Old 12-21-2015, 04:34 PM
dataway's Avatar
dataway dataway is offline
Did you have some of the bolt re-oxided? I see what looks like fresh black and grey phosphate oxiding.
I do some bolts myself ...but not always happy with the results and not sure of the longevity ... I use the 200 degree soak in Mag Phosphate etc. method.
JohnnyB
  #422
Old 12-21-2015, 08:38 PM
Awesome job GW... What's the deal on the brake lines at the MC? are you going to connect at the flare nut on the end of that stub or is that just for bleeding purposes?
Old 12-21-2015, 09:23 PM
David Jones's Avatar
There will be a rear brake hold off valve under the master?
  #424
Old 12-21-2015, 10:40 PM
^^ Oh yeah...I shoulda known that. ^^
Old 12-21-2015, 10:46 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Nice Greg! Won't be long now!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #426
Old 12-21-2015, 11:13 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Johnny, yes refinished the bolts using a zinc phosphate method. I outlined the procedure earlier in this thread. Sounds like you do the same thing.
Greg, that damn little line won't fit it's too short. Purchased from Inline Tube years ago when I restored the frame. Going to have to call them to see what's up.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #427
Old 12-21-2015, 11:16 PM
GOAT WHORE's Avatar
Ya, right, been saying that to myself for some time! Well the goal is still to get er to the GTOAA nationals this coming July in Seattle.
  #428
Old 12-22-2015, 02:18 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Looking real good GW!! I'm sure you are getting anxious to see her completed. I really do like that color gold it really stands out! Your Grandmother had good taste, I'm sure she would be very proud of how you are restoring her car. When you go to Seatle I'm sure you will have no problem bringing home the concourse gold award. Post pics when you can.
Thanks.
CB
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #429
Old 12-22-2015, 04:10 PM
The reason that line got my attention in the first place is that the booster/MC equipment under my hood is an eyesore. I have a brand new booster and MC just sitting on a shelf that I may as well use but I was wondering what to do about replacing the lines.
I see that Ames lists front line kits. I may try that out.
Old 12-22-2015, 05:12 PM
dataway's Avatar
Inline is hit and miss in my opinion ... good selection, but much of what they describe as absolutely "correct" is barely close.
Just installed a set of their wheel cylinder to flex hose hard lines ... PITA, had to do considerable bending to get them right.
Ended up removing them because they were not spring wrapped like "correct" originals. Installed some from a different company ... Right Stuff I think ...fit quite a bit better, still needed tweaking.
PS. Love this thread
  #431
Old 12-22-2015, 08:54 PM
The spring wrap is the only reason I was going to buy any in the first place. Otherwise, I'd just make some to replace the highly visible ones between the MC and the distribution block on the frame rail. I may do that anyway...If I could figure out a good way to simulate the wrap.
Old 12-22-2015, 09:08 PM
tinindian68's Avatar
tinindian68 tinindian68 is offline
http://www.ebay.com/ulk/itm/191718147670
They sell just the spring shielding. I've used it before. Just slip it on, add your fitting and flare the end. Helps with tight bends too to keep the line from kinking.
  #433
Old 12-22-2015, 10:28 PM
Where would one find that shielding? I've seen the line at certain parts stores.
OOPS!...Just noticed the link. Thanks!
  #434
Old 12-22-2015, 11:45 PM
BOB VIDAN BOB VIDAN is offline
Hey whore, is this going to be ready for the Bellevue nats? If not why?
Practicing social distancing for 65+ years
  #435
Old 12-24-2015, 08:41 PM
GOAT WHORE's Avatar
Bob, I am sure hoping it will be done in time. If not it will be due to my lame ass not putting enough time and money into it. That and I am still looking for a nos gold steering wheel.
  #436
Old 12-28-2015, 09:56 PM
GOAT WHORE's Avatar
Here we go again! Wet sanding the clear so deck lid, hood and bumper all come off again. Mike and I got the quarters, deck lid, hood and both doors done yesterday and today.
Going to spray the final coats of clear in a booth with a bake cycle at Walkers place of employment.
  #437
Old 02-12-2016, 12:14 AM
GOAT WHORE's Avatar
Been making more slow progress. Car was shot in clear for the final time and Walker is scheduled to Polish in two weeks.
Found an upholstery guy and am pretty excited as he comes highly recommend from a high end Porsche shop I've done some work for.
Ordered a ton of stuff from Ames today including a bunch of interior stuff. Tom, the upholstery guy, is going to order the headliner material, carpet and vinyl top. The gold samples I got from Ames for the headliner was not gold but a buff and Tom had a carpet sample color that I liked a lot better as well.
  #438
Old 02-12-2016, 12:27 AM
GOAT WHORE's Avatar
This car originally had idiot lights and no tach. I want to run rally gauges and an in dash tach. I had a few sets of rally gauges around and a very nice tach. I sent them to Pete Serio of Precision Pontiac to restore. He took the best of what I had plus some excellent parts he had and made me an awesome set.
Pete set the milage to the actual milage from my grandma's car. Pete also matched the sensors to the gauges so they will read accurately. Also modified tach to work with my MSD dizzy.
I've had Pete do work for me in the past and as always his stuff is top notch, thanks Pete!
  #439
Old 02-12-2016, 12:32 AM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
That picture with the freshly laid clear is absolutely stunning. Well done. I'm digging the gold!
P.O.S.I - It's not just a club...it's an addiction!
  #440
Old 02-12-2016, 03:35 AM
Nice work Greg, even if you live in Sherwood.
