area and this must be addressed to prevent the windage from uncovering the oil pump pickup at increased rpm levels.
Please give us a call and we can discuss your needs to modify your existing pan or package a pan and pump assembly for your new engine project.
Stock to 9.5” deep pans: $389.99
Send us your existing pump for upgrade: $349.99
Call for special depths or other accommodations.
ID:	351177   Click image for larger version
ID:	351178   Click image for larger version
Holy cow Tom that's a dirt road...
www.luhnperformance.com
Old 02-17-2014, 10:57 AM
bad69bird's Avatar
bad69bird bad69bird is offline
I am not currently using one, but I will have one on my new motor. I have bought and used several items from LPI and the products are awesome!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
The Following User Says Thank You to bad69bird For This Useful Post:
Old 02-17-2014, 01:02 PM
I ran the LPI theory past our "Oil Pump Lady" (Research Lubricants/Oil Systems Technical Expert) at work and she agreed with everything that was posted above.
I plan on purchasing a couple of the pump systems once I measure the depth of my oil pans.
Old 03-13-2014, 08:04 PM
LPI's Avatar
LPI LPI is offline
Default can handle 1200+ HP
Pump just ran great at 1229 Hp
Old 06-05-2014, 03:02 PM
LPI's Avatar
LPI LPI is offline
Default adjustable pickup lengths
The new increased inlet bolt on pickup comes in the following "stock" sizes for most oil pan applications:
8.00" deep pans
8.5" deep pans (Moroso, Canton, Stef's)
9.00" deep pans
We can easily make a pickup to any length to meet your oil pan depth needs.
Old 06-06-2014, 09:06 PM
My frankenstein lobotomy pan has that custom depth measure issue too.
Mark; do you have a "standard depth measure" like from oil pump mount surface to pan floor, or is there some "easier" measure to get the desired depth perfect?
Old 06-09-2014, 12:17 AM
Richie Hoffman's Avatar
Just ordered a pump
2008KRE Q16 Winner
Old 06-09-2014, 10:42 PM
bad69bird's Avatar
Ordered mine...should be here in a couple days!
Old 06-11-2014, 07:45 PM
bignate's Avatar
bignate bignate is offline
Just curious, if I sent you a good '55-'58 pump body could you do all your modifications to it?
Nate
1970 "Real" Judge RAIII 4-speed, Atoll Blue w/painted white top. Mild RAIV headed 400 motor in now.
Old 06-11-2014, 08:02 PM
Nate
Do not think the gear height ever changed. 55-58 pump to present one (Luhn would know).
Do believe the inlet screen diameter increased slightly and the spring went from 40 psi spring to 60 psi spring.
The inlet for the small inlet screen pump does not matter as Luhn machines that away anyway.
Go for it.
Old 06-11-2014, 08:32 PM
LPI's Avatar
LPI LPI is offline
Hi Nate,
If the pump is similar to the typical Pontiac spur gear with a 4 bolt bottom plate then we should be able to accommodate your request.
I am curious as well, please send the pump to us and I will let you know what I determine.
By the way your Judge is a really cool color combination. Always liked the painted top cars.
Thanks,
Herb
Old 06-12-2014, 06:19 PM
bignate's Avatar
I believe all parts are interchangeable it's just the body casting is shaped differently. I wish I had one to send you, I have a 370 but no oil pump and I'm not entirely sure what direction I'm going yet with my project. If I come up with one soon I'll send it to you to look at.
Nate
