Old 02-24-2014, 03:48 PM
The Boss's Avatar
The Boss The Boss is offline
https://www.google.com/search?q=gopr...icial&tbm=shop
This one even has a remote so you can be in the car when you turn it on!
And go racin' in the street.
  #302
Old 02-24-2014, 08:29 PM
Bentwheelbob's Avatar
Default Help Wanted
Ok, I need a little help. First, I need to replace the elastic on my shoulder belts and would like advice on the best way to remove the plastic trim pieces that dress out the roof mounted anchors for these belts. I'm sure they just snap on (I think), but before I start prying on 42 year old plastic I want to know if there are any tricks to removal. I want to take the belts off to get new elastic sewn in and to clean and possibly re-dye the belts. Here's a picture. Are these trim pieces reproduced?
I have seen on here that the retention for the shoulder belts changed around December 1971 production. The Black Car was built January 11, 1972 and has the old buckle retainer and elastic.
Secondly, I need to replace a grommet in the core support. There is a picture below. Is this part repo'd or does anyone have a source or suggestion? I appreciate all the help.
  #303
Old 02-24-2014, 11:27 PM
njsteve's Avatar
njsteve njsteve is offline
The car is a 12B car built during the second week of December but delivered in January, so the belts are the originals. If I remember correctly, those black plastic covers are just snapped over the chrome bracket with four little "fingers", so you can gently pry the edge with a plastic pry tool.
That grommet is a common piece used in several locations around the front end of the car, and during the entire span of the second generation era.
  #304
Old 02-25-2014, 12:13 AM
transam1972 transam1972 is offline
Default parts
...I have the same belt set up..those black covers are reppoped and snap on the hinge is on the top AMES page 32 #223B..perhaps P.Y. as are the clear plastic clips for securing the chrome buckles...the rubber grommet is not reproduced.(trust me I have looked) mine to has a slit in it as though it was designed like that?
Name:	1st issue standard belt upper.jpg
  #305
Old 02-25-2014, 02:58 AM
Default hardware
BOB..it looks as though you are missing a rear coot hook..I have 2 new ones I can send you if you like they are close, even though they advertise as an exact reproduction they are not..however they are GM S.R.that I got quite awhile ago..just let me know.if you could do me a huge favor the next time you take some engine pics (I like the way yours are gigantic!)..could you take a shot of your harness route by the front of your drivers side valve cover.(I added a 1976 wire shield and would like to see how an original was done)...I also have a rear alternator bracket and any shots of that would be helpful, is there a spacer involved?..lastly a fuse box pic would be tops, I have the coated screws(from Inline Tube), actually new repops with the coating and my radio surpressor is not in place..my idle stop solenoid bracket looks differant than yours..included are some of mine for reference..let me know on coat hooks..thanks!!your engine compartments looking nice!..and I have my new engine colour thanks to your thread!.
Name:	upper belt      note metal trim mounting clip.jpg
ID:	354381   Click image for larger version
Name:	1976 WIRE SHIELD DETAIL.jpg
ID:	354382   Click image for larger version
Name:	1972 original 80 amp alternator    note missing rear support bracket.jpg
ID:	354383   Click image for larger version
  #306
Old 02-25-2014, 07:04 AM
My bad on the production date. I got lazy and instead of looking at the trim tag, just looked at the GM Canada document which was right in front of me and lists 1/11/1972 as the production date. Is it unusual that there would be almost a month between production and delivery? There is another thread on here regarding the method of should belt retention and when the change in methodology occurred. December had been referenced as the date of change.
On the grommet, it is good to know they were widely used. Maybe that will increase the likelihood of someone knowing where one can be obtained.
Glenn, I would be happy to send you some pictures. PM me your email address. I'm not an expert, but I don't believe the 1972 455HO used a wire shield mounted to the front head bolt stud. There are several threads and posts around here regarding the proper routing and the various clips needed. You're right on the coat hooks - both are missing.
  #307
Old 02-25-2014, 08:56 AM
njsteve's Avatar
BTW, from the photo, the grommet looks fine, just dirty. Those grommets are supposed to have the slit in them from the factory.
I remembered another thing about the black cover - I think it is hinged at the rear with one half of the flange under the metal bracket and the other half that snaps onto the metal as a decorative cover. So be careful not to rip the hinge. Is your garage heated? You could also use a heat gun to warm up the plastic before you pry. That way it won't crack.
