Old 02-28-2014, 08:37 PM
zavy70 zavy70 is offline
Default 66 GTO Headlights
Do the 3 prong (low beams) bulbs go on the bottom or the top...been too long, can't remember how they were when I took them off.
Old 02-28-2014, 08:47 PM
saltman 1965's Avatar
saltman 1965 saltman 1965 is offline
Top.
1965 Lemans Vert
1968 Shelby GT 500 KR
Old 03-01-2014, 10:53 AM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
Top is right. I can't believe how many times I've seen restored or repaired cars with the low beams on the bottom if they're stacked or on the inside of side by side setups. Jerry.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
Old 03-01-2014, 12:45 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Didn't know that, good info. Thanks!!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 03-01-2014, 12:58 PM
Old Goat 67's Avatar
I agree. You can tell when they are like that that whoever did the restoration is clueless!
Old 03-02-2014, 01:56 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 66 Pic
Here ya go.
Name:	66 details 000.jpg
Old 03-02-2014, 06:26 PM
I bought a T3 (just one) at a swap meet last week. I couldn't remember what it was high or low beam. Seriously, how often do we change headlights in these cars.
Old 03-02-2014, 06:28 PM
arbys's Avatar
arbys arbys is offline
I was just asking myself the same question. For me. hardly ever on my DD and never on my old cars.
Old 03-03-2014, 11:56 AM
GT182's Avatar
GT182 GT182 is offline
Just make sure the tangs on the headlight are long and standout further, or the stock plug connector won't work. I had that problem with a set of Sylvania halogens. Wagner's are ok.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-22-2014, 04:09 PM
Oldeboy70 Oldeboy70 is offline
I have just run into this problem with the length of the tangs on the high beams. (Sylvania Xtra vision) I didn't have this problem with the low beams.
The attached picture shows how much longer the tangs are on the T3's (left) are than the Sylvanias. (right)
The tangs don't engage the female portion of the connector....
Any ideas on how to fix this without cutting up my original plug connector?
Old 03-22-2014, 04:12 PM
arbys's Avatar
Someone should come up with a coupler.
Old 03-22-2014, 06:12 PM
Allright I came up with a workable solution without cutting into my original harness.
In my mind the new Sylvania bulb would be the "at fault" issue.
Thus that is where my modifications would reside.
I already had newer Sylvania low beams and I wanted the high beams to match. I did not note this issue with the low beam bulbs.
Caveat: There are many talented folks on here who may come up with a much more eloquent solution.
That being said I noted there are holes in the bulb tangs. (similar to the holes I have seen in 110v male plug connectors) I then thought I might be able to use these male prongs from a replacement 110v male plug found at the local hardware store. I then cut the (bent) wire connecting ends off of the male prongs and enlarged the thru holes on both sets of prongs to 1/8". I then used a 1/8" pop rivet to join the tang and the newly fabricated tang extensions. The pictures are worth 1000 words of explanation.
Name:	photo 1 (3).JPG
ID:	357714   Click image for larger version
Name:	photo 1 (4).JPG
ID:	357716   Click image for larger version
Name:	photo 2 (3).JPG
ID:	357718   Click image for larger version
Name:	photo 2 (4).JPG
ID:	357720   Click image for larger version
Name:	photo 3 (2).JPG
Old 03-22-2014, 06:13 PM
more pics
Name:	photo 4 (1).JPG
ID:	357724   Click image for larger version
Name:	photo 5 (1).JPG
Old 03-22-2014, 09:55 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Wagner bulbs will work without having to make any alterations.
Old 03-22-2014, 10:15 PM
GT182's Avatar
I have a set of GE H5001s that also work. No alterations needed on the tangs.
Gary
Old 03-23-2014, 07:30 AM
Jeff Hamlin's Avatar
I bought a set of these and the fit and finish is excellent.
http://www.lectriclimited.com/mainpage.htm
Been in service for at least 10yrs
Old 03-23-2014, 11:37 AM
These are all true comments and good to know.
I wanted all 4 of my headlights to match. I already had fairly new Sylvanias in the low beams (didn't have this issue) and I had already opened the boxes for the high beams that I had to order from the store. (thus couldn't take back) I didn't want to buy another set of 4 of another brand just for the sake of matching.
Hopefully your comments/suggestion keep someone from getting into the situation I was in.
However if they do have this problem, maybe they can do something similar to what I did to get out of it.
