#1881
does look like an I, but i thought the General never used an I so as not to get confused with the # 1????? |
#1882
Only in the 1967 model year castings.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#1883
Anyway, the first position of the date codes would be for the year, a '1' in this case. There would be no alpha letters here. The second position would be the place for an 'I' if it were used, but it was not on stamped date codes. (the letter was for the month btw) And the last digits were the day of the month.
#1884
![]() Looks like 0H12 but very faint...
Mike/Illinois |
#1885
Think I might have saved the data from the car it came from......I'm ON a mission.....
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
#1886
I can only capture date with my camera phone, its that faint.
When was the change from open face to closed? BTW:The one on ebay is too late for Judge for sure
Mike/Illinois |
#1887
The change from open face to closed face was in late May of '71.
#1888
Secondly, Pontiac didn't use the letter "I" for stamped letters because it could be mistaken for the number 1. They only used the letter "I" when it was cast. September was a stamped "J" Most of you guys have been at this longer than me, but., it's been my experience that alternators are date coded using 4 alpha-digit type stamps. This one only has 3. Example, if you are looking for a 1100928 for August 15th, 1970...it would be stamped...0H15. Or even for September 7th, 1971, it should be 1J07. See my point. I don't recognize or trust the 3 digit thing. Eddie
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
#1889
928s are the 55A alternators. This 927 looks original to me, just looks like a factory mis-stamp on the date code.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
#1890
![]() My pictiure in not clear at all on the date code but I can definately make out _HI2....with the naked eye (and glasses).....I previously assumed it was a 1 and NOT a O....so that is GOOD NEWS for me as I have a Sept build HO than needed a correct # alternator...
#1891
On mine I would have to go out and double check, but either all of it or the bottom line with 3D4 12V NEG was double stamped. I rebuilt it either last year or the year before, and when I disassembled it, all the parts inside were date coded just before the date on the case.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#1892
#1893
#1894
Here's the open-face '927 on my GTO (before and after resto), also dated 0J1.
1971 GTO 455 H.O. Ram Air Nordic Silver - Black |
#1895
#1896
I gotta 0H4 982 on my 71 FWIW.....looks to be stamped pretty deep....
#1897
I'll be checking mine tonight and posting too!
#1898
Good, Good, Good. Like I said guys, you been doing longer than me. I was glad to be corrected and learned a bunch myself. I forgot about the 37 amps being 927's & the 55 amps being 928's.
#1899
So to be clear, the concensus is, after '67, "I" was still used for September casting dates, but not for stamped in date codes?
BTW, IIRC, this method of dating is called Julian dating. |
#1900
I know for a fact they still used the "I" for September when casting blocks. I have been operating under the mindset listed below for a long time. Casting: A, B, C, D, E, F, G, H, I, J, K, L Stamped: A, B, C, D, E, F, G, H, J, K, L, M ( no "I" ) You may be right. it may have started in 1966 for the '67 models. It's been so long since I read it, I can't remember who said it here. I'm sure I learned it here on the forum. But I have not saw an alternator for '70 and up stamped with an "I" for September. I do stand corrected about the use of 3 & 4 character stampings being used for date coding and that it was common place.