  #308
Old 02-25-2014, 05:35 PM
Default GROMMET AND COAT HOOK
here are some pics of my grommet and coat hook..as you can see mine also has a slit so that may be the way its made..this is an original coat hook..AMES lists 2 different ones for 67 to 72..page 65FA808 look to be the right ones..I ordered FA807 for whatever reason and must have sent them back..sorryClick image for larger version
Name:	radiator support grommet and coat hook.jpg
Name:	grommet and coat hook.jpg
  #309
Old 02-25-2014, 06:35 PM
What's a coot hook?
  #310
Old 02-25-2014, 07:57 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Originally Posted by eaglesan13 View Post
What's a coot hook?
It's for hanging up Coot ducks after shooting them on a duck hunt.
BJ
  #311
Old 02-25-2014, 10:10 PM
BJ
I've been called a coot, and I have shot more than a few, but personally I prefer mallards and quail....
  #312
Old 02-26-2014, 01:29 AM
70RAlll 70RAlll is offline
Bob your shoulder belt mount plastic clips on the upper part. It will fold down not backward. If you take a small screwdriver and press outward on the top corners you will see.
  #313
Old 02-26-2014, 02:22 AM
Default seat belt bolt cover
I happened to check mine today..the plastic hinge is on the top..if you look closely at it the hinge is on the top...I then snapped it down to lock...this was the drivers side I checked..I did not check the passenger side
  #314
Old 02-26-2014, 06:48 AM
Thanks all for the suggestion that my grommet might just be dirty. I took it off last night and it cleaned up fine, although it definitely has some age on it and has lost most of its' elasticity. I did get it reinstalled, but the line is not centered up in the core support hole and the fit leaves something to be desired. A softer grommet might fit a little better, so I'll leave the BOLO request open, but at least it looks better than it did.
Bill and Glenn - thanks for the feedback on the anchor cover/escutcheon. I'll play around with it tonight and see what I can do.
I need a little information on the length of the elastic on the shoulder belt. Should the elastic have any extra length between the two points where it is sewn onto the belt, or should the length of the elastic closely approximate the distance between the two points where it is sewn onto the belt? The elastic on the belts now is so stretched out and dry rotted that it's of little help in making that determination.
Here's the Grommet...
  #315
Old 02-26-2014, 09:47 AM
Gator67's Avatar
Gator67 Gator67 is offline
I redid the elastics on my shoulder belts recently. I made the elastics slightly longer than the two points on the belt so that when the elastic was sewn/attached it would be the same length as the two points on the belt. Just loose enough so that when the belt is folded over with the elastic on the outside, the belt does not gather. I'm not sure this is correct, but it seems logical. Making the elastic slightly longer would reduce the level of fatigue of the elastic (important since the belt is stored the majority of the time), but I don't think loose elastic would be good when the belts are in use. Also, loose elastic would result in the unused stored belt(s) flopping around while driving. Mine have been on the car about a month with no increase in the amount of give in the elastic.
  #316
Old 02-26-2014, 10:00 AM
Judge273's Avatar
Judge273 Judge273 is offline
Gator, Can you post a picture of belt in place? Length of elastic too. You got elastic at hobby lobby if I recall?
Mike/Illinois
  #317
Old 02-26-2014, 10:01 AM
RamAir's Avatar
RamAir RamAir is offline
times 2
  #318
Old 02-26-2014, 06:57 PM
Default 1972 UPPER BELT
Name:	72 belt first design.jpg
Name:	2 bolts retain belt.jpg
Name:	buckle to clip mount.jpg
Name:	eschuen    these are repopped.jpg
  #319
Old 02-26-2014, 07:18 PM
Gator67's Avatar
Sure thing. I don't have a photo in my files, but I'm happy to snap a couple photos tomorrow when I'm at the shop. I'll also take measurements as well.
I did purchase the elastic at Hobby Lobby…there are two types there…I used the one with the ribs that seems to more closely approximate the original elastic. I think it's called braided (rather than knitted). The original elastic looks like it's 5/16, but only 1/4 and 3/8 is available. I chose 3/8 because for durability and because it looks better.
  #320
Old 02-26-2014, 08:41 PM
Default Winner, winner, chicken dinner...
So the should belt anchor covers on the Black Car hinge up and not down. I am betting that their orientation is original, but NJSteve might weigh in differently. This is probably another example that the guys who assembled these cars were more concerned about a cold beer at lunch than they were about a bunch of old Coots trying to figure out the proper original assembly method 42 years later...
