Old 12-05-2015, 10:45 PM
moparcolt's Avatar
moparcolt moparcolt is offline
Default 68 gto convertible 1/4's what's the best way to replace them?
I have a 68 gto convertible, it had 1/4's put on it once, and they were not done well.
We are planning on replacing the quarters and inner/outer wheelhouse on both sides.
What are my options?
Does anyone make replacement parts that fit?
Anyone who has done this chime in and tell me your experiences.
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
Old 12-06-2015, 07:42 AM
green66gto green66gto is offline
Find some NOS quarters, cash in the 401k to pay for them, and you are good! Seriously, I am working on a similar project myself. I found a pair of straight but rusty quarters from a donor car, patched the rusted areas and installed them at the factory seams. there is no other way to get the factory curves at the top of the quarter panel. Skins are made for hard top cars and when installed on a convertible can be spotted from a mile away.
Old 12-06-2015, 08:20 AM
The Boss's Avatar
The Boss The Boss is offline
We used a repop skin on the 68 Tempest Custom convertible I did a few years ago - went in fine. If you finish it well inside & out, nobody will ever know.
Name:	2012-09-29 14.27.00.jpg
ID:	414921   Click image for larger version
Name:	2012-10-20 12.31.57.jpg
ID:	414922   Click image for larger version
Name:	2012-11-08 17.25.14.jpg
ID:	414923   Click image for larger version
Name:	2012-12-05 16.28.50.jpg
ID:	414924   Click image for larger version
Name:	2012-12-08 13.50.50.jpg
And go racin' in the street.
Old 12-06-2015, 03:42 PM
I don't have a convert and have never replaced that part on one but I believe the problem area is the upper surface where it meets the top-well area.
You can see that the upper portion of Boss' car looks like the original metal. If yours still has factory metal in that area, I think you could do it fine.
Old 12-06-2015, 04:10 PM
moparcolt's Avatar
I'm wondering what's different about the wheelhouse?
Chris Collier
Old 12-06-2015, 09:36 PM
6804gto's Avatar
6804gto 6804gto is offline
The wheelhouses on a convertible are almost flat on the top where as the hardtop wheelhouse has a contour or same shape as the outside wheel opening. The reason for the flat area on top is for the convertible folding top frame to be lowered and have clearance in that area. You can use hardtop wheelhouses also you just have to modify them a little to fit.
Old 12-06-2015, 09:52 PM
6804gto's Avatar
I put hardtop quarter skins on my 68 back in 2001. They took some work to get the rite contour but I don't think anyone would ever notice if done rite?
I haven't checked lately if anyone is reproducing quarters and wheelhouses for convertibles or not?
Name:	Brent's phone 402.jpg
ID:	415014   Click image for larger version
Name:	Brent's phone 406.jpg
ID:	415015   Click image for larger version
Old 12-07-2015, 09:05 AM
moparcolt's Avatar
I see they make convertible tubs for a 68-72 chevelle, anyone know if they're the same?
Chris Collier
Old 12-07-2015, 02:46 PM
MD79TA MD79TA is offline
Default Possible fit
OPGI offer a coupe or convertible quarter panel. It come without sail panel and I'm sure it will need some work to fit. Price is on sale about 250 dollars plus shipping. Love to here from others as I have a quarter that might not be worth fixing on my 68 convertible
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 12-07-2015, 04:48 PM
Vol's Avatar
Vol Vol is offline
I am putting half panels on my within the next month. I have full skins from a hardtop, and outer wheel houses too. I want to maintain the contour of the top section of the panel so I opted to do only the lower.
Old 12-22-2015, 11:21 AM
Chris I used hardtop panels I got from the PY show in the junk room cheap. i only needed a small amount and nothing was rusted in the w/h area.
Name:	gto street rod etc 014.jpg
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
