Old 07-14-2014, 05:59 PM
Alvin's Avatar
Alvin Alvin is offline
Talking
Originally Posted by Bentwheelbob View Post
Alvin - they are yours at no charge. I appreciate all the help you have provided and am happy these parts will find a good home. PM your address and I'll get them moving your way.
Talk about a quick ship and restoring my faith in my fellow man! I came home to find the tube you shipped on my porch today. Many Thanks Again Bob!
I greatly appreciate your efforts. Let me know if there's anything else I can do to assist you.
  #142
Old 07-14-2014, 07:44 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Originally Posted by 2manyT/A'S View Post
Not sure,but think his nose might have gotten out of joint when I posted that I didn't feel his current interpretation of 78 W72 T/A production figures was accurate...
I think I was with you on that one. I remember it well. Nobody was being a ***** about it, we were just commenting on the lack of the W72 Auto Y88's coast to coast. It didn't sit well with the stats in the book (I think). The warehouse that they are all stored in still has not been found.....
I'll keep looking though!
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
  #143
Old 07-14-2014, 07:52 PM
68ragtop's Avatar
So my confusion is by the chart...
L78 is a 400 Pontiac engine as is the W72. Both are different in HP, and some production number charts don't recognize the L78 as a manual.
Thanks Alvin!
Personally I like the W72 auto option in the Y88's not being listed on this page. I would rather see that than the stat were every L78 & W72 are grouped together.
I keep hoping there is some GM executive somewhere that has the production numbers stuck to the bottom of his shoe in his attic.... I'm going to go with that hope.
89 Trans am GTA
  #144
Old 07-14-2014, 09:45 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=544301
Was this the thread?
I killed this one...
  #145
Old 07-14-2014, 10:02 PM
68ragtop's Avatar
Another one from April. Mine was also. (your car, I mean)
That thread was from 9 years ago??? Holy crap, where does the time go.......
EDIT: sorry, 7 years ago
89 Trans am GTA
  #146
Old 07-17-2014, 11:23 PM
Formulabruce's Avatar
found this in my pics. Gold T/A
" Long may we DRIVE !"
  #147
Old 07-18-2014, 07:06 AM
68ragtop's Avatar
I would like to have that framed in the garage! Very cool picture indeed!
Any idea what issue that was in? magazine add I assume?
89 Trans am GTA
  #148
Old 07-18-2014, 12:53 PM
I do not have this physical advert, so I do not know its source, but would assume car and driver, Ebay may help . FB
  #149
Old 07-18-2014, 08:03 PM
Bentwheelbob's Avatar
Default Radiator Question
Okay, so I have a radiator question. The Gold Car is a W72, 4 speed, A/C car with a radiator code on the build sheet of FD*L. It does not have HD cooling. The radiator in the car is a 3 core with no visible markings or tags that I can discern. What would be the correct radiator based on this information and where should it have markings? The radiator certainly looks original, but who knows.....
Related to this, I noticed while checking it out that the two lower radiator shroud bolts are missing. If anyone has a couple I am in the market.
  #150
Old 07-18-2014, 08:26 PM
Alvin's Avatar
Bob, looking @ our '78 W72 4-spd WS6 w A/C Martini Blu Bld sheet now:
the Rad code is "FA*L"
Hoses "LU NT"
with code "VO2 HD COOLING"
the OEM Rad was a 3-core that I replaced w a 4-core back when I first purchased it...
Van Nuys Build BTW.
  #151
Old 07-19-2014, 01:55 AM
Alvin's Avatar
Wink
Hoses "LU NT"
Van Nuys Build BTW.
Another (non-Y88) '78 VN W72 4-spd Build Sheet From Roundport @ his new thread link HERE
image below w Rad Code "FY*L"
  #152
Old 07-19-2014, 07:15 AM
FY*L on Roundports build sheet is interesting because the 1978 service manual shows the FY designation as correct for a 350ci manual without a/c or the super cooling option. It has a capacity of 17.2. The 400ci manual without A/C or super cooling is listed as code FR with a capacity of 19.7.
My car is listed as FD which corresponds to the build sheet and has a capacity of 20.3.
