Old 12-02-2014, 01:13 PM
Alex_F Alex_F is offline
Have one of both! Turbo wagon is running and newly painted,
The GTO survived norwalk...
but didn't survive the beating I gave it on the street! Time to build a good bottom end.
ID:	383473   Click image for larger version
ID:	383475   Click image for larger version
Old 12-02-2014, 04:10 PM
charlie66's Avatar
You did a nice job with setting up those turbos....
What was the failing link with the motor , cast crank??
My Half AN Injun.....
Old 12-02-2014, 04:36 PM
Thanks! Appears failure started in the factory main caps. Hard to tell if the bolts went first or the caps themselves. It was all used junk I picked up cheap when I was still in school and broke, so not much of a loss. Now I am torn between going the aftermarket block route or building a strong factory block engine. I think I may be the first person to run a set of unported 6x heads on an aftermarket block!
Old 12-02-2014, 09:13 PM
Nice cars Alex.
Stock caps are not known for much strength! Aluminum rods like BME or GRP and splayed bolt steel caps probably would have kept that one together!(certainly longer) Aluminum rods act somewhat like harmonic shock absorbers. Factory N cranks are actually very strong but they are also very hard and more sensitive to harmonics/flex than a forged or billet crank(both are more flexible). Not advocating cast crank over forged or billet, just I am aware of a few cast crank motors well over 1000 hp that didn't break the cast crank or if they did, it wasn't crank failure that caused the crank to end up broke.
Old 12-02-2014, 10:58 PM
meanone meanone is offline
Hey Alex, how much of a beating were you giving it? Lol! How much boost were you running? Good looking cars!
Old 12-02-2014, 11:12 PM
Originally Posted by v869tr6 View Post
Looks like it will be a beast!!
Thanks a lot! It sounds and revs like it's gonna be! Should be able to take it for a test drive soon, then post up a little video. I've watched all of your guy's videos probably more than you! Lol!
Old 12-03-2014, 01:01 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Cool cars, hate to see the blown up engine, have more pictures of the cars engines?
Old 12-03-2014, 07:50 AM
charlie66's Avatar
Getting an aftermarket block is a very good idea for growth....
What year is the gto?
Old 12-03-2014, 10:55 PM
The goat is a 74, I was running close to 20 psi this summer. Previous engine was 406 in^3, unported factory heads, borg warner s360 turbos, ms2 controlling fuel and timing. I am leaning towards an IA2 block and forged crank for the new engine. Below are a few pictured from the build, hopefully they will give some winter motivation!
ID:	383595   Click image for larger version
ID:	383596   Click image for larger version
Old 12-04-2014, 02:01 AM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Haven't been paying attention to the site lately and thought I would check in. My car hasn't been on the jackstands for a long time, but its definitely been negelcted. Took it for a spin last Sat to knock the dust off.
Boost controller is giving a fatal error after powering up for 15-20 minutes. Could only muster 10psi, but it sure reminds me how much fun it is to drive.
The following day temps dropped 40 degrees so its probably done for the winter. Plan to spend some time on a dyno next year after the move. I still haven't ran it with methanol yet...
Old 12-04-2014, 08:33 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by Tom McQueen View Post
No jack stands. If you push it it moves. Engine in mock up and assy.
Cool build Tom, subscribed to your thread on YB.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 12-06-2014, 12:36 AM
Tom McQueen Tom McQueen is offline
Whats winter?
Love them monster A bodies.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 12-06-2014, 08:14 AM
charlie66's Avatar
You're motivating me to twin my 74 Ventura. There aren't that many that I have seen with turbos.
With 20 psi what do you think it was making hp wise?
Old 12-06-2014, 11:51 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Whats winter?
It's when it cools off enough to touch the steering wheel when you get in the car.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 12-10-2014, 11:57 PM
69FIREBIRD76MM's Avatar
Default jack stands
Mine is on jack stands, waiting for 455..hopefully it will be running next year..
ID:	384116   Click image for larger version
ID:	384117   Click image for larger version
ID:	384118   Click image for larger version
