Old 04-06-2015, 09:23 PM
Bentwheelbob's Avatar
Originally Posted by berrygoat View Post
I doubt you will be able to use the passenger side AC bracket that bolts to the manifold with those VC spacers. The triangular one. Without it you will probably get a serious belt squeal. Hopefully I'm wrong.
Thanks BG, you are a real ray of sunshine. Hah, hah...
Yeah, I'm a little concerned about that, but I hope a few extra washers and a modest modification to the compressor stud or rear bracket hole will provide necessary clearance. I only need 3/8".
  #702
Old 04-07-2015, 01:24 PM
Alvin's Avatar
Alvin Alvin is offline
Something tells me that you and MDH "ain't skeered" and will figure it out
  #703
Old 04-07-2015, 10:30 PM
berrygoat's Avatar
berrygoat berrygoat is offline
Sorry BWB, just trying to save you time and aggravation. One more "ray of sunshine". on the drivers side the Air Cleaner will be pushed up on the plastic elbow for the preheater tube. I have the thick RAIV gaskets on my 77 W72 with AC and they slightly throw off the alignment on the passenger side vent tube and that preheater elbow. PITA. Good luck, the car looks Fantastic !!!!
That triangular bracket alignment is extremely important. I had a serious belt squeel from the AC and it took me a year to figure it out. I cleaned and sanded the groove on the pulleys, changed belts a few times etc. It ended being I didn't follow the sequence in the service manual. I finally left the triangular bracket loose, tightened everything else up then wrenched down on the two bolts on the manifold. No more squeel.
  #704
Old 04-11-2015, 10:42 AM
Alvin's Avatar
Wink
Posted these local MECUM auction '78 & '79 SE's for comparison & review of details, differences, the hell of it
Link: http://forums.maxperformanceinc.com/...d.php?t=772547
  #705
Old 04-12-2015, 02:53 PM
Well, a few things getting done, but not a lot. I got a few additional responsibilities at work that are tying me down some, and have been trying to get the yard in shape since spring has sprung....
The motor is now pretty much ready for paint, I just need to figure out what I am going to use. It will probably be the Dupli Color 1619, but I ordered some 1978 Pontiac Blue engine paint from the AutoColorLibrary that is supposed to be mixed from the original formula and I am waiting for that to be delivered.
Also, I sent several pieces off to be plated at Aero Propellor that have come back and look great. This includes the throttle bracket, idle stop bracket and hardware, and EGR holddown bracket. Here's a few pictures...
  #706
Old 04-12-2015, 05:30 PM
RamAir's Avatar
RamAir RamAir is offline
That motor is a piece of artwork Bob, looks potent too.
  #707
Old 04-12-2015, 06:10 PM
Judge273's Avatar
Judge273 Judge273 is offline
Purdy nice!
Mike/Illinois
  #708
Old 04-12-2015, 10:12 PM
Formulabruce's Avatar
Bob, you have a Private Message. My cable/ net melted off the side of my house tonight!! Bruce
Sent from my Samsung Note 4
" Long may we DRIVE !"
  #709
Old 04-14-2015, 09:03 AM
Alvin's Avatar
Hey Bob - have you met Todd Lewis? Although not a Y88, sounds like similar performance upgrades while retaining outward stock appearance on his '78 "Goldrush" T/A.
POCI link HERE
  #710
Old 04-18-2015, 07:48 PM
Well, things got back on track today and we are moving forward again.....
The A/C brackets and compressor all got fit on a dry run, and the rear mounting bracket has been modified to fit over the valve covers that had to be raised to accommodate the roller rockers. We used a die grinder to remove some of the lower portion of the rear bracket and open up the adjustment slot. That combined with spacers under the intake mounting points and it looks like we are good to go. As it turns out, the car did not have the rear bracket when I got it so I had to track one down, and I still need to the rear spacer. MPD is planning to turn one on his metal lathe unless one pops up pretty quickly.
The motor is also now painted and looks great. I ended up using the Dupli Color 1619 and am very happy with the color. Most recently I bought a quart of paint from TCP global that was supposed to be mixed from the original formula, and it sucked. It was like a robins egg blue. It was weird that on the receipt someone had penciled in Dupli Color 1608 and OEM 62030. It seemed like they must have tried to match the currently available rattle cans, and did a crappy job at that. Regardless, I am happy with the 1619.
Here are a few pictures....The valve covers are temporary until everything is finished because I don't want to damage the original flash chromed W72 valve covers
  #711
Old 04-18-2015, 09:32 PM
looks great Bob!! Glad you found a rear bracket!!
  #712
Old 04-18-2015, 09:37 PM
Alvin's Avatar
Lightbulb
Excellent and Thxs for sharing the update Bob!
Suggestion: perhaps MPD could fab you one of those A/C shrouds to keep the factory A6 compressor oil sling off of your nice pristine engine bay?
Like these on Houstonian Ronnie Bayers '76 TA
Here's a fuzzy zoom angle for your viewing pleasure
  #713
Old 04-18-2015, 09:38 PM
Alvin's Avatar
Wink
Here's another fuzzy zoom angle for your viewing pleasure
  #714
Old 04-18-2015, 10:10 PM
Yeah, the one on the Black Car leaks like a sieve. Dave and I were talking today, and I think I am going to order a rebuilt compressor from the air conditioning folks at Classic Auto Air as I understand they offer a no leak/spray guarantee. Here is the shroud on the Black Cars compressor.
The compressor on the Gold Car was a new reman when I bought the car. There was no indication it was leaking, but the whole engine compartment was so filthy it's hard to say for sure.
  #715
Old 04-18-2015, 10:28 PM
Alvin's Avatar
Thumbs up
...There was no indication it was leaking, but the whole engine compartment was so filthy it's hard to say for sure...
You are gonna have a field day on our '78 Martini and '79 Y84 Bob...Filty, Filty, Filty!!!! JK
BTT - man, that shroud on the black HOe is WIDE!!!!!!!!!!!!! eh?
  #716
Old 04-18-2015, 10:38 PM
Alvin's Avatar
Talking For MPD & Bob
  #717
Old 04-19-2015, 07:44 AM
Judge273's Avatar
Coffee did spill....
Mike/Illinois
  #718
Old 04-19-2015, 08:23 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
No question the A6's make a mess. I finished a resto in 2008 with a NOS A6 that was still under pressure when I removed the rear shipping cap. I leak tested the system before charging & had no measurable loss after 2 weeks. So I charged it & the A/C worked awesome. Then, After a couple months & a few very short runs I found oil getting sprayed. Pretty sure it seeps out onto the clutch pulley when not running & gets flung around next start up. very disappointing.
I ended up drawing the system into a slight vacuum & sealed it up. Non-functioning now.
This picture was from before the hoses went on, but same issue you'll possibly be having if you charge it.
The guard will keep it off some the hood & inner fender, but the rest is going to get nailed. I had it all over the bright yellow paint. took a while to get everything clean as a whistle again.
Name:	Screen Shot 2015-04-19 at 7.16.58 AM.jpg
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
  #719
Old 04-19-2015, 09:31 AM
The Boss's Avatar
The Boss The Boss is offline
for Mike's comment & thanks for the pic Alvin!
Great work as always Bob!
And go racin' in the street.
  #720
Old 04-19-2015, 05:13 PM
Alvin's Avatar
Cool
Yeah, I had a literal laugh out loud reading Mike's comment too ...and my Mrs looked @ source of chuckle and said something about cows, or?
x2 as to MPD & Bob"s "skilz" ....now back to your regularly scheduled Gold Car coverage!
