#2281
All went well with the dyno session today. The carb may not be on top of its game. It ran fine, but needed more tuning than normal to get the power out of the engine. I think it held us back by a few ponies and torque. But I'm happy with the numbers anyway. The Desktop dyno predicted 388 hp and 484 lb-ft tq. Despite the carb (had to richen the snot out of it), we ended up making 395 hp @ 5000, and 500 lb-ft @ 3300.
With a little more time 400 hp and above is possible but were happy with these numbers for now. Pictures attached to review and enjoy. Cheers, Brew
#2282
Nice numbers, what is the projected highway mpg ?
#2283
Craig, I dont bleeping care
#2284
Those are nice numbers, Brian! Now the real fun starts... getting her put back together!
69 GTO 400, 4-Speed, Matador Red 69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack 72 Trans Am, 455HO, 4-Speed, Lucerne Blue 73 Trans Am, SD-455, 4-Speed, Brewster Green 73 Formula, 455, 4-Speed, Ascot Silver 73 Formula, 455, Navaho Orange Survivor |
#2285
Is that the correct radiator cap Craig? ;-) lol
#2286
Those are good numbers! That's with accessories too. Real life numbers, and exhaust too.
Mid 12 on 1/4 mile is in sight....
Mike/Illinois |
#2287
Good numbers, very close to my Toyota Tundra.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#2288
Alternator's sitting a little low for a car with power steering. Just saying...
#2289
Maybe a little Norwalk Challange here.
#2290
I know the numbers aren't that impressive compared to todays cars and some trucks but this 1972 Pontiac Formula is going to be hell of allot more fun to drive
#2291
I fully agree - just messing with you a little. I laughed to myself because they are almost identical to the trucks published numbers.
#2292
Yes its amazing on some of the new motor packages available but remember were talking 1972 here
![]() ![]() I'd still race yah though ![]() I added a couple more pictures to enjoy, Cheers! |
#2293
Good luck getting her back in the cradle!
http://www.starspangledbannerchallenge.com/ |
#2294
those are great numbers Brew, and I bet that torque curve hits the high 400's at very low rpms and is as flat as Kansas from there on up! Anymore power will only serve to make the car go sideways faster
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
#2295
Thanks guys! It sure gets me pumped up and seeing it gets me interested in working on the car more and more. Cheers and cant wait to share it with you all this summer.
#2296
Hey Brew,
I talked to Dan about your dyno pulls and he was very pleased with how your stock '72 455HO numbered with the factory exhaust manifolds with only the 2-1/8" outlets, so there is definitely 10-15 more hp and torque to be found if you substituted new Ram Air Repro manifolds with the 2.45" outlets and possibly a different Q-jet carb. Even if you leave it as is 400 hp and 500 lbft of torque over a long rpm range is amazing. Congrats & Cheers! Dennis |
#2297
Isn't the difference between the two exhaust manifolds just the slight opening up of the exhaust opening? I thought I had seen that the castings were the same and that RARE just has the openings slightly enlarged. Seems like a home shop project with a die grinder and a six pack of beer.
BTW - Congrats Brew on the dyno run. Great numbers and best of all it worked with no drama or great problems. Max performance is great, but at the end of the day you want the damn thing to start and run reliably without issue. |
#2298
" Long may we DRIVE !" |
#2299
Hi Bob,
The new RARE manifolds are cast in ductile iron rather than the original grey iron which cracks with age and heat cycles, so grinding them out would severely weaken the casting further. The RARE manifolds are opened up not just at the flange, but all the way to the collector portion, therefore helping flow a little bit. From what I understand, the runners are based on the SD455 manifolds which are purported to be larger (not sure that is true but rather Pontiac lore). Formulabruce, Definitely the factory headpipes would not seal to the RARE 2.45" flange and is meant to accept 2.5" mandrel pipe like from Pypes. Dennis |
#2300
Great work Brewster. Carbs are a pain until they're right. I'm satisfied you'll breeze past 400 a good bit before your done.
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
