Old 03-27-2014, 06:54 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
Originally Posted by Transamric View Post
Not sure about his date code interpretation. He says April 7th, 1971, which would be 1D7. But to me, it looks more like I("eye")07. What do you guys see?
does look like an I, but i thought the General never used an I so as not to get confused with the # 1?????
  #1882
Old 03-27-2014, 07:06 AM
The Boss's Avatar
The Boss The Boss is offline
Only in the 1967 model year castings.
And go racin' in the street.
  #1883
Old 03-27-2014, 07:20 AM
I thought the middle position looked like a zero?
Anyway, the first position of the date codes would be for the year, a '1' in this case.
There would be no alpha letters here.
The second position would be the place for an 'I' if it were used, but it was not on stamped date codes.
(the letter was for the month btw)
And the last digits were the day of the month.
  #1884
Old 03-27-2014, 08:16 AM
Judge273's Avatar
Judge273 Judge273 is offline
Originally Posted by 2manyT/A'S View Post
Round port alternators are hard to find...
What's latest date on an "open face" alternator?
I have one that looks like August 71,but stamp is very faint.........
Mine is on my car built around third week of August 1970.
Looks like 0H12 but very faint...
Mike/Illinois
  #1885
Old 03-27-2014, 10:34 AM
2manyT/A'S's Avatar
Now that's REALLY interesting.......mine looks exactly like yours,but even LiGHTER on the date stamp....thought it was IHI2,but likely the SAME as yours...
Think I might have saved the data from the car it came from......I'm ON a mission.....
Eye Candy......garage band?
Go full screen & turn it UP!
  #1886
Old 03-27-2014, 11:27 AM
Judge273's Avatar
I can only capture date with my camera phone, its that faint.
When was the change from open face to closed?
BTW:The one on ebay is too late for Judge for sure
Mike/Illinois
  #1887
Old 03-27-2014, 01:05 PM
The change from open face to closed face was in late May of '71.
  #1888
Old 03-27-2014, 10:22 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
First, it's a 1100927, not a 1100928. I think the 928 is correct for the '71 37 amp Firebird Alternator. It may be for the GTO.
Secondly, Pontiac didn't use the letter "I" for stamped letters because it could be mistaken for the number 1. They only used the letter "I" when it was cast. September was a stamped "J"
Most of you guys have been at this longer than me, but., it's been my experience that alternators are date coded using 4 alpha-digit type stamps. This one only has 3. Example, if you are looking for a 1100928 for August 15th, 1970...it would be stamped...0H15. Or even for September 7th, 1971, it should be 1J07.
See my point. I don't recognize or trust the 3 digit thing.
Eddie
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #1889
Old 03-27-2014, 11:16 PM
68bird400HO's Avatar
928s are the 55A alternators. This 927 looks original to me, just looks like a factory mis-stamp on the date code.
  #1890
Old 03-27-2014, 11:21 PM
2manyT/A'S's Avatar
You show me yours.....I'll show you mine.......
My pictiure in not clear at all on the date code but I can definately make out _HI2....with the naked eye (and glasses).....I previously assumed it was a 1 and NOT a O....so that is GOOD NEWS for me as I have a Sept build HO than needed a correct # alternator...
  #1891
Old 03-28-2014, 07:14 AM
Pepi's Avatar
Pepi Pepi is offline
Eddie
My 73 80 amp P/N 1101015 has a very clear date code of 3D4. I know you guys are talking about 70's and 71's. I wonder if and at what point then they switched to 3 digits.
On mine I would have to go out and double check, but either all of it or the bottom line with 3D4 12V NEG was double stamped. I rebuilt it either last year or the year before, and when I disassembled it, all the parts inside were date coded just before the date on the case.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1892
Old 03-28-2014, 12:04 PM
There was no "switch" in the number of characters. The date coding for these was last digit of the year followed by the month code followed by the day of the month. If the day was a single digit, then you would have 3 characters total in the date code. 1971455HOs example of September 7th, 1971 would be 1J7, not 1J07. The 927 on my 71 TA is date coded 0J1. The only reason why I think the Ebay one is a mis-stamp is because that "D" sure looks like a "0" which doesn't make any sense. Distributors used the same date coding convention.
  #1893
Old 03-28-2014, 12:23 PM
Pepi's Avatar
Okay, good to know. I had no clue about the earlier ones, just trying to give an example of 3 digits.
  #1894
Old 03-28-2014, 04:52 PM
Sport71's Avatar
Sport71 Sport71 is offline
Here's the open-face '927 on my GTO (before and after resto), also dated 0J1.
ID:	358507   Click image for larger version
ID:	358508   Click image for larger version
1971 GTO 455 H.O. Ram Air
Nordic Silver - Black
  #1895
Old 03-28-2014, 05:51 PM
2manyT/A'S's Avatar
Nice stamp (and resto)..............I'm envious...
  #1896
Old 03-28-2014, 07:15 PM
bossbirdta's Avatar
I gotta 0H4 982 on my 71 FWIW.....looks to be stamped pretty deep....
  #1897
Old 03-28-2014, 07:20 PM
Brewster's Avatar
Brewster Brewster is offline
I'll be checking mine tonight and posting too!
  #1898
Old 03-28-2014, 10:24 PM
1971455HO's Avatar
Good, Good, Good. Like I said guys, you been doing longer than me. I was glad to be corrected and learned a bunch myself. I forgot about the 37 amps being 927's & the 55 amps being 928's.
Ol' man Smith
Son video'd this...
  #1899
Old 03-29-2014, 08:08 PM
Transamric's Avatar
So to be clear, the concensus is, after '67, "I" was still used for September casting dates, but not for stamped in date codes?
BTW, IIRC, this method of dating is called Julian dating.
  #1900
Old 03-29-2014, 11:25 PM
1971455HO's Avatar
Transamric,
I know for a fact they still used the "I" for September when casting blocks. I have been operating under the mindset listed below for a long time.
Casting: A, B, C, D, E, F, G, H, I, J, K, L
Stamped: A, B, C, D, E, F, G, H, J, K, L, M ( no "I" )
You may be right. it may have started in 1966 for the '67 models. It's been so long since I read it, I can't remember who said it here. I'm sure I learned it here on the forum. But I have not saw an alternator for '70 and up stamped with an "I" for September. I do stand corrected about the use of 3 & 4 character stampings being used for date coding and that it was common place.
Ol' man Smith
Son video'd this...