I still am looking for two lower shroud bolts and information as to where the radiator code can be found on the tank.
  #153
Old 07-19-2014, 08:09 AM
I don't know if metal tags were on them. If they were, they'd be located near the lower hose outlet.
  #154
Old 07-19-2014, 08:33 AM
roundportponchos's Avatar
Default Radiator
To anyone on board, that help. Based on my build sheet,, do I need a FY, rad fo r a 350. Is the FY, embossed on tank. That may be why, car has a 4 core in now. Does anyone think, it was mistake from factory
Which one should I be searching for?
OTE=Bentwheelbob;5237096]FY*L on Roundports build sheet is interesting because the 1978 service manual shows the FY designation as correct for a 350ci manual without a/c or the super cooling option. It has a capacity of 17.2. The 400ci manual without A/C or super cooling is listed as code FR with a capacity of 19.7.
I still am looking for two lower shroud bolts and information as to where the radiator code can be found on the tank.[/QUOTE]
  #155
Old 07-19-2014, 08:35 AM
Default Radiator
I just thought of this, not sure if my logic correct, but since car sold new in Canada, would that have any bearing?
  #156
Old 07-19-2014, 09:21 PM
Default Hinge Detent Roller
One out of three isn't bad in baseball...Today I was hoping to get the door hinge detent roller installed, the window aligned, and the body side molding installed. Today I got the detent roller installed and I'm not so sure it isn't a worse job than replacing the heater core. I'm sure MPD would agree.
We hoped to remove the door hinge and replace the roller without taking the door off. We finally got the hinge out, but had to loosen the lower hinge bolts to do so. Installing the new roller went well - very straight forward and it fit well even though it was not made for a '78 FBody. While the hinge was out we replaced the bushings and that was a little more difficult as the pins had been replaced before and instead of securing the pin with a clip it had been tack welded in place. That finally got remedied and the real fun started.
We had slotted the rear mounting hole on the hinge so that the rear bolt could be started and then the hinge slid into place. We tried for about 30 minutes to get the right angle and never could. Finally we gave up and just took the door totally off. We had secured the door before starting with binder straps and a floor jack, so once we got the door loose it was pretty easy to manage and things went much better. It took a while to get things lined up after that, but it all came together. The door stays open, has zero sag, and opens and closes with no drag. The job, however, was a real drag...
A few tips before the pictures.
1) Don't kid yourself about doing this with the door on. Take it off.
2) Get the longest 7/16" wrench you can. We had Joey at The Welding Shop make one up for us when went to get the pin replaced.
3) Get a door spring compressor. MPD had one thank goodness.
4) Use plenty of tape. We taped with painters tape and then added a layer or two of gorilla tape and nothing got damaged.
The new roller
The custom wrench and spring compressor
  #157
Old 07-19-2014, 11:31 PM
Glad that hurdle is done! I bought 2 of the Harbor freight door holders for this work, still can be tedious in paint..Glad yours wasnt drilled out at last replacement. These need grease !
  #158
Old 07-20-2014, 07:25 AM
The Boss's Avatar
The Boss The Boss is offline
What sets us apart from the other animals is the ability to make & use tools.
Did any get thrown during this process? I'm always good for a throw when everything seems to be fighting back at you.
And go racin' in the street.
  #159
Old 07-20-2014, 07:41 AM
Default Radiator mystery
Spoke with guy in British Columbia, that had car, since around 88. remembers, now, that car had 2 core, so he changed, way back. He thinks, He may have.
Across, from his shop in Vancouver, a guy has a 78 blue, Ws6, w72. Optioned almost identical. It too has same rad, so he documented a few more, called me back. All The 4spd s had same 2 core. It must of made, cars going to Canada, with vold, got 2 cores. .
  #160
Old 07-20-2014, 07:47 AM
Default wow.
Bob, great work, have a 71, that you could really practice your skills on.
UOTE=Bentwheelbob;5237561]One out of three isn't bad in baseball...Today I was hoping to get the door hinge detent roller installed, the window aligned, and the body side molding installed. Today I got the detent roller installed and I'm not so sure it isn't a worse job than replacing the heater core. I'm sure MPD would agree.
The new roller
[/QUOTE]
