Old 04-05-2016, 11:29 PM
mike leech's Avatar
mike leech mike leech is offline
Originally Posted by cgeise View Post
Are you Saying I don't have a clue ???
I very much doubt that was his intent
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #182
Old 04-06-2016, 01:27 AM
john marcella john marcella is offline
Not at all, I don't know anything about you . I was just sayin.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #183
Old 04-06-2016, 03:53 AM
BB70's Avatar
BB70 BB70 is offline
Hey Mike, can I ask what size pushrod do you use and has the pushrod hole been moved ?
Thanks and good luck this season.
John
  #184
Old 04-06-2016, 08:08 AM
mike leech's Avatar
John
Sure. The pushrods are 7/16 to 3/8 taper .165 wall. And the intake rocker is .700 offset. So yes the pushrod hole was moved.
EHTTFMF!
  #185
Old 04-06-2016, 09:08 AM
Should be 1/2 straight imo.
John Marcella
[email protected]
ph. 248-259-6696
  #186
Old 04-06-2016, 09:22 AM
mike leech's Avatar
I agree. But no room in them lil heads.
EHTTFMF!
  #187
Old 04-08-2016, 08:01 PM
mike leech's Avatar
Ha ha.
EHTTFMF!
  #188
Old 04-09-2016, 06:13 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Valve hit the piston?
[email protected]. 3460#s
  #189
Old 04-09-2016, 08:55 AM
mike leech's Avatar
Piston is OK. Valve, Guide was ripped out of head, Rocker arm junk obviously the spring and retainer. It's all fixed up. Just waiting on a head gasket.
EHTTFMF!
  #190
Old 04-09-2016, 12:45 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
I thought it might be the guide or seat. Glad it's fixed, go get'em!
  #191
Old 04-09-2016, 12:54 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Was the valve to guide clearance to tight? Making that must steam your egt's must expand that valve a bunch.
  #192
Old 04-09-2016, 01:34 PM
mike leech's Avatar
No. The spring was the first to go. Then retainer. Then side load on guide. Then valve touched radially. Then bent valve. Then rocker.....
Not sure why spring broke.....
EHTTFMF!
  #193
Old 04-09-2016, 02:15 PM
slowbird's Avatar
slowbird slowbird is offline
What springs you running? Did the dyno let go of the engine at any point? I've broke a couple PAC double springs from the dyno letting go.
  #194
Old 04-09-2016, 02:50 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Great thread Mike. Very pertinent info. Thanks for the many details. Best of luck with the dyno session; Looking forward to some top level numbers.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
  #195
Old 04-09-2016, 04:50 PM
Sometimes you just happen to be the guy that gets the part that is not perfect and then you have an issue. Especially when the part is "exercised" like Mike is doing his deal.
Keep after it Mike!
  #196
Old 04-10-2016, 01:31 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Jack Gifford View Post
... are the retainers a good (snug) fit in the springs?...
I asked this because of the adjacent valve in the photo- the non-concentricity of the retainer with the O.D. of the top of the spring is visible. So the retainer's shoulder must not be a snug fit in the spring I.D. This, in combination with the skimpy retainer O.D. and cross section in that area (considering the extreme loading), would cause me to suspect retainer failure.
  #197
Old 04-10-2016, 10:32 AM
Gary Kubisch Gary Kubisch is offline
Mike,
Your car has progressed quite a lot over the last few years.
Can you talk about what you've used fuel-wise from being a mid nine second
combo to what it is now?
  #198
Old 04-10-2016, 12:17 PM
mike leech's Avatar
Originally Posted by Gary Kubisch View Post
Mike,
Back in the day with the 477 that was 13.7 cr we ran c14. We tried q16 In 2010 with good results. Still running it now. There are fuels that show more power but they are risky imo.
EHTTFMF!
  #199
Old 04-20-2016, 09:18 PM
mike leech's Avatar
Back on the pump again!
EHTTFMF!
  #200
Old 04-20-2016, 09:41 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Good luck
