Old 11-08-2013, 09:15 PM
deadendcustoms deadendcustoms is offline
Default 1963 four door tempest solid axle conversion
hes my wifes 63 four door just got the car back on the ground , custom made adjustable ladder bars made from 1" dom 156 wall tube cut, bent, tapped,notched, tig welded by myself, not happy about the dropped crossmember has way too much drop its only tacked in so im goin to pull it out and make my own, I just cant get the car low to where it looks good with out it bein close to the ground the rear is a 8.8 out of a mountaineer with 373s and posi disc brakes , runnin a track bar and coil overs , frame rails are 2x3 box tubing this car is very rusty ,
ID:	342389   Click image for larger version
ID:	342390   Click image for larger version
ID:	342391   Click image for larger version
ID:	342393   Click image for larger version
  #542
Old 11-08-2013, 09:17 PM
Default 4 door tempest
more pics of the 63 four door
ID:	342399   Click image for larger version
  #543
Old 11-08-2013, 09:25 PM
ahnuld's Avatar
ahnuld ahnuld is offline
good job, that cross member is low, i'd fix it too. Post some pics of the rest, mine was a basket case too. Dan
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
  #544
Old 11-08-2013, 10:07 PM
what size back tire are u running , is ur crossmember dropped how far from the ground is it , aslo what rear spring rate are u using
  #545
Old 11-08-2013, 10:10 PM
ahnuld's Avatar
i got 28 x 12 m/t, 150 pound coilovers, and i've had 4 full size men cruising, i can take pic of my crossmember tonight and measure it. Dan
  #546
Old 11-08-2013, 10:14 PM
ok thanks my last two sets of springs are not marked but the car bottomed them out
  #547
Old 11-09-2013, 01:17 AM
ahnuld's Avatar
my crossmember is 4 3/4 inches from the ground at lowest point, if pics are upside down blame I phone, one old pic when i built it. Dan
ID:	342428   Click image for larger version
ID:	342429   Click image for larger version
  #548
Old 02-23-2014, 03:42 AM
blueghoast's Avatar
Default Tempest Motor Pics.
Here's a couple pics of the motor for this summer.
GT.
ID:	354114   Click image for larger version
  #549
Old 02-23-2014, 12:08 PM
GaryK's Avatar
GaryK GaryK is offline
Nice work Eddie - looking forward to seeing it on the road again.
  #550
Old 02-23-2014, 12:10 PM
GaryK's Avatar
GT.
Love the stacks! What size motor?
  #551
Old 02-23-2014, 10:31 PM
blueghoast's Avatar
It's a 400 ci. just a used motor that I got awhile back.
I put a new oil pump in it a set of 16-heads and a crane
RA-IV cam I had lying around. The motor is a 1968 and
the heads I used are 1968 also same month to only a few
day's from the date of the block and of coarse you can see
the induction system. Should make a good driver for the summer.
WOW If I get all these cars done for the summer I'll have a variety
to drive through the week.
GT.
  #552
Old 02-23-2014, 11:53 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Default 61 going back together.
Manifold & carb back on. Alternator conversion done. Still have all the odds & ends to put back on. With any luck it will be back on the road by this weekend,,,,all depends on work whether I have any time to spend on it.
Name:	Tempest going back together! 001.jpg
ID:	354234   Click image for larger version
Name:	Tempest going back together! 003.jpg
ID:	354235   Click image for larger version
Name:	Tempest going back together! 005.jpg
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #553
Old 02-24-2014, 11:57 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Thanks for posting those Keith! First time running a 4-barrel?
  #554
Old 02-25-2014, 01:30 AM
Jack,,,She's a factory 4 bbl car. Used to run it but switched to the 1bbl for fuel economy. Decided to switch back. Hard part is finding all the parts I took off over 12 years ago!!
Keith Collier
Tech advisor
POCI.org
  #555
Old 02-25-2014, 04:01 AM
jdhill jdhill is offline
Default '63 tempest convertible
I was trying to upload photos but it didn't seem to want to work. A couple pics of what it looks like now and one rendering when finished. I want to do the rearend conversion and disc brake from tend but am more concerned with how low I can get it and providing enough tire clearance. I have a built 400 for it but so far that's it. Was thinking if doing the currie street rod 9" which I guess is 56" wide as I want as much room for a wide lip on a 9.5" wide rear with 4.5 b.s. As possible. Let me know what you guys think.
  #556
Old 02-25-2014, 04:03 AM
Default Another
Here you go
  #557
Old 02-25-2014, 04:04 AM
Default Only letting me load one pic at a time?
So here's another
  #558
Old 02-25-2014, 04:08 AM
Default Want it to sit like my falcon
Here
  #559
Old 02-25-2014, 04:09 AM
Default Front
American racing photo shoot
  #560
Old 02-25-2014, 04:10 AM
Default Rear
3/4
