Old 07-16-2014, 03:20 PM
grivera's Avatar
grivera grivera is offline
Everyone has an opinion; here's mine: Following the manufacturers recommendation is never a bad thing- I took the inners out. Also, as long as coolant temperature is in check, run it for 20-25 minutes varying RPM from 1800-2500.
Will Rivera
Old 07-16-2014, 06:07 PM
Originally Posted by Hooch View Post
So do you use air to hold the valve up or do you remove the head to replace the springs?
I see the comp recommends this method. What is the best way to do this ?
I was also told to run the engine for only 5 min at a time let cool offcomple the run 5min repeat until you have 30min break in time.
What is working and what is not on engine break in theses days?
As far as oil I use Brad Penn ( the green oil)
Dont take the heads off.
