Old 02-18-2015, 10:47 AM
Brewster's Avatar
Brewster Brewster is offline
Default Dyno Day ;)
All went well with the dyno session today. The carb may not be on top of its game. It ran fine, but needed more tuning than normal to get the power out of the engine. I think it held us back by a few ponies and torque. But I'm happy with the numbers anyway. The Desktop dyno predicted 388 hp and 484 lb-ft tq. Despite the carb (had to richen the snot out of it), we ended up making 395 hp @ 5000, and 500 lb-ft @ 3300.
With a little more time 400 hp and above is possible but were happy with these numbers for now.
Pictures attached to review and enjoy.
Cheers, Brew
ID:	390558   Click image for larger version
ID:	390560   Click image for larger version
Name:	Engine Start Up.jpg
  #2282
Old 02-18-2015, 11:14 AM
Norwood's Avatar
Norwood Norwood is offline
Nice numbers, what is the projected highway mpg ?
  #2283
Old 02-18-2015, 11:47 AM
Brewster's Avatar
Craig, I dont bleeping care
  #2284
Old 02-18-2015, 12:15 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Those are nice numbers, Brian! Now the real fun starts... getting her put back together!
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
  #2285
Old 02-18-2015, 12:23 PM
RamAir's Avatar
RamAir RamAir is offline
Is that the correct radiator cap Craig? ;-) lol
  #2286
Old 02-18-2015, 01:20 PM
Judge273's Avatar
Judge273 Judge273 is offline
Those are good numbers! That's with accessories too. Real life numbers, and exhaust too.
Mid 12 on 1/4 mile is in sight....
Mike/Illinois
  #2287
Old 02-18-2015, 05:13 PM
The Boss's Avatar
The Boss The Boss is offline
Good numbers, very close to my Toyota Tundra.
And go racin' in the street.
  #2288
Old 02-18-2015, 05:33 PM
Held for Ransom's Avatar
Alternator's sitting a little low for a car with power steering. Just saying...
  #2289
Old 02-18-2015, 05:48 PM
Norwood's Avatar
Maybe a little Norwalk Challange here.
  #2290
Old 02-18-2015, 08:13 PM
Brewster's Avatar
I know the numbers aren't that impressive compared to todays cars and some trucks but this 1972 Pontiac Formula is going to be hell of allot more fun to drive
  #2291
Old 02-18-2015, 08:25 PM
The Boss's Avatar
I fully agree - just messing with you a little. I laughed to myself because they are almost identical to the trucks published numbers.
  #2292
Old 02-19-2015, 07:02 AM
Brewster's Avatar
Yes its amazing on some of the new motor packages available but remember were talking 1972 here
I'd still race yah though
I added a couple more pictures to enjoy, Cheers!
ID:	390653   Click image for larger version
  #2293
Old 02-19-2015, 07:52 AM
165th's Avatar
165th 165th is offline
Congratulations on this milestone. Dyno days are fun days.
Good luck getting her back in the cradle!
  #2294
Old 02-19-2015, 11:37 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
those are great numbers Brew, and I bet that torque curve hits the high 400's at very low rpms and is as flat as Kansas from there on up! Anymore power will only serve to make the car go sideways faster
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #2295
Old 02-19-2015, 06:32 PM
Brewster's Avatar
Thanks guys! It sure gets me pumped up and seeing it gets me interested in working on the car more and more. Cheers and cant wait to share it with you all this summer.
  #2296
Old 02-19-2015, 06:41 PM
SD455DJ SD455DJ is online now
Hey Brew,
I talked to Dan about your dyno pulls and he was very pleased with how your stock '72 455HO numbered with the factory exhaust manifolds with only the 2-1/8" outlets, so there is definitely 10-15 more hp and torque to be found if you substituted new Ram Air Repro manifolds with the 2.45" outlets and possibly a different Q-jet carb. Even if you leave it as is 400 hp and 500 lbft of torque over a long rpm range is amazing.
Congrats & Cheers! Dennis
  #2297
Old 02-19-2015, 07:39 PM
Bentwheelbob's Avatar
Isn't the difference between the two exhaust manifolds just the slight opening up of the exhaust opening? I thought I had seen that the castings were the same and that RARE just has the openings slightly enlarged. Seems like a home shop project with a die grinder and a six pack of beer.
BTW - Congrats Brew on the dyno run. Great numbers and best of all it worked with no drama or great problems. Max performance is great, but at the end of the day you want the damn thing to start and run reliably without issue.
  #2298
Old 02-19-2015, 07:46 PM
Formulabruce's Avatar
Hey Brew,
I do not think you can run the stock 2-1/4 exhaust with those manifolds. I know Gardner will NOT build without a 100% verify on your manifolds..
" Long may we DRIVE !"
  #2299
Old 02-19-2015, 09:34 PM
Hi Bob,
The new RARE manifolds are cast in ductile iron rather than the original grey iron which cracks with age and heat cycles, so grinding them out would severely weaken the casting further. The RARE manifolds are opened up not just at the flange, but all the way to the collector portion, therefore helping flow a little bit. From what I understand, the runners are based on the SD455 manifolds which are purported to be larger (not sure that is true but rather Pontiac lore).
Formulabruce,
Definitely the factory headpipes would not seal to the RARE 2.45" flange and is meant to accept 2.5" mandrel pipe like from Pypes.
Dennis
  #2300
Old 02-19-2015, 10:51 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Great work Brewster. Carbs are a pain until they're right. I'm satisfied you'll breeze past 400 a good bit before your done.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
